Steering Wheel Removal. 2000 Accord SE.
Anybody Know how to remove the steering wheel? couldnt find the topic about this so i just started new Topic's. Want to install a quick release but not really sure how to remove the steering wheel. Any help will be appreciated, Thanks.
Re: Steering Wheel Removal. 2000 Accord SE. (garaged_Si)
1. Make sure to park the car with wheels straight.
2. Disconnect negative battery cable, and then positive cable.
3. Remove access plate from bottom of steering wheel. Unplug the yellow 2-pin connector.
4. Remove the access panels from each side of the steering wheel, then remove the torx bolts. Pull off the airbag module and set it in a safe place.
5. Unplug the connectors for the cruise control and horn.
6. Remove the steering wheel bolt. Remove the steering wheel using a steering wheel puller.
ek9tl
02-22-2007 10:34 AM
