how to change headlight bulbs in 2001 v6 accord
Old 07-13-2006, 02:52 PM
xxkevo's Avatar
Default how to change headlight bulbs in 2001 v6 accord
how do you change the headlight bulbs in a 2001 v6 accord...? i know in my friends I4 is easy as it has so much room, but the v6 model has alot of stuff in the way... so is the only way to change it is by dropping the bumper? or is there a way with out having to drop the bumper? thanks!
Old 07-13-2006, 03:00 PM
iam7head's Avatar
Default Re: how to change headlight bulbs in 2001 v6 accord (xxkevo)
break out your manual if you need a how-to
you do not have to remove the bumper, i forgot how it did it but you can slip your hand to it, well, you can if you don't have some butcher's hands
Old 07-13-2006, 06:53 PM
Legendaryyaj's Avatar
Default Re: how to change headlight bulbs in 2001 v6 accord (iam7head)
Its exactly the same as the 4cyl. No different. Low beams shouldnt run you into cleareance issues with fat hands. The high beam though, thats a little rough but can be done without dropping the bumper.
Old 07-13-2006, 10:18 PM
xxkevo's Avatar
on the driver side lowbeam there seems to be a plastic tray in the way or something is that removeable?
Old 07-14-2006, 04:28 AM
blackv6's Avatar
Default Re: (xxkevo)
The passengers side you should have no problem. On the drivers side there is a plastic piece blocking it, but it pops right out. You should be able to do it fine, I could and I am 6' 3" with pretty big hands.
75aces
04-10-2011 05:11 PM
vaultman07
09-09-2010 07:05 PM
shankbear
02-19-2007 08:02 PM
JiGzAcura
08-30-2004 12:00 PM
Quick Reply: how to change headlight bulbs in 2001 v6 accord
