Honda Door Lock Problem
Old 07-13-2006, 11:50 AM
HondaDocket's Avatar
Default Honda Door Lock Problem
I recently am having problems with my automatic door lock on my 01 Civic. It started with one lock not unlocking and now 3 don't unlock. HELP! Thanks!
Old 07-13-2006, 11:53 AM
Miracle's Avatar
Default Re: Honda Door Lock Problem (HondaDocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaDocket &raquo;</TD></TR><TR><TD CLASS="quote">I recently am having problems with my automatic door lock on my 01 Civic. It started with one lock not unlocking and now 3 don't unlock. HELP! Thanks!</TD></TR></TABLE>
more than likely the switch has got a bad connection, or the switch itself is going bad.
Could be 3 of the 4 door lock actuators, but highly doubtful.
Old 07-04-2008, 07:27 PM
ugaprof's Avatar
I had a similar electric lock problem on my 1990 Accord. First the electric locks would work intermittently, then one day they quit working all together. It turned out to be a bad solder joint on the lock control module circuit board. The relay terminal that connected to pin #3 was broken and was easy to locate by looking for broken solder on the bottom side of the board. After heating the joint with a soldering iron and applying a dab of solder it works good-as-new.
The door panel had to be removed, the lock control module removed and then opened. It was really a fairly simple repair.
lrhtech
07-13-2015 05:30 PM
viper111
01-10-2013 09:59 AM
kevpple
Honda CR-V & Element
07-07-2011 07:34 PM
Dropped90Integra
07-21-2005 07:50 PM
patastinky
01-29-2003 10:05 AM
Quick Reply: Honda Door Lock Problem
