Go Back   Honda-Tech > Honda and Acura Technical Forums > All Motor/ Naturally Aspirated
Old 08-06-2006, 06:26 PM   #1
inh
inh's Avatar
Default over revved my engine, now i think i have rod knock
car: 88 crx si with d16a6 and chipped p28 with a phearable.net chip
i dont have time to pull the pan or anything, i leave for 3 weeks in about 5hours.. but heres what happened
upgraded to obd1 last night. got the car running fine. drove a few miles on the highway, tested out the higher redline. revved the car to aboru 7300 rpm, then shifted.. no problems. pulled the plugs, they looked fine. on the drive home.. it got bad. loud *** noise, let off the gas and the engine just dies... would struggle to start and then idle like ****. rev it up and let off the gas and it would die.
its a loud knocking sound, but it sounds more like its coming from the head than lower in the block.
compression test: 165 150 165 175
pulled plugs one at a time, no change in sound.
any ideas?
inh is offline   Reply With Quote
Old 08-06-2006, 06:28 PM   #2
hybridmiklo
hybridmiklo's Avatar
Default Re: over revved my engine, now i think i have rod knock (inh)
bent valves?
hybridmiklo is offline   Reply With Quote
Old 08-06-2006, 06:38 PM   #3
inh
inh's Avatar
shouldnt be with compression readings like that
Old 08-06-2006, 07:13 PM   #4
inh
inh's Avatar
130k miles
cant pull pan, dont have the time, i leave in 5 hours and its dark out Click the image to open in full size.
just trying to narrow it down before i leave
Old 08-07-2006, 07:30 AM   #5
d16dcoe45
d16dcoe45's Avatar
Default Re: (inh)
stock d16a6 (unless the springs were REALLY old) shouldn't start floating valves until like 8800 rpm---valves are so small and light.
[B]Cusco EF master cylinder brace[/B]-- brand new, unopened, still in package [B]$75 shipped[/B] obo (RHD ONLY!!!)
[B]WTB:[/B] 88-89 Civic hatch driver side door w/ glass and regulator.
Losi xxx4 G+
Associated Rc10 t4 FT
Losi xxx BK2
JConcepts BJ4 WE
d16dcoe45 is offline   Reply With Quote
bent, dies, element, engine, gas, h22, honda, knock, knocking, overrevved, revved, rod, s2000, stock, valves
