> Honda Civic (2001- 2005)
Old 07-30-2006, 01:19 AM   #26
CwestGurl
CwestGurl's Avatar
Wow scary I actually understood what you wrote. I learned something new today.
Laugh All U Want My Kit Is Jdm Man Holla
CwestGurl is offline Report Post   Reply With Quote
Old 07-30-2006, 02:22 AM   #27
Miracle
Miracle's Avatar
Send a message via AIM to Miracle
Default Re: (CwestGurl)
See, thats what I am going for right there.
I appreciate that.
My 'Stang Build v. 2.6H
Miracle is offline Report Post   Reply With Quote
Old 08-04-2006, 12:52 PM   #28
Miracle
Miracle's Avatar
Default Re: (Red_EM2)
Here are a couple videos on the sound of VTEC engagement...
1998 CW ITR:
http://videos.streetfire.net/s...6.htm
N/A LS/VTEC B18:
S2000:
http://videos.streetfire.net/s...8.htm
Modified by .Red.EM2 at 4:45 AM 9/20/2006
Old 08-11-2006, 08:33 AM   #29
iwantspeed
iwantspeed's Avatar
Send a message via AIM to iwantspeed
when i bought my car it had a vtec light installed... i dont know where the wires connect to but it works... most of the time it comes on at around 3300 rpms.
88 crx hf 1.8l vtec.jdm front. and jdm tail lights.soon to be 500whp
full chromolly 10 pc. cage. fresh paint.my shits a go kart SON!. GFI built.
iwantspeed is offline Report Post   Reply With Quote
Old 08-13-2006, 04:27 PM   #30
Miracle
Miracle's Avatar
Default Re: (iwantspeed)
Here are a couple more illustrations of a VTEC valvetrain...
The rocker assembly, the VTEC rocker colored in yellow, and the low RPM rockers in red and blue. Note the locking pin assembly in 2 pieces:
An original Honda illustration, showing how the pin inside the rockers slides over with oil pressure, locking the 3 rockers together...
Old 08-14-2006, 03:02 PM   #31
Metalluthier
Metalluthier's Avatar
Send a message via AIM to Metalluthier
Default Re: This, is VTEC explained. (Red_EM2)
Originally Posted by Red_EM2
UPDATED 8-2-06
In a SOHC VTEC motor, the camshaft sits centered in the head, so both of the intake and exhaust valves are engaged on the same camshaft.
There are 3 camshaft lobes on a VTEC camshaft. The three cam lobes in the middle are the intake cam lobes. The two low RPM (the shorter of the 2 profiles) lobes actuate two valve rockers, which in turn pushes the intake valves open.
Actually, the way the spark plug is located on SOHC VTEC engines, it is impossible for VTEC to work for the exhaust valves
DJ AnalogDuck (various artists - mix) - Eastern Duck Heads West (2001) - 05 - Eastern Duck Heads West05.mp3 [192Kbps] (05:54)
-1995 EJ1 JDM B16A SiR II SOLD 01/08/08 Miss you!
-2003 RSX Type S
Metalluthier is offline Report Post   Reply With Quote
Old 08-14-2006, 03:07 PM   #32
Miracle
Miracle's Avatar
Default Re: This, is VTEC explained. (Metalluthier)
I think you misuderstood.
I didn't say that VTEC operated both the intake and exhaust valves, but rater that the cam sat centered in the head, and that IT operated both intake and exhaust valves under normal operation.
Old 08-17-2006, 07:30 AM   #33
myst
wow
myst is offline Report Post   Reply With Quote
Old 09-05-2006, 08:06 AM   #34
Phil McConkey
B A N N E D
Default Re: (myst)
The title made me laugh for some reason, lol.
Phil McConkey is offline Report Post   Reply With Quote
Old 09-05-2006, 10:37 AM   #35
mholt
mholt's Avatar
Default i-vtec DOHC k20A3 in an 02 Civic SIR hatch
Anyone know alot about the K20A3?? I have an 02 Civic SIR, up in Canada, and it seems when it gets a little colder then normal outside the engine makes a high pitched whining noise. Is this normal for these motors? I bought the car when it had 28000 km on it and it started making this weird noise at about 32000 km. I've asked my local dealer what it is and each time they say they will try to figure it out and then they give it back to me telling me that it is because it has a timing chain instead of a belt, and when i ask why it wasnt doing it befor they tell me because it wasnt worked in yet....
Any advice for me anybody? And one more thing. Should there be a kik in the pants when the vtec kiks in?...the car has good power but i can't always feel that extra kik when you hit a certain rpm.
any advice or help is appreciated.
thanks
If you dont like imports then that's too bad for you http://images.honda-tech.com/set1/smile/emsmilep.gif
mholt is offline Report Post   Reply With Quote
Old 09-05-2006, 12:28 PM   #36
Curiouz_G
Curiouz_G's Avatar
wrong forum
The pleasure of a dream is that it is a fantasy. If it happens then it was never a dream to begin with.
Originally Posted by yobbr5
My buddy has a superchargered s2k, and that its rear wheel drive and it loses about 40% of its power from the drivetrain, axle, and other things.
Curiouz_G is offline Report Post   Reply With Quote
Old 11-01-2006, 01:52 PM   #37
lorence
lorence's Avatar
Default Re: (Curiouz_G)
hey im new here and i noticed my v-tec doen't kick in at all when it should because i have an 01 ex. also my car's been laggin meaning running kinda slow. Anyone know wat could be wrong wit it?
lorence is offline Report Post   Reply With Quote
Old 11-01-2006, 02:05 PM   #38
Miracle
Miracle's Avatar
Default Re: (lorence)
Probably needs a decent tune up, and you really will not feel the VTEC in the D17A2 "kick" It is just that harsh of a transition. You will know it, but it won't be like the old B series crossovers.
Old 11-01-2006, 10:15 PM   #39
toyomatt84
Sanji
toyomatt84's Avatar
Send a message via AIM to toyomatt84
It does kick in, but it's very difficult to "feel" the changeover. A good test would be to accelerate normally from 1,000 - 2,200 rpm's, then go to Wide Open Throttle through 3,500 rpm's. You'll notice a slight change in pitch, when the rpm's reach about 2,700 (VTEC kick-in point).
*free hugs*
IA '09: Midwest Caravan (Click to join us!)
toyomatt84 is offline Report Post   Reply With Quote
Old 11-02-2006, 06:40 AM   #40
Boilermaker1
Default Re: This, is VTEC explained. (.Red.EM2)
how it works in this piece.... with the real parts
This is an A2 cam
2 outers are the exhaust lobes
there 1 intake lobe and a circular lobe
This is the intake rocker assy
the one on the left has a roller on it and the other one has nothing.
At low RPM, it runs 1 intake valve. At high RPMs, a pin locks the rockers together and both open.
2002 Civic - POS/Toy
237 HP / 187 TQ @12 PSI
2008 Audi A3 2.0T - Daily Beater
Boilermaker1 is offline Report Post   Reply With Quote
Old 11-02-2006, 08:18 AM   #41
TN90accord
TN90accord's Avatar
Send a message via AIM to TN90accord
Default Re: This, is VTEC explained. (Boilermaker1)
OK, SO THE D17A2 IS VTEC-E??? On wikipedia it says we have SOHC VTEC, and there was just a thread that brought this up. Everyone in that thread was saying we had SOHC VTEC and not VTEC-E. I think its VTEC-E or else the engagement point wouldn't be so low. Also if these pics are from an A2 this kind of proves its VTEC-E.
Stephen
H22 accord (OFFICIALLY laziest HT member...EVER)*
05 Civic EX SE
TN90accord is offline Report Post   Reply With Quote
Old 11-02-2006, 09:16 AM   #42
toyomatt84
Sanji
toyomatt84's Avatar
None of the K-series engines are VTEC-E. The only engine that's VTEC-E in the 7thgen lineup, is the D17A6 which came with the Civic HX.
*free hugs*
Old 11-02-2006, 09:23 AM   #43
Boilermaker1
Default Re: (toyomatt84)
Depends on how you want to define that. The K20A3 is intake only and operates in a very similar manner. Its got a big lobe and a little lobe on the intake side, when VTEC engages, it puts both valves on the big lift lobe. Thats all it does.... more or less the same thing.
Old 11-02-2006, 09:25 AM   #44
Miracle
Miracle's Avatar
Same principal,different name... VTEC-E as compared to i-VTEC.
Old 11-02-2006, 09:33 AM   #45
toyomatt84
Sanji
toyomatt84's Avatar
Default Re: (Boilermaker1)
I know that they are almost identical in terms of operation, but if you want to go technical about the definition of the engine types, the D17A6 is the only VTEC-E engine for the 7th gen Civic's.
*free hugs*
Old 11-02-2006, 09:35 AM   #46
Miracle
Miracle's Avatar
Werd.... You are getting the technical thing down. Now, if I could only get to YOUR level of knowledge about wheels.
Old 11-02-2006, 11:22 AM   #47
TN90accord
TN90accord's Avatar
Default Re: (.Red.EM2)
Wait, so the D17A2 switches between 12 valve and 16 valve operation, but is not VTEC-E? I thought that's what VTEC-E was? I see how the K20A3 motor would be classified as iVTEC, but shouldn't the D17A2 be classified as VTEC-E?
After posting this I re read those post. So the D17A2 has a Low rpm lobe and a high rpm lobe, and when VTEC engages it goes from 12 valve low rpm to 16 valve high rpm? If so I see what you're saying about it not being VTEC-E.
Modified by TN90accord at 2:33 PM 11/2/2006
Stephen
05 Civic EX SE
Old 11-02-2006, 11:27 AM   #48
Miracle
Miracle's Avatar
Default Re: (TN90accord)
No, the D17A2 has the traditional VTEC, it just is not the same style, as it only increases duration on the intake valves.
VTEC-E is used only on the D17A6, fouind in the 7th Gen Civic HX.
Old 11-02-2006, 11:33 AM   #49
TN90accord
TN90accord's Avatar
Please re read my previous post and tell me if that's correct.
Stephen
05 Civic EX SE
Old 11-02-2006, 11:36 AM   #50
Miracle
Miracle's Avatar
The D17A2 VTEC, is VTEC because it increases the Lift AND duration of the intake valves. A VTEC-E motor only increases the amount of intake valves that operate... Like the K20A3, and the D17A6.
Bookmarks
2004, bad, cam, civic, d17a2, explained, good, honda, hondas, preventing, sensor, stage, tps, vafc, vtec
