Go Back   Honda-Tech > Honda and Acura Technical Forums > Suspension & Brakes
Old 09-26-2006, 09:52 PM   #1
ogawa_jiei
Default What exactly does an alignment consist of? EG Civic specific....
Edited
ogawa_jiei is offline   Reply With Quote
Old 09-26-2006, 10:15 PM   #2
Tyson
Tyson's Avatar
Default Re: What exactly does an alignment consist of? EG Civic specific.... (ogawa_jiei)
it would consist of adjusting toe.
and if you point out you have camber adjustment, they can adjust that too.
but toe is the most important. of course you can adjust rear toe...
Don't IM me your TECHNICAL question. Start a thread, I'll answer there.
I am not a moderator, nor do I need to provide you technical advice.
Tyson is offline   Reply With Quote
Old 09-26-2006, 10:54 PM   #3
ogawa_jiei
Default Re: What exactly does an alignment consist of? EG Civic specific.... (Tyson)
Edited
Old 09-27-2006, 09:32 AM   #4
nonsense
nonsense's Avatar
adjust camber first, then toe. As for how much camber you want, it depends on what you're doing with the car. If it's mainly street driven and won't see the track or AutoX then you will probably want somewhere between -1 and -1.5. If you will be tracking the car a lot and don't care about the downsides of having more camber (straight line accelleration and braking are effected slightly) then you can go with more negative camber. Either way, have them set the toe at zero front and rear, not just "within spec" so that you avoid tire wear.
I don't own any more Honda's
nonsense is offline   Reply With Quote
Old 09-27-2006, 10:02 AM   #5
ogawa_jiei
Default Re: What exactly does an alignment consist of? EG Civic specific.... (nonsense)
Edited
adjust, adjusting, adjustment, alighnment, alignment, camber, civic, consist, consists, front, kits, of, settings, toe, what
