Old 09-05-2006, 09:44 PM   #1
som3on3_10
som3on3_10's Avatar
Default Car jerks while I'm at a stop light...why?
OK, car is a 95 Integra LS automatic. When I'm at a stop light, with my foot on the brakes, the car jerks as if I'm giving it gas, then lets off. Has this happened to anybody? It does this too when I'm driving at low rpms. I am clueless as to what this could be...electrical, tranny, etc. I have no check engine light either. Any help would be deeply appreciated. Thanks!
som3on3_10 is offline   Reply With Quote
Old 09-05-2006, 11:02 PM   #2
Mr. green.
Mr. green.'s Avatar
Default Re: Car jerks while I'm at a stop light...why? (som3on3_10)
sounds like a tranny issue to me, check/change the fluid see if you find any metal shavings... maybe get it power flushed.
LNC#003
[quote=L33T]I'm offering you ten ******* dollars to change your HT name forever![/quote]
[quote=DoraThaMuthaF*ckinExplora]H-T as my witness, and I solemnly sware it will never go back.[/quote]
Mr. green. is offline   Reply With Quote
Old 09-06-2006, 07:59 PM   #3
som3on3_10
som3on3_10's Avatar
What's a power flush?
Old 09-06-2006, 09:21 PM   #4
Jay J
Prince of Zamunda
1999 Lexus GS
My Garage
Jay J's Avatar
Send a message via AIM to Jay J
Default Re: (som3on3_10)
Run the transmission fluid in and out of the transmission(one hose to drain, one to fill, and it'll run itself through. Try seafoam transmission flush then change the fluid in 100 miles Click the image to open in full size.
Toyota Aristo
Evolution VIII
If you need a car detailed in SoCal Let me know
Jay J is offline   Reply With Quote
Old 09-06-2006, 09:29 PM   #5
madrrio
madrrio's Avatar
madrrio hidguy
Send a message via AIM to madrrio
sounds like u got oil on the tranny, causing it to slip instead of hold, hence jerkin here and there.
madrrio is offline   Reply With Quote
Old 09-06-2006, 09:46 PM   #6
4d96gsr
4d96gsr's Avatar
Fernie gutierrez
Default Re: (madrrio)
change the dang sinaloid(dont know if i spelled right???)
4d96gsr is offline   Reply With Quote
Old 09-06-2006, 11:20 PM   #7
SoTexDC2
SoTexDC2's Avatar
Send a message via AIM to SoTexDC2
Does the jerking happen during constant idle? or only during erritac idle & acceleration? Your engine mounts could be severly worn.
̿' ̿'\̵͇̿̿\з=(̪●)=ε/̵͇̿̿/'̿'̿ ̿
SoTexDC2 is offline   Reply With Quote
Old 09-06-2006, 11:30 PM   #8
XYU
Ask me about vaginal warts
most of us here have 5 speed manual transmission and usually dont know **** about auto..... on your place i wouldnt worry about it, any way it s something with tranny and if it will die, its very easy and cheap to replace. good luck!
[B]JDM INTEGRA TYPE R FRONT END FOR SALE[/B]
With HID -- $1500
NON-HID -- $1300
98+ INTEGRA Tail Lights ALL RED -- $150
94+ INTEGRA POWER Side Mirrors - $80
XYU is offline   Reply With Quote
Old 09-07-2006, 10:36 PM   #9
som3on3_10
som3on3_10's Avatar
Default Re: Car jerks while I'm at a stop light...why? (SoTexDC2)
Yes it happens during constant idle and at low rpms when I'm driving. I will look into power flushing the tranny this weekend and see if that fixes it. Click the image to open in full size.
Old 09-08-2006, 01:22 AM   #10
SoTexDC2
SoTexDC2's Avatar
Okay, then the problem is probably within your tranny as everyone else said. My lower mounts were all worn & my car would jerk, but only during acceleration or tapping the pedal. Good luck!
Old 01-29-2013, 05:11 AM   #11
keykey25
Would changing the filter and putting new tranny fluid in help? I have the same issue with my lumina
keykey25 is offline   Reply With Quote
Old 01-30-2013, 01:18 PM   #12
Solster
1991 Acura Integra
Solster's Avatar
THERE is no filter in a honda trany you can change. you have to rebiuld the trany to do it.
also it sounds more like the torque converter lock up is failing it's not uncommon for this to happen in automatic cars.
when you stop the force the the fluid in the torque converter drops and releases the the converter lock-up allowing the engine to turn freely as long as there is no force on the lock-up (mostly if it stuck in a gear from a failed solinoid)
if the shift solinoid was bad it would ether not go into a gear OR would not come out of a gear.
so if it's BAD and not going into gear you would see say 1st no 2nd then 3rd then 4th Or 1st 2nd NO 3rd then 4th
so from 0~17mph is 1st 18~28 is 2nd 29~38 is 3rd 39 and up is 4th
if it's bad and not going OUT of gear weather it's 3rd or 2nd the engine will stall and die when you come to a stop.
this is from the solinoid getting hot and seizing to the pintle shaft allowing the ATF to flow through and locking the gear in.
91 Integra B18C1 GS-R Swap
And as always. Help make the roads a Safer place. Have your Local backyard Mechanic Spayed or neutered.
Solster is offline   Reply With Quote
brake, car, civic, engine, foot, honda, idle, jerks, jumps, light, lights, prelude, red, slight, stoplights
Similar Threads
Motor jerks intermittently when idling jdm91integ Honda Accord (1990 - 2002) 16 06-27-2014 03:00 PM
Car jerking and shuting off jasmin92993 Honda Civic/Del Sol (1992 - 2000) 8 03-17-2014 04:19 PM
Car jerking RickyRT711 Honda Civic/Del Sol (1992 - 2000) 4 03-18-2013 03:44 PM
Car jerking when holding accelerator steady! rufeooo85 Acura Integra 15 02-27-2013 06:32 AM
car jerks the king. Honda Accord (1990 - 2002) 26 02-12-2013 10:30 PM
