Old 08-04-2006, 01:24 PM   #1
Tech-Nics
Tech-Nics's Avatar
Send a message via ICQ to Tech-Nics Send a message via AIM to Tech-Nics
Default Need Help...Locating Transmission Drain Plug!?!?
can some one please post a picture of where the transmission drain plug is?
or atleast explain where its located...im going to do a drain and refill...
thank you...
1997 Honda Accord LX Coupe (SiR)-(JDM-CD7/CD8) -(((F22))) = Infinity
-(((A&S)))- est. 10/16/04
CD Squad Member #158
[url="http://www.passwordjdm.com"]http://www.passwordjdm.com[/url]
[url="http://www.tasauto.com"]http://www.tasauto.com[/url]
Tech-Nics is offline   Reply With Quote
Old 08-04-2006, 01:55 PM   #2
businessmanph
businessmanph's Avatar
Send a message via AIM to businessmanph
Default Re: Need Help...Locating Transmission Drain Plug!?!? (Tech-Nics)
it's near the front passenger tire
get a 3/8th ratchet
and stick it into the square shaped bolt
97 accord ex 4 cyl, auto with 110k.
stock
01 prelude sh 27k
aem cai w/bypass valve, vafc2 tuned, mugen suspension, neuspeed swaybar, e46 hid, window module, spoon thermostat, pretty much stock
businessmanph is offline   Reply With Quote
Old 08-04-2006, 04:54 PM   #3
sony224422
sony224422's Avatar
Default Re: Need Help...Locating Transmission Drain Plug!?!? (businessmanph)
its in there pretty tight too.. make sure you use a big rachet
96 accord lx- converted into 5spd ex http://is.rely.net/1-92-29998-l-1gbM...AmVuBW3hGg.gif
93 civic CX (project car)- Sold
1997 dodge ram 1500 sport 4x4 extended cab
360 magnum
sony224422 is offline   Reply With Quote
Old 08-04-2006, 07:27 PM   #4
JimBlake
JimBlake's Avatar
Auto or manual tranny? V-6 or 4-cyl? It matters.
JimBlake
'03 Accord & '07 Civic
'01 Saab 9 & '05 9x
TECHNICAL(?) quote...
Originally Posted by ??
some guy told me that I could set the torque wrench that I have to 100 ft/lbs and then torque it, when it clicks torque it again at 81/ft lbs to have the torque add up to 181 ft/lbs
JimBlake is offline   Reply With Quote
Old 08-04-2006, 08:24 PM   #5
Tech-Nics
Tech-Nics's Avatar
auto/4-cyl
Old 08-04-2006, 10:16 PM   #6
MestizoRacer310
MestizoRacer310's Avatar
Send a message via AIM to MestizoRacer310
Default Re: (Tech-Nics)
Passenger side like businessmanph said. Make sure to use a long handled ratchet...
Kevin; AIM: MestizoRacer310
UA5: Tein|Rota|Racingbrake|Cusco|Eibach||CG6: H&R|TYC
Vouches: Crashtest Sonny, SiPower99, Blackstar, blackdc5
MestizoRacer310 is offline   Reply With Quote
Old 08-05-2006, 01:24 AM   #7
iam7head
iam7head's Avatar
Default Re: (MestizoRacer310)
bad idea actually, most people use a long rachet and turn it slowly, because the metal to metal contact it's easy to stripe the bolt that way.
use a regular size handle and give it a quick blow, one good yank will break it loose
Honda s2000 Ap1 00' Silverstone(153lb-ft of torqueless wonders)
Mazda Miata Mx-5 90' BMWjetblack(116hp of ball-less fury)
iam7head is offline   Reply With Quote
Old 08-05-2006, 07:05 PM   #8
MestizoRacer310
Default Re: (iam7head)
What metal to metal contact are you talking about? Not trying to sound dumb or nothing but I don't see what you're speaking of...
Old 08-06-2006, 06:38 AM   #9
Tech-Nics
Tech-Nics's Avatar
well...the drain and refill was a complete success...thanks to you guys for helping me out...the lug came out with one great big jolt...i used the regular size ratchet. came out like a champ. looks like the person who owned the car before me had atleast 6 1/2 quarts of tranny fluid in before....but now i drained all that crap out and filled it with 4 quarts of Honda ATF...car runs alot better and shifts silky smooth....
thanks again to all that helped me...
Old 08-06-2006, 06:30 PM   #10
thatasiankidtony
thatasiankidtony's Avatar
I used another ATF brand, do you guys think that can be a reason it's shifting hard?
thatasiankidtony is offline   Reply With Quote
Old 08-06-2006, 06:33 PM   #11
JimBlake
JimBlake's Avatar
Originally Posted by Tech-Nics
... looks like the person who owned the car before me had atleast 6 1/2 quarts of tranny fluid in before....but now i drained all that crap out and filled it with 4 quarts of Honda ATF...car runs alot better and shifts silky smooth....
Fill whatever amount makes the correct level on the dipstick. (Car warmed up, shift into park, turn OFF the engine.) Don't simply go by quarts. The tranny & torque converter have something like 7 or 8 quarts in there, but only 1/3 or 1/2 of it can drain out.
JimBlake
'01 Saab 9 & '05 9x
2006, 90, 93, accord, drain, f22b, honda, location, lx, picture, plug, prelude, sh, tranmission, transmission
