LS/VTEC problems HELP
Old 06-13-2007, 11:31 AM
B Series JuNky's Avatar
Default LS/VTEC problems HELP
i have a 90 DA with an ls/vtec p30 pistons pr3 head gsr cam shaft ..everytime i start my car up it stays on idle but when the temp goes up my RPM's rev up and down and it will turn off ? it only does it when the temp goes and warms up not when its cold i dont have overheating problems or nothing no check engine none of that **** its just that ?
another problem its not hitting VTEC ?
Modified by B Series JuNky at 5:15 PM 6/13/2007
Modified by B Series JuNky at 5:25 PM 6/13/2007
Modified by B Series JuNky at 12:18 PM 6/14/2007
Modified by B Series JuNky at 12:19 PM 6/14/2007
Old 06-13-2007, 12:59 PM
KoalaEatingTree's Avatar
Default Re: LS/VTEC problems HELP (B Series JuNky)
It's normal for the car to idle higher when it first starts up. Upon initial startup is it idling really really high? Play around with your idle adj screw...
Old 06-13-2007, 01:05 PM
CompanyFlow's Avatar
I have an idea: read a book.
Old 06-13-2007, 01:08 PM
* B A N N E D *
St Jimmy's Avatar
Default Re: LS/VTEC problems HELP (CompanyFlow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CompanyFlow &raquo;</TD></TR><TR><TD CLASS="quote">I have an idea: read a book.</TD></TR></TABLE>
Your grammer is that of a 5th graders.
Old 06-13-2007, 04:11 PM
Default Re: LS/VTEC problems HELP (St Jimmy)
when my temp is at the middel my RPM just go up and down like i have stage 3 cams or somthing
Old 06-13-2007, 04:12 PM
i have an idea to F*CK YOU
Old 06-13-2007, 04:46 PM
integgyboi87's Avatar
whats up ur problems sound like my friends when we did a motor swap in an integra it kept idling up n down when it warmed up check intake manifold thats what was wrong with his if u got time check out the topic i posted n see if u can tell me something its the topic bout the 89 integra
Old 06-13-2007, 05:28 PM
Thats what I expect from someone who lives in the methamphetamine capital of the world.
Old 06-13-2007, 09:47 PM
Default Re: LS/VTEC problems HELP (integgyboi87)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integgyboi87 &raquo;</TD></TR><TR><TD CLASS="quote">whats up ur problems sound like my friends when we did a motor swap in an integra it kept idling up n down when it warmed up check intake manifold thats what was wrong with his if u got time check out the topic i posted n see if u can tell me something its the topic bout the 89 integra</TD></TR></TABLE>
alright cool thanks i'll check that out should i just look for air leak or somthing on the manifold ?
Old 06-14-2007, 08:53 AM
any other idea's
Old 06-14-2007, 10:20 AM
* B A N N E D *
St Jimmy's Avatar
If your idle is jumping up and down 9 times out of 10 its a vacuum leak or a dirty iacv, clean that, check for leaks and you will probably find your problem.
Old 06-14-2007, 10:27 AM
91redteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by St Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">If your idle is jumping up and down 9 times out of 10 its a vacuum leak or a dirty iacv, clean that, check for leaks and you will probably find your problem.</TD></TR></TABLE>
yeah probly a vacuum leak on the idle sensor if u still have the stock intake manifold it has a little idle sensor. its attached to the throttle cable and throttle body.
Old 06-14-2007, 10:58 AM
okay i'll check that so thats why my car just shuts off when it warms up ?
Default Re: LS/VTEC problems HELP (91redteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91redteg &raquo;</TD></TR><TR><TD CLASS="quote">
yeah probly a vacuum leak on the idle sensor if u still have the stock intake manifold it has a little idle sensor. its attached to the throttle cable and throttle body.</TD></TR></TABLE>
i dont have the stock manifold i have an ITR
Old 06-14-2007, 11:05 AM
Dc2alldawaY's Avatar
if you know anyone that has a smoke machine, try plugging it up, it will show you exasctly where your vaccum leak is, if indeed you have one. otherwise check your iacv.
Old 06-14-2007, 11:12 AM
Default Re: LS/VTEC problems HELP (Dc2alldawaY)
is there a type of cleaner i can buy for my IACV that u guys know about or how do u guys do it ?
Old 06-14-2007, 11:15 AM
* B A N N E D *
St Jimmy's Avatar
brake cleaner
Old 06-14-2007, 11:18 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by St Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">brake cleaner </TD></TR></TABLE>
forsure thanks jimmy
Old 06-14-2007, 11:36 AM
i think i figured urs out i worked on mine all day cleaning the intake with some cleaner put it all back to gether n it was idling up n down when it warmed up at bout 1000-1500rpms i pulled my main fuse thats on my battery to reset the (programed feul injection) hit me back if u got a chance take a look at what i posted about my 89 integra with a b16
Old 06-14-2007, 02:12 PM
can u post the link for that ..my car doesnt idle high it idle's low and then just turns off ?
Old 06-14-2007, 03:07 PM
Old 06-14-2007, 09:35 PM
anyone else ?
Old 06-14-2007, 09:46 PM
96teggylsse's Avatar
get a helms
Old 06-15-2007, 08:08 AM
Default Re: LS/VTEC problems HELP (96teggylsse)
anyone got any idea's ?
Old 06-15-2007, 08:17 AM
Have you tried any of the suggestions?
Idle screw? Brake cleaner to clean out IACV? Feel for leaks/fog machine for leaks on vacuum hoses? Reset ECU? Timing?
More time under the hood &gt; more time on the internet
Quick Reply: LS/VTEC problems HELP
