#1 | |||||
#2 |
so the vtec controler aint worth it? what if i changed my fuel pump and injectors?
Quote, originally posted by jackinthetrunk » So I bought this helmet size Large. So that means it is not DOT certified right? http://images.honda-tech.com/set1/smile/emthup.gif |
#3 |
The most benificial 'all motor' Change you can do to your car, is to change the fuel system to a returnable system, which really isnt worth it anyways on the D17, but if youre willing to go all out, and spend some futile money on the D17, then thats your perogative.
But if you wanted to, then maybe a walbro fuel pump, the swap to a returnable system, aftermarket fuel rail, bigger injectors, a better Intake Manifold, an adjustable FPR, Camshaft, valvetrain, cam gear and VAFC would yield some decent gains. But thats if you want to dump 2 maybe 3 grand into the motor. Which youre going to have to do anyways if you go boost'd. Or you could wait for a K to show up, and then youre really free to do anything. Its really all up to you. |
#4 |
i see,
#5 |
Good write-up on the sohc vtec. Good Job!
#6 |
Asleep in the Back
Nice one, Red.
~ CW DC5 Integra Type R ~ |
#7 | |
MSEngineering unconventional versatility. 92' 2.4L AWD Talon piece of fkin shit. |
#8 |
can you explain to me how the vtec controlller works?
i have a ls-vtec all motor runnin a p28 jun chip....will that benefit my car to run better?
#9 |
nicely done
2003 EM2 NHBP low n slow FS: black enkei rpf1 15x7 4x100 HarkparK |
#10 |
Just FYI, the D17A2 VTEC system only uses two intake lobes. It basically runs 12 valve operation until the crossover point then goes to 16.
#11 |
I have a D17A1 and I might look into installing a Vtec head. I've read what people have to say on other topics, however my friend told me that if I did this I would need a full swap kit, new oil lines need to be drilled for the head, a new ECU, and my check engine light will always be on b/c it would be "chipped". I've noticed no one has adressed this issue yet. If I can find a used headswap for around 300 would you recomend this, I'd like to hear if anyone has done this to their car. This is my first car so I dont wanna screw it up guys lol
![]() Modified by HondaRacing3 at 5:24 AM 7/18/2006 |
#12 |
It isn't worth the effort or the money.
#13 |
Where exactly is the VTEC crossover point on a D17A2? I'm hearing different things like 2 stage where 2000rpm all intake valves kick in and then at 4500 VTEC engages? It's too bad there's no distinct VTEC note with the D17...
#14 |
yes 4500 i believe
#15 | |
#16 |
very good write up, wish would have been able to read this when i was learning..
96 Jetta GLS - SOLD 92 Civic DX D16y8 BOOST! 14.0 at 103!-SOLD 95 Integra GS-R MAD VTAK YO!!! [b]CURRENT[b] myspace.com/doebmx1 Ohio http://images.honda-tech.com/set1/smile/embeer.gif /Oo ___A___ oO |=_|_______|_=| |
#17 |
There's always a different sound, and k24em2 is right.
#18 |
I thought that i would add a little to this thread while asking a few things. I have found a few videos illustrating how Vtec works. These two videos basically reinforced what you have explained.
http://videos.streetfire.net/s...a.htm http://videos.streetfire.net/s...a.htm OK well here goes my newbie questions. This is my first vtec car/honda i have ever owned and I was trying to understand how Vtec works a little better. I have a h22a4 DOHC prelude and I was wondering one thing, how is the sound Vtec "makes" created? |
#19 | |
BTW, VERY good find on the videos. Im going to put those in the OP if you dont mind. |
#20 | |
haha thanks for the explanation Btw how many posts does one need to have before the messaging function works?nvm works and yea put it in the OP so people can see how it works |
#21 |
The only thing I would like to add to this sticky is that honda most certainly did not invent VVT (In essence the mother of vtec). GM had the first version of VVT in 1975. Otherwise, good technical explanation.
Just FYI. |
#22 |
great info for a noob on how Vtec works, but we have Vtec-E (economy) engines and more helpful to know how much Vtec-E sucks before we get our hopes up and then disapointed when a stage 3 cam gives us about 12 hp. 7thgencivic.com has a stickie on how all SOHC Vtec engines work. from 0 to 4500 one intake valve rides the primary and 2nd valve on secondary, after 4500 they both switch to primary, exaust stays the same.
2001 Civic EX, 2 door, five speed. AEM cold air intake DC sports 4-1 header Megan Racing test pipe stock exaust, cut out resenator, put turbo mufler on. http://1bad6t.com/extra/civic_high.wmv |
#23 |
Very nice writeup
Nissan Sucks! 525i Corolla All-Trac |
#24 |
nice post
if you drive a honda, you own if you dont drive a honda, buy one. |
#25 | ||||
Wow, all positive comments, Im kinda suprised on my first write up. Looking good. If you guys have anything to add, like a different type of VTEC, or whatever, throw it up here. It needs to be Honda VTEC related though. Lets keep this rolling. |
| Bookmarks |
| Tags |
| 2004, bad, cam, civic, d17a2, explained, good, honda, hondas, preventing, sensor, stage, tps, vafc, vtec |
