Which Rear Swaybar will fit a 1993 Del Sol SI?
Besides ST, Progress, will the Type-R sways sit the rear of the del sol?
Which other cars (Sways) are interchangable w/ the 93 Del SOL SI?
Thanks
Thanks
Re: Which Rear Swaybar will fit a 1993 Del Sol SI? (mrtrinh)
correct me if i am wrong but i belive you will need the aspec brace....im pretty sure at least for civic you do so i would imagine you need it for a del sol...
Re: Which Rear Swaybar will fit a 1993 Del Sol SI? (rysingsun86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rysingsun86 »</TD></TR><TR><TD CLASS="quote">gsr fits that i know of u'll need the gsr LCA's tho del sol's dont have the mounting holes ;]</TD></TR></TABLE>
you dont need the gsr LCA's. my brother swapped over his gsr bar form his gsr to my dads sol and it works without modifications to the suspension.
Re: Which Rear Swaybar will fit a 1993 Del Sol SI? (dillywong)
idk i have a del sol and my old 94 si wouldnt work w/ a gsr sway bar unless u drilled a hole but im pretty sure about the lca's tho coz i have em on my car now
all 94-01 integra's and 92-95 civic's suspension components are interchangable with del sol's.
so pretty much the ITR sway bar your asking about fits. you just need some new rear LCA's. your oem Si ones dont have the mounting holes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcVTECeg2 »</TD></TR><TR><TD CLASS="quote">all 94-01 integra's and 92-95 civic's suspension components are interchangable with del sol's.
so pretty much the ITR sway bar your asking about fits. you just need some new rear LCA's. your oem Si ones dont have the mounting holes.</TD></TR></TABLE>
Dont you risk tearing up your subframe when using a larger mm sway bar like the CTR and ITR with out something like tha ASR brace?
Re: Which Rear Swaybar will fit a 1993 Del Sol SI? (CH3A:chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CH3A:chris »</TD></TR><TR><TD CLASS="quote">Dont you risk tearing up your subframe when using a larger mm sway bar like the CTR and ITR with out something like tha ASR brace?</TD></TR></TABLE>
Yes, mainly on EK chassis. The Beaks kit is sufficient for EG/DC chassis.
Re: Which Rear Swaybar will fit a 1993 Del Sol SI? (BlueIntegraBoy)
cool i just orderd the ASR brace with ctr sway bar. I wish in a way i woulda got the beaks one though...
hondapwr
05-11-2006 08:43 AM
