Old 07-26-2006, 05:35 AM   #1
Danziver
Danziver's Avatar
Default What could cause a distributor to go bad?
I have bought 2 new distributors and so far each one has only last me about 2 months. Im on my 3rd one and its starting to act up too. It is starting to give me hard starts and it killed on me this morning. Anyone have this problem?
Thanks
Danziver is offline   Reply With Quote
Old 07-26-2006, 05:46 AM   #2
motoman
motoman's Avatar
Default Re: What could cause a distributor to go bad? (Danziver)
I have had distributors die from having bad grounds.
motoman is offline   Reply With Quote
Old 07-26-2006, 05:46 AM   #3
Danziver
Danziver's Avatar
Default Re: What could cause a distributor to go bad? (motoman)
Where are the grounds you speak of?
Old 07-26-2006, 06:01 AM   #4
crx_88_si
crx_88_si's Avatar
thermostat ground.
are these 100% new, or used? did u reuse the coil? ignitor? cap ?
Vouche: Jay-C
My Car: [url="http://www.cardomain.com/id/crx88si"]http://www.cardomain.com/id/crx88si[/url]
crx_88_si is offline   Reply With Quote
Old 07-26-2006, 06:07 AM   #5
Danziver
Danziver's Avatar
Default Re: What could cause a distributor to go bad? (crx_88_si)
Its re-built from advance auto parts and its my 2nd one from them. Cap, rotor, ect are all new.
Im gonna check my grounds, any more info would be appreciated.
Old 07-26-2006, 06:13 AM   #6
Danziver
Danziver's Avatar
Called my local mechanic and he said he couldnt see any reason for them to just die like that, other than the fact that its a cheap rebuild. Click the image to open in full size. Im gonna try to replace my grounds today. Anyone have any experience with this weird problem?
Old 07-26-2006, 10:37 AM   #7
Danziver
Danziver's Avatar
Just added some new ground wires. Anymore ideas?
Old 08-17-2006, 05:06 PM   #8
Danziver
Danziver's Avatar
Up
Old 08-17-2006, 05:35 PM   #9
erikiksaz1
erikiksaz1's Avatar
Maybe try distributorking? I've used two for a period of about six months and so far, so good. Let's hope Click the image to open in full size.
erikiksaz1 is offline   Reply With Quote
Old 08-17-2006, 05:46 PM   #10
wrx-killer-Sti-eater
1994 Acura Integra
wrx-killer-Sti-eater's Avatar
Location: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
iTrader Rating: (1)
dmcnasty1
Send a message via AIM to wrx-killer-Sti-eater Send a message via Yahoo to wrx-killer-Sti-eater
Default Re: What could cause a distributor to go bad? (erikiksaz1)
is there oil pooling in the spark plug sockets?
www.precisionmobilesoundwerks.com 562-271-8841 Import life performance
If they want it they will get it-Most untrue saying ever http://www.honda-tech.com/showthread...1#post38708541
wrx-killer-Sti-eater is offline   Reply With Quote
Old 08-18-2006, 12:18 AM   #11
tyco
tyco's Avatar
Send a message via AIM to tyco
Had the same problem before, check spark plugs if oil is pooling in, also check to see if the bolts are tight on the distributor, it happen to me and started acting up Click the image to open in full size.
Representin' Long Beach 562
tyco is offline   Reply With Quote
Old 03-22-2011, 09:46 AM   #12
koreachangsu
koreachangsu's Avatar
Hey I know this I. An old thread. Oil is in my spark plug sockets. I have no spark I went through 2 dizzy's.my question about this thread is what if oil is on the plugs or in the cylinder of the wire plug. Won't your car just start but sound shitty.
94 ex 4 DR H22a Accord................is it worth it hell yeah!!!!!!!!!
93 h22 prelude turbo now thats worth it......
koreachangsu is offline   Reply With Quote
Old 03-22-2011, 11:28 AM   #13
djkobe
1990 Acura Integra
Jake Griffin
i cant speak for anyone else but when i bought my 90 DA it needed plug gaskets and always had oil soaking the the plugs and wires. which in turn ruined the wires and caused them to slip of the plug and kill the car or would have a loose connection and would starve the electrical power to make it bog but it hasn't seemed to hurt my distributor. so that may be a slight part of your problem but i dont see how it would kill your dizzy. have you checked all of your wires that run to the dizzy plug to make sure that none of them are shorting out?
djkobe is offline   Reply With Quote
bad, car, cause, distibutor, distributor, distributors, honda, hondas, integra, makes, months, plugs, problems, reason, spark
