> Honda Civic (2001- 2005)
Old 09-21-2006, 03:42 PM   #1
Miracle
Miracle's Avatar
Send a message via AIM to Miracle
Default FAQ: What engine should I put in my EM2/ES1?
This is a question we awnser almost every day. "What swaps can I do to my civic.
Here is a picture tutorial on engines you can swap out for the unloved d17a1/2.
K20a. JDM ITR 2.0l
K20a2 USDM RSX-S
K20A3, USDM Civic Si, and RSX non-Type S.
K24, Accord, Element, CRV, TSX.
All of these engines will fit in our cars with little modification.
Parts you would need to put these engines in the EM2 ES1 chassis:
Mounts
Transmission
ECU with harnesses for respective motor
EP3 Si subframe
Intermediate shaft
EP3 Si Driveshafts
RSX Throttle cable
Shift Linkages (If using 6 speed transmission)
EP3 Si radiator and fans
RSX fuel lines
RSX Brake booster line
RSX EVAP purge lines
RSX clutch lines from master to slave cylinder
If you want to keep AC:
EP3 Si line from the compressor to the condenser
If you want to keep PS:
RSX Pressure line from the pump to the rack
Return line from the rack to the reservoir
92-95 PS Reservoir with bracket.
And if you have an automatic EM/ES, you will need:
shift linkages
shifter base
shift lever
clutch master cylinder
clutch slave cylinder
clutch cable
clutch pedal and its assembly
Anything I may have missed, correct me so I can fix it.
Modified by Miracle at 11:17 PM 11/25/2006
My 'Stang Build v. 2.6H
Miracle is offline Report Post   Reply With Quote
Old 09-21-2006, 04:04 PM   #2
Synapz
Synapz's Avatar
K20A2 is from a USDM RSX-S, not Civic Si
EvoGarage
http://www.evogarage.com
Synapz is offline Report Post   Reply With Quote
Old 09-21-2006, 06:24 PM   #3
Vantage
Vantage's Avatar
Default Re: (.Red.EM2)
K20a ( JDM RSX Type R)
Engine Specs
HP 220 @ 8000RPM
Torque 152 lb/ft @ 7000 RPM
Bore 86mm
Stroke 86mm
Comp Ratio 11.5:1
Displacement 1998cc
Specific output 110HP/L
K20a2 ( RSX-S)
Engine Specs
HP 200 @ 7400RPM
Torque 142 lb/ft @ 6000 RPM
Bore 86mm
Stroke 86mm
Comp Ratio 11:1
Displacement 1998cc
Specific output 100HP/L
K20a3 ( RSX Base / Civic Si (SiR Canada)
Engine Specs
HP 160 @ 6500RPM
Torque 152 lb/ft @ 5000 RPM
Bore 86mm
Stroke 86mm
Comp Ratio 9.8:1
Displacement 1998cc
Specific output 80HP/L
K24a1 ( CRV)
Engine Specs
HP 160 @ 6500RPM
Torque 162 lb/ft @ 3600 RPM
Comp Ratio 9.6:1
Displacement 2354cc
Specific output 67.5HP/L
K24a3 (Accord)
Engine Specs
HP 160 @ 6500RPM
Comp Ratio 9.5:1
Displacement 2354cc
k24a4 ( Element)
Engine Specs
HP 160 @ 5500RPM
Torque 161 lb/ft @ 4500 RPM
Comp Ratio 9.7:1
Displacement 2354cc
K24a2 ( TSX)
Engine Specs
HP 200 @ 6800RPM
Torque 166 lb/ft @ 4500 RPM
Comp Ratio 10.5:1
Displacement 2354cc
Specific output 83.3HP/L
K20z3 Civic Si (8thgen)
Engine Specs
HP 197 @ 7800RPM
Torque 139 lb/ft @ 6100 RPM
Bore 86mm
Stroke 86mm
Comp Ratio 11:1
Displacement 1998cc
K20z1 04,05 RSX-S
Engine Specs
HP 210 @ 7800RPM
Torque 143 lb/ft @ 7000 RPM
Bore 86mm
Stroke 86mm
Comp Ratio 11:1
Displacement 1998cc
Specific output 105HP/L
1990 Crx: Sold, 2001 Civic LX Sold, 2002 Tacoma Sold : 2006 Civic Si Current!
Vantage is offline Report Post   Reply With Quote
Old 09-21-2006, 11:23 PM   #4
civic_minded1987
civic_minded1987's Avatar
Default Re: (B18a_CRX)
hey nice postage of the specs on the engines but one thing i noticed is that you have the k20a rated at 152tq@7000rpm but according to http://www.tunerworld.com it is really 206tq@7000rpm im not trying hate on your work just want to make sure the info is correct also does anyone know about how much a k20a will crank out after adding intake, intake manifold, headers and exhaust (all performance grade of course) just wondering cuz i am planning on swappin that old hunk d17 out of my em2 if this has been asked before (which i doubt) i apologize.... if no one knows just pointing me in the right direction would be great thanks
Modified by civic_minded1987 at 1:04 AM 9/25/2006
civic_minded1987 is offline Report Post   Reply With Quote
Old 09-23-2006, 09:15 AM   #5
Curiouz_G
Curiouz_G's Avatar
youll never see a honda motor make more tq than HP at the wheels
The pleasure of a dream is that it is a fantasy. If it happens then it was never a dream to begin with.
Originally Posted by yobbr5
My buddy has a superchargered s2k, and that its rear wheel drive and it loses about 40% of its power from the drivetrain, axle, and other things.
Curiouz_G is offline Report Post   Reply With Quote
Old 09-23-2006, 02:08 PM   #6
The Lobster
The Lobster's Avatar
Send a message via AIM to The Lobster
Default Re: (Curiouz_G)
if by never you mean there are couple cars on here with turbos making more torque then horsepower then yes you are correct
DAP - 15g Greddy kit 257hp/227tq
http://www.wvmotorsports.com
UltraRare 96-00 ashtray http://www.hondamarketplace.com/showthread.phpt=2542732
The Lobster is offline Report Post   Reply With Quote
Old 09-24-2006, 02:00 PM   #7
Argale
Argale's Avatar
Send a message via AIM to Argale
one quick question. I have the d17a2, and im planning to swap it for a k20. Unfortunately my car is automatic and i want to do change it to manual. Is that a lot of work and money?
Argale is offline Report Post   Reply With Quote
Old 09-24-2006, 02:03 PM   #8
toyomatt84
Sanji
toyomatt84's Avatar
Send a message via AIM to toyomatt84
Default Re: (Argale)
Ballpark, around 1000 dollars.
*free hugs*
IA '09: Midwest Caravan (Click to join us!)
toyomatt84 is offline Report Post   Reply With Quote
Old 09-24-2006, 05:34 PM   #9
Curiouz_G
Curiouz_G's Avatar
Default Re: (The Lobster)
since this was a thread about just engine swaps, i was talking about a stock motor.
Old 09-24-2006, 05:58 PM   #10
The Lobster
the old legends had more tq then hp
Old 09-25-2006, 12:57 AM   #11
civic_minded1987
206 is not greater than 220 last time i checked but hey i could be wrong i dunno.... but does anyone have an answer to the second part of my post about total hp after mods in the k20a cuz that was what i really wanted to know
Old 09-25-2006, 01:20 AM   #12
The Lobster
droppedcrx K20a with intake and HDR/E
It made 221.8whp and 159.1tq this is at the wheel not crank so add on estimate 20% somewhere around 245-250 hp
http://www.honda-tech.com/zero...ge=37
Old 09-25-2006, 06:51 AM   #13
civic_minded1987
so i imagine it would be pretty difficult to sqeeze 300 or close to it out without boost did you replace underdrive pulley, cams, or camshaft
Old 09-25-2006, 07:18 AM   #14
fventura03
fventura03's Avatar
Send a message via AIM to fventura03
Default Re: (civic_minded1987)
wouldn't be too hard just a crapload more money, but easier with boost.
-Freddy
myspace.com/fventura03 (add me if you know me)
fventura03 is offline Report Post   Reply With Quote
Old 09-25-2006, 11:34 AM   #15
The Lobster
you could reach 300 or very close.
your forgetting he only has 2 real mods and mostly bolt ons. buy cams/ header, more tuning, maybe even bump up compression some more and im sur eyou can reach 300.
your forgetting he probably runs 12s if not faster with just 220 NA hp 160tq.
Old 09-25-2006, 01:13 PM   #16
fventura03
fventura03's Avatar
i highly doubt 220whp in an em2 will give you 12s, maybe high 13s, if that. some guy had ~500whp in his em2 (k20 turbo) and only hit 11s. em2 is heavy.
inlinepro's na ~300whp k24 frank eg hatch does 10s btw.
-Freddy
Old 03-29-2007, 07:22 PM   #17
92egSnatch
92egSnatch's Avatar
Default Re: FAQ: What engine should I put in my EM2/ES1? (Miracle)
couple of questions does anyone know any good sites to buy a jdm k20a and also any good shops to do the swap in the Ausitn/Courpus Christie TX Area and prices on the swap?
Thanks for your help
Originally Posted by Probot
AMEN http://images.honda-tech.com/set1/smile/embeer.gif - however, i say expletive chicks too..literally. Never turn down moose knuckle.
92egSnatch is offline Report Post   Reply With Quote
Old 03-29-2007, 07:45 PM   #18
Shintakun
Shintakun's Avatar
Send a message via AIM to Shintakun
Default Re: FAQ: What engine should I put in my EM2/ES1? (01D17a1)
http://www.passwordjdm.com/pro...D=134
theres your engine.
hit up Protech performance in Austin TX. off of Lamar in a street i forgot.
Shintakun is offline Report Post   Reply With Quote
Old 03-30-2007, 08:06 AM   #19
7thgencivicsdn
7thgencivicsdn's Avatar
Default Re: (Vantage)
Originally Posted by Vantage
K24a3 (Accord)
Engine Specs
HP 160 @ 6500RPM
Comp Ratio 9.5:1
Displacement 2354cc
Are these the engine specs for an 2006 accord V6, if not what are engine specs? Also can you use the block from an the V6 accord?
7thgencivicsdn is offline Report Post   Reply With Quote
Old 03-31-2007, 05:46 AM   #20
toyomatt84
Sanji
toyomatt84's Avatar
Default Re: (7thgencivicsdn)
There are no kits out there, to mount a V6 (of any kind) in the 7th gen. Civic. So, you're not going to be able to use it.
Originally Posted by wikipedia
K24A3
* Found in:
o 2003-2006 Honda Accord (Europe, Japan, and Australia)
+ Displacement: 2354 cc
+ Bore and Stroke: 87 mm x 99 mm (3.43x3.90 inches)
+ Compression: 10.5:1
+ Power: 189 hp (140 kW) @ 6800 rpm
+ Torque: 164.5 ft·lbf (223 N·m) @ 4500 rpm
+ Redline: 7000 rpm
*free hugs*
Old 03-31-2007, 12:33 PM   #21
JamesL
JamesL's Avatar
Default Re: (fventura03)
I'd really take the driver into account when considering these times. The EM2s are a bit porky compared to earlier model Hondas, but weight less than both the RSXs and EP3s... Comparing them to eg hatches with that much torque is hardly fair
JamesL is offline Report Post   Reply With Quote
Old 03-31-2007, 05:40 PM   #22
OG SHG_EM1
OG SHG_EM1's Avatar
Send a message via AIM to OG SHG_EM1
Default Re: (JamesL)
ummm legend type II motor...200HP 205/Tq...learn the facts before u start talkin shit
07' GGM Civic Si 4DR
EK-EG2-EM1-EM1-FA5
SoHondaGarage
SNOWBOARD FOR SALE
OG SHG_EM1 is offline Report Post   Reply With Quote
Old 03-31-2007, 06:14 PM   #23
Curiouz_G
Curiouz_G's Avatar
humm, 5tq. amazing. oh im sorry SHG_EM1. you must know EVERYTHING about honda motors. big deal. just because i left out ONE motor means i spout useless shit? gtfo and take your little e-penis with you
Old 03-31-2007, 10:23 PM   #24
sujak
Banned
You can also use the k20z1 out of the 05-06 rsx-s but to use k-pro you require the 02-04 PRB ECU sent ot hondata for the kpro and adapter harness, and you'll have problems with the cluster getting the speed.
sujak is offline Report Post   Reply With Quote
Old 04-11-2007, 08:44 PM   #25
92egSnatch
92egSnatch's Avatar
any1 no anything about osakajdmmotors.com
Bookmarks
01, civic, exhaust, hp160, k20, k20a2, k20a3, k20z1, motor, needed, part, put, swap, system, tutorial
