Odometer LED Backlight Fuse
Good afternoon everyone, my backlight where the odometer reads just turned off. I do not have the Honda Manuel so I cannot figure out which fuse to replace. Can someone help out with this issue? Thank you in advance.
Honda Accord 98, EX V6 Couple
Re: Odometer LED Backlight Fuse (mvargas08)
just pull thrm till you find the one thats blown.
however, if its just where the odometer reads, then its probably a bulb.
im pretty sure if a fuse goes that controls the lights on the cluster, then all the lights will be off.
im having sort of the same problem......except only half of my speedometer is out....the left and ride sides light up but the middle is dead!! im guessing my problem is a bulb but i highly doubt that all of the bulbs behind your gauges died at the same time.
jpm0830
02-26-2013 08:33 PM
lokoo23
20
09-12-2009 08:15 AM
lilsicsoul
03-14-2009 02:30 PM
