Last edit by: IB Advertising
- Honda: How to paint your engine cover
Step by step instructions for do-it-yourself repairs.
DIY: Step-by-step how to paint your valve cover
#29
Re: DIY: Step-by-step how to paint your valve cover (weaksauce.org)
Nicely done. one question though, would it be possible to put painted wheels in your oven so that they wont chip? Just a thought.
#33
ohhh makes a lot of sense, another question do u need high heat paint to paint the VC?? cuz the homie wants to paint hers pink but they dont have high heat pink paint
#34
Because valve covers get REALLY hot. Just get it powdercoated. Itll run her like $40 and the finish will probably outlast the car.
#36
1 Post
Can't help but ask.. But would Duplicolor Metalcast hold up on VC? Obviously I won't be able to heat treat it. Just wondering if anyone has ever used this one before. And also, what do you wetsand with between the paint and the clearcoat? 1500?
http://www.jegs.com/i/Duplicolor/318...oductId=763208
#39
i go to this Automotive Academy through my high school and my teacher told me it wasnt a good idea because of some chamber thats under the valve cover and sand will get stuck in there and end up in the engine. this was a valve cover for a d16y6 that i showed him
#43
The letters do get painted... You just have to sand them down little by little. Start from 80 grit then use 120, then 320. The trick is to make sure that the paint is fully dry and cured so that it would be easy to sand em down! goodluck!
adamisgreat88
17
06-08-2009 02:52 PM
