| Welcome to Honda-Tech! | ||
#1 |
| Garage is empty, add now |
have the honda shop manual on my computer and the chilton at home but i cant find where it tells you how to replace the wheel bearing. does anyone knows the page? or any help would be great
thanks Modified by roterx7 at 5:18 PM 7/25/2006 |
#2 |
Back or front?
For the back remove the dust shield for the nut. Then remove said nut and remove hub/bearing. If they are rear disks you will need to remove the caliper and rotor. For the front remove the knuckle from the car including removing the brakes. Then press out the hub, remove the snap ring and press out the bearing. Installation is the reverse of removal. |
#3 |
Check out this link http://honda-tech.com/zerothread?id=720159&page=1
I used this as refrence for my wife's 02 Altima. Sad part is I have to redo it, hub bearing I put in is humming now and it's brand new? but I know how to do it so no worries. Also, it helps that I have a 20 ton shop press. Good luck! JG |
#4 |
front wheel bearing
i dont have access to a shop press. can it be done with out one? |
#5 |
Moderator
http://www.honda-tech.com/zerothread/1508680 you might find something here
I know it has been done before. I would suggest taking your knuckles off and walking them into a shop to do them. That is what I did one time, and the guy that pressed them is now one of my good friends crazy how things workout.
Hondworks Need a write up on how to fix your CRX cracked climate control, PM me 1990-1993 Accords parting out 1991 CRX HF parting out PM me for any parts EG Sedan Tail Lights $60 shipped |
#6 | |
take the knuckle to a shop and have them press it in and out. most shops will have a press, not all are willing, but keep asking around, someones going to help you out for a modest fee. the first link is great. its also very detailed in the helms manual.
Don't IM me your TECHNICAL question. Start a thread, I'll answer there. FS: Mugen CF-48 13x5.5 -38 Wheels *NIB* FS: 4040 Brake Proportioning Valves |
#7 |
yes, you need a slide hammer, and then you press it back it on with the axl nut.
#8 | |
be professional
All you need to pull the hub is a slide hammer. It's easy. Then you press it back on with an axle nut.
1996 Accord | 1998 CB750 | 2001 Integra | 2012 Giant Anthem X29 |
#9 |
just remove the knuckle and bring it to a machine shop to get pressed out/in. And you might as well get a new lower balljoint put in while the knuckle is out.
ps3 screen name thread http://www.honda-tech.com/showthread.php?t=1818477 ps3= Robert_Paulson |
#10 |
Have any of you actually done the slide hammer approach? It works and I can get my hubs off in less than 2 min, but also the wheel bearings I am putting back on is the whole hub assembly not jsut the bearing......
#11 |
i dont even have a slide hammer, can someone show me what it looks like? i might have to go buy one or borrow one form somebody
thanks |
#12 |
sorry need to bump this but i have a crx fsm but it doesnt say anything on how to take out the hub/knuckle from the car.
my front left bearing is screwed. anywhere or anyone has the removal diagram so i can pull it out and send it to a shop? need to get this done cause sears is telin me they cant do an alignment on the car with this part being bad. thanks a lot
People I've bought from: Snail EG, egb18turbo, CiViC KiD, jonyb, Knigtnam, Shongku, HONDA-2NR, Shocka1998LX, ian, Surfer_Sandman, Duece, cycocivic, kadburry, 3 3 3, XX Boosted Si XX, IntegraXTR, Hybrid Performance, delsolcutie, crank, sporkcrx, slowhatch92, hybrid89, sauceja, b20vrex, SOHCejcivic http://images.honda-tech.com/set1/smile/emthup.gif Sold to : Integra N Civic, KND, ff_terror, Chester Rumble, That4drGSR, Mr. B in Az http://images.honda-tech.com/set1/smile/emthup.gif |
#13 |
Don't really have a diagram but here it goes.
1. break axle nut loose 2. Remove wheel 3. romove brakes, including rotor 4. disconect lower ball joint from lower arm 5. remove axle from hub 6. disconnect tie rod from knucke 7. disconnect upper ball joint. should be done then. if you're taking in in somewhere to have a new bearing pressed in you might as well have them press in a new balljoint too. my order of things above may be a little fucked up, but that is everything that needs to be done.
#14 |
err ok man thanks for the help but i am still a bit confused. do u know of an fsm or any manual that shows how to do it?
#15 | |
be professional
Buy the real Honda FSM: http://www.helminc.com/helm/pr...61RV6
#16 | |
The question is do I need any special attachments or additional things to help me get the hub/wheel bearing out? I mean I'm obviously going to need something but how do the pros do it? Attachements that fit the bearings properly or improvise something else? Sorry for the noob question here... just trying to learn as I go. i'm not too concerned with getting everything apart... but once I've got my knuckle sitting on my bench, whats next--- is whats confusing a bit lol... got the press... gotta figure out how to use it right! thanks in advance for the help and sorry for bumping an old thread...
1993 Honda Prelude VTEC - Weekend Project 2011 Mustang 5.0 GT - Daily Driver |
#17 | |
1991 Honda CRX |
id would just use a socket thats as clost to the size of the bearing as i can get and make sure when you set up to press you are not going to break any part of your knuckle(watch how its supported) i have never heard of tools for a press i think everyone uses what works and fits and is safe again id use a socket prob a deep socket and deff use an impact socket not a cheap-o
91 Crx B18c1(gsr) swap WTB FOR MY REX^: BRAKES (PADS ROTORS ECT) REAR WHEEL BEARING ANY AND ALL FRONT SUSPENSION AND STEERING PARTS/BUSHINGS PM ME WITH WHAT U GOT! |
#18 |
Please check out the recall for the front wheel bearing, you may be able to get this done for free.
http://www.lemonauto.com/complaints/...onda_civic.htm |
#19 | |
#20 | |
http://www.honda-tech.com/showthread...=wheel+bearing
IT IS WHAT IT IS |
#21 | |
you guys are bumpasaur's bumping these Dino posts.
#22 |
2000 Acura IntegraMy Garage |
i took my knuckle off and got it pressed at a local shop...took me a few tries walkin into random shops but i found on that would do it for a good price
#23 |
I'm having my 2005 CR-V's rear passenger bearing replaced (didn't attempt it myself but sounds like I could have) and just got a call that they will have to 'break' my ABS sensor to accomplish it. Is this true or am I being taken for a ride?
#24 |
this thread rocks....thanks honda tech....just gotta put everything back in....xmas list; 12-20 shop press from harbor freight
#25 |
TeamXenocron |
| Tags |
| 1992, 2001, 98, axle, bearing, civic, diagram, front, honda, nut, removal, remove, repair, replace, s2000, wheel |
