Weak Battery?
Old 09-25-2006, 03:45 PM
Si_chRis's Avatar
Default Weak Battery?
I was wondering if a weak battery would cause low idle? I let my car sit for 2 wks because i was away at school. I left the battery connected and it drained. But it started right up when i used jumper cables. i then drove my car around to charge the battery. It started fine and had power the next day but my idle has been low kinda around 500-600 ish. Been like that for a while. Car is a 2000 civic SI. I wouldn't think it's my altenator because it charged my battery and it had power afterwards. When i let off my throttle, my lights do dim and rpm is around 500. But i do have the radio on with my lights and fogs.
Old 09-25-2006, 04:31 PM
nsxmatt's Avatar
Default Re: Weak Battery? (EM1_ChRiS)
Could be a battery or the alternator. You need to take the battery and put it on a real charger overnight. Using the alternator to charge the battery puts too much stress on it and takes too long to try and bring it back to 100%. If the battery has a dead cell or a short it will give the impression of a bad alternator.
Charge the battery, have it tested.
Old 09-25-2006, 08:34 PM
ph0shizzle's Avatar
i dont think its ur battery or alternator. bad alternator will cause your rpm and speedometer and stereo to jump around and go crazy. a bad battery will make your car have trouble starting and have a weak crank. ithink.. i had a bad alternator and bad battery couple times and those were the effects on my car.. so yeaa correct me if im wrong.
Old 09-26-2006, 10:41 AM
Multi-paradigm
Good ol' Screwtape's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1_ChRiS &raquo;</TD></TR><TR><TD CLASS="quote">When i let off my throttle, my lights do dim and rpm is around 500. But i do have the radio on with my lights and fogs.</TD></TR></TABLE>
Your batter probably just isn't fully charged. Do you know how to use a voltmeter? You can check your battery yourself.
After your batter has been FULLY drained, you should get your battery recharged at a local shop (most places even do it for free and it takes an hour or two) as driving it around and relying on the alternator to do all the work isn't the most efficient way to charge a battery from 0% to 100%.
Old 09-26-2006, 02:39 PM
nsxmatt's Avatar
Default Re: Weak Battery? (ph0shizzle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ph0shizzle &raquo;</TD></TR><TR><TD CLASS="quote">i dont think its ur battery or alternator. bad alternator will cause your rpm and speedometer and stereo to jump around and go crazy. a bad battery will make your car have trouble starting and have a weak crank. ithink.. i had a bad alternator and bad battery couple times and those were the effects on my car.. so yeaa correct me if im wrong. </TD></TR></TABLE>
Your wrong. There are 100's of symptoms of a failing battery or alternator, I doubt you have seen them all so don't discount something because it hasn't happened to you.
Old 10-21-2006, 03:36 PM
Help we my pennies
BLUE EH3's Avatar
Default Re: Weak Battery? (nsxmatt)
What are they??
vtecnique69
11-07-2014 08:20 AM
vtecnique69
Honda Civic (2006 - 2015)
11-07-2014 08:18 AM
disposable
06-26-2008 08:02 PM
idewson
08-31-2006 11:45 AM
dog the bounty hunter
02-05-2006 11:50 AM
Quick Reply: Weak Battery?
