Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda CRX / EF Civic (1988-1991)
Old 09-26-2006, 05:08 AM   #1
STDClayton
claytonross hailclayton666 YourArsonistxo claytonmathias
Send a message via AIM to STDClayton
Default parking lights randomly come on when brakes are pressed
ok, so intermittenly my parking lights (1st click) will come on when the lights are off when i press the brakes. it doesn't matter if the car is on or off. it just happens sometimes and doesn't other times. what do you guys think could be causing this? maybe the brake light/fuel pump ground isn't securely grounded in the hatch? is there a ground below the steering wheel around where the turn signal canceller is?any help would be greatly appreciated.
Modified by STDClayton at 9:36 AM 9/26/2006
Originally Posted by kNOwLedGe.
We all know how the term "JDM" has been DVDA'd...
HELP SAVE MY GIRLFRIEND'S LITTLE BROTHER
Double Lung Transplant
EJ8 Squad
Visit my bio for vouches http://images.honda-tech.com/set1/smile/emthup.gif
STDClayton is offline   Reply With Quote
Old 09-26-2006, 10:05 AM   #2
STDClayton
Default Re: parking lights randomly come on when brakes are pressed (STDClayton)
seriously, if anyone knows if this is maybe a sign of something failing or if it's something completely obvious that i can't think of, let me know!
EJ8 Squad
Old 09-26-2006, 11:32 AM   #3
wiZCo
Stouts 'n' Scotch
2012 Subaru WRX STI
wiZCo's Avatar
Ders 0ne
I think you know where you're going with this, it definitely sounds like a grounding issue because the electricity is leaking into other wires when you hit your brakes. Check all of your grounds out and the brake light switch itself. Good luck, wiring demons are either simple or mind-numbingly complicated in my experience.
Old Hondas: 1990 FW ED7, 1999 FBP EM1
Originally Posted by CBXweb View Post
Did Brock come in this thread yet explaining how not breathing in air saves him $5000 a month or some ****?
wiZCo is offline   Reply With Quote
Old 09-26-2006, 02:55 PM   #4
markviiisvt4
markviiisvt4's Avatar
Send a message via AIM to markviiisvt4
yep look at the grounds and bulb sockets for the taillight, also check all your break light bulbs. I had a dual filiment bulb pop once and part of the brake filiment was touching the parking light filiment. Talk about beating my head aginst the wall on that one.
markviiisvt4 is offline   Reply With Quote
Old 09-27-2006, 09:45 AM   #5
STDClayton
Default Re: (markviiisvt4)
thank you, both so much. that's what i was thinking, wiZCo, i just needed some reassurance. markviisvt4, good call on that man. i never would have thought about that. now it's time to figure this out!
EJ8 Squad
Old 09-28-2006, 02:36 AM   #6
SETI20
SETI20's Avatar
Send a message via ICQ to SETI20 Send a message via AIM to SETI20
Your fluid level is low.
Doesn't anyone read the manual anymore?
Flickr
SETI20 is offline   Reply With Quote
Old 09-28-2006, 04:52 AM   #7
STDClayton
Default Re: (SETI20)
fluid level?
EJ8 Squad
Old 09-28-2006, 04:58 AM   #8
SETI20
SETI20's Avatar
pop the hood, unscrew the cap of your brake cilinder, and top it off.
Problem solved. Bet you a beer on that.
Flickr
Old 09-28-2006, 05:49 AM   #9
Loserkidwac
Loserkidwac's Avatar
Send a message via AIM to Loserkidwac
Exactly what i was going to say...you are saying you dash brake light is coming on when you hit the brakes, correct...there is a sensor in the MC when it gets low it turns on the dash warning light, when you press your brakes it is pushing enough fluid out to set the sensor off Click the image to open in full size.
But yea now after read rereading i see you aren't talking about your dash light Click the image to open in full size.
91 CRX SI LS-T "B-Rex" My "B-Rex" Project Thread SOLD
95 Civic VX #2 (DD)
92 Mazda Miata
Loserkidwac is offline   Reply With Quote
Old 09-28-2006, 09:24 AM   #10
STDClayton
Default Re: (Loserkidwac)
exactly. i know that the brake light on the gauge cluster will come on when the brake fluid is lower than it should be. but my left brake light/tail light (dual fillament bulb) is burnt out and the fillament is touching the parking light...now i just have to wait until friday (payday) to replace the bulb and hope that that is the case.
EJ8 Squad
accord, brake, brakes, dash, gauge, hit, hondas, light, lights, make, park, parking, pressed, pushing, turn
