i just got an error code on my radio display
Old 09-29-2006, 01:41 PM
justdonikes's Avatar
Default i just got an error code on my radio display
today my car wouldnt start so i got a jump from my friend, i started the car and pushed the radio on button, "enter code" showed up and i guess it wont work until i put in the correct code. i know theres like a default or standard code you can put in like 1111 or 2222, does anyone know the exact code to put in?
i have a lx sedan btw..
thanks in advance
Old 09-29-2006, 01:47 PM
westspeed's Avatar
Default Re: i just got an error code on my radio display (justdonikes)
your radio locked itself you need to either bring it to the dealership or find out how to unlock it. the dealership should do it for free
Old 09-29-2006, 02:43 PM
LxXsilenceXxP's Avatar
Default Re: i just got an error code on my radio display (westspeed)
on the inside of the glove compatmet door is the code
Old 09-29-2006, 03:22 PM
Declectic's Avatar
Default Re: i just got an error code on my radio display (LxXsilenceXxP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LxXsilenceXxP &raquo;</TD></TR><TR><TD CLASS="quote">on the inside of the glove compatmet door is the code</TD></TR></TABLE>
in addition to that, i believe it should also be in the manual too right?
Old 09-29-2006, 04:34 PM
Type X's Avatar
if your 2006 lx wouldnt start, i'd bring it to the dealer
Old 09-29-2006, 10:51 PM
PROHONDA's Avatar
THERE SHOULD BE A STICKER IN THE GLOVE BOX OR ON THE TRUNK LID. IF IT READS'' ENTER CODE'' AND YOU DONT HAVE THE CODE YOU CAN TURN THE RADIO OFF AND HOLD THE NUMBER ONE AND THE NUMBER SIX KEYS ON THE RADIO AT THE SAME TIME THEN TURN THE RADIO ON AND THE AUDIO UNIT SERIAL NUMBER WILL DISPLAY WRITE IT DOWN AND BRING IT TO THE DEALER. IF THE AUDIO UNIT READS '' ERROR'' THAT MEANS YOU ENTERED THE WRONG CODE TOO MANY TIMES YOU NEED TO DISCONNECT BOTH BATTERY CABLES. HOLD BOTH OF THE CABLES TOGETHER FOR ABOUT TEN SECONDS THEN RECONNECT THIS WILL DRAIN ALL THE VOLTAGE OUT OF THE PCM AND RESET THE RADIO. THEN DO THE 1 AND 6 METHOD. SORRY SO TECHNICAL IM A TECH AT HONDA. ANY Q'S HIT ME UP JIXERBOY1000@HOTMAIL.COM
Old 09-30-2006, 08:07 PM
Demonis's Avatar
yeah if you had to jump your car off for any reason other than leaving EVERYTHING on all night, you should take it to the dealer and get a new battery/alternator
Old 10-01-2006, 07:17 AM
modifyORdie's Avatar
Default Re: i just got an error code on my radio display (SeanJohn1802)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SeanJohn1802 &raquo;</TD></TR><TR><TD CLASS="quote">in addition to that, i believe it should also be in the manual too right?</TD></TR></TABLE>
its a seperate little card thing about the size of a business card in a plastic bag
Old 10-01-2006, 09:13 PM
Striker_1818's Avatar
Default Re: i just got an error code on my radio display (Type X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type X &raquo;</TD></TR><TR><TD CLASS="quote">if your 2006 lx wouldnt start, i'd bring it to the dealer </TD></TR></TABLE>
Old 10-02-2006, 06:42 PM
COMplex.'s Avatar
Something smells fishy...
Old 10-04-2006, 12:03 PM
gus738's Avatar
open the glove box , sometimes theirs a sticker on the wall thats the code , also their should be a buisnes card as stated . if you open up your navi on the back it has a serial number give this to honda n they'll give you a code
Old 10-05-2006, 01:32 AM
dejavu1's Avatar
check manual book.
Old 10-05-2006, 01:35 AM
gus738's Avatar
Default Re: i just got an error code on my radio display (dejavu1)
manuels never state such personal info ... watch read yours and see if your code is there
Old 08-02-2007, 07:21 PM
mandy8819's Avatar
I couldn't find my code anywhere. Thanx!
Old 08-02-2007, 09:58 PM
Blackline47's Avatar
Default Re: i just got an error code on my radio display (PROHONDA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PROHONDA &raquo;</TD></TR><TR><TD CLASS="quote">THERE SHOULD BE A STICKER IN THE GLOVE BOX OR ON THE TRUNK LID. IF IT READS'' ENTER CODE'' AND YOU DONT HAVE THE CODE YOU CAN TURN THE RADIO OFF AND HOLD THE NUMBER ONE AND THE NUMBER SIX KEYS ON THE RADIO AT THE SAME TIME THEN TURN THE RADIO ON AND THE AUDIO UNIT SERIAL NUMBER WILL DISPLAY WRITE IT DOWN AND BRING IT TO THE DEALER. IF THE AUDIO UNIT READS '' ERROR'' THAT MEANS YOU ENTERED THE WRONG CODE TOO MANY TIMES YOU NEED TO DISCONNECT BOTH BATTERY CABLES. HOLD BOTH OF THE CABLES TOGETHER FOR ABOUT TEN SECONDS THEN RECONNECT THIS WILL DRAIN ALL THE VOLTAGE OUT OF THE PCM AND RESET THE RADIO. THEN DO THE 1 AND 6 METHOD. SORRY SO TECHNICAL IM A TECH AT HONDA. ANY Q'S HIT ME UP JIXERBOY1000@HOTMAIL.COM</TD></TR></TABLE>
No need for Caps Lock...
Old 08-03-2007, 05:56 AM
chiggin's Avatar
Default Re: i just got an error code on my radio display (mandy8819)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by modifyORdie &raquo;</TD></TR><TR><TD CLASS="quote">its a seperate little card thing about the size of a business card in a plastic bag</TD></TR></TABLE>
When you buy a new civic, you are given a card with the radio code on it. It may be in the bag with your manual/paperwork, but the salesman who sold me my Si handed it to me (he wanted to make sure I knew what it was). They did the same thing with my dad when he bought his civic. This is an anti-theft measure. If someone rips your radio out, They are not supposed to be able to use it without the code.
Old 12-12-2007, 04:32 PM
winesaavy's Avatar
Default Re: (Demonis)
Thank You! I was told that you needed to unhook the battery for 2 hours and a radio installer told me you had to let the car run for an hour to clear the error code...touched the positive and negative cable to gether for 10 seconds...presto! Back to the "code" and all is well. Graci!
ali311
Honda Civic (2001 - 2005)
10-08-2007 08:53 AM
Wicked04
Honda S2000
10
04-21-2007 06:00 PM
htilson
06-05-2005 07:16 PM
jaczs
01-07-2003 10:21 PM
Quick Reply: i just got an error code on my radio display
