Old 11-03-2006, 01:00 PM   #1
TunerShark
TunerShark's Avatar
Send a message via AIM to TunerShark
Default Upstream or Downstream O2 Sensor? interchangable?
my downstream o2 sensor(on cat) is shot, so i just bought a new denso one for my car on ebay, but it doesnt specify wether its the upper or the lower one, i mean, are these 2 sensors interchangable? or are they 2 completely different?
heres the auction
http://cgi.ebay.com/ebaymotors...d=1,1
thanks
238 WHP / 183 FT Ibs @ 9 PSI
Tuned w/ ECTune
Stock Block D16Y8
Single Stick Turbo http://images.honda-tech.com/set1/smile/emthup.gif
TunerShark is offline   Reply With Quote
Old 11-03-2006, 01:02 PM   #2
Padawan
Darth ModerVader
Padawan's Avatar
Default Re: Upstream or Downstream O2 Sensor? interchangable? (TunerShark)
They're interchangeable, as far as function goes.
-NEMO ME IMPUNE LACESSIT-
Padawan is offline   Reply With Quote
Old 11-03-2006, 01:07 PM   #3
TunerShark
TunerShark's Avatar
Default Re: Upstream or Downstream O2 Sensor? interchangable? (Padawan)
ok cool, so just in case, would an o2 sensor made for the header fit right into where the cat one is supposed to be?, i mean like wiring & fitment wise?
thanks
Tuned w/ ECTune
Stock Block D16Y8
Old 11-03-2006, 01:15 PM   #4
Padawan
Darth ModerVader
Padawan's Avatar
It should. I know on the Integra, the secondary sensor has a rubber grommet to seal the hole where it enters the car, and the wiring might be a slightly different length. I'm not entirely certain, but I assume it's a similar situation with the Civic. Either way, it shouldn't be a big issue.
Old 11-03-2006, 06:09 PM   #5
TunerShark
TunerShark's Avatar
ok, what about the plastic connector harness? are they still both the same on upper and lower?
Tuned w/ ECTune
Stock Block D16Y8
Old 11-03-2006, 06:13 PM   #6
Padawan
Darth ModerVader
Padawan's Avatar
Yes, the connectors are exactly the same.
Old 11-10-2006, 06:47 AM   #7
yeah_its_fast
yeah_its_fast's Avatar
can i get a picture of where these O2 sensors are suppost to be?? I have a b16a2 and i was told it was missing the o2 sensor. there is a sensor by the cat but not one on the header.
SPR
yeah_its_fast is offline   Reply With Quote
01, 03, 1992, 2001, accord, civic, downstream, function, honda, integra, interchangable, interchangeable, o2, oxygen, sensor, upstream
