how to hook up autometer air fuel ratio gauge?
Old 04-19-2002, 10:47 PM
Ignitecivic's Avatar
Default how to hook up autometer air fuel ratio gauge?
i just got an air/fuel ratio gauge. i want to know how to hook it up. can anyone help me. appreciate any help.
thanks
Old 04-19-2002, 11:36 PM
Jonathan_ED3's Avatar
Default Re: how to hook up autometer air fuel ratio gauge? (Ignitecivic)
i'd have no clue. my advice, call them directly...they're really helpful. just tell the secretary lady you need install help and she'll patch you to the 'tech' department
Old 04-19-2002, 11:56 PM
f0de's Avatar
Default Re: how to hook up autometer air fuel ratio gauge? (hot_EF)
tap it off your ecu or your o2 sensor on your cat.. i dunno what wire it is for you car tho
Old 04-20-2002, 06:08 AM
b16b hatch's Avatar
If it i OBD II then the wire is orange/black for the O2 on connector A the 32 prong one. the ground is the thicker black one and then the power on I used for same one as the stereo ignition. I am not sure on the colors for the OBD I harness.
Old 04-20-2002, 07:14 AM
M.A.R.C.'s Avatar
what car is it? obd1 or 2? If it's 2... just run the wire from the gauge to the ecu... and look for a white wire (might look kinda off white) and tap that. Not sure if it's the same for OBD1... should be though... me thinks. I did mine like this:
- position the gauge and pod on the a-pillar
- run the power, ground and o2 signal wires behind/under the dash
- tapped the accessory plug wire for power, grounded it somewhere, and then ran the signal wire to the panel where the ecu is and then tapped the white wire.
This way u don't have to run wires directly to ur o2 sensor.
Hope that helps.
[Modified by CivicRyda2k, 11:18 AM 4/20/2002]
Old 04-20-2002, 03:45 PM
Default Re: how to hook up autometer air fuel ratio gauge? (CivicRyda2k)
it is for a 94 d16z6. i dont know what obd is it.
Old 04-20-2002, 04:42 PM
mps9506's Avatar
That would be obdI, I think your best bet would be to tap off the o2 sensor. My old car had a dedicated O2 sensor for my A/f meter.
I have a 93 civic but never had the need for an a/f gauge....
Old 04-20-2002, 04:43 PM
mantic6t9's Avatar
Default Re: how to hook up autometer air fuel ratio gauge? (mps9506)
That's obd1, you still want to tap in off your ecu.
Old 04-20-2002, 04:45 PM
DragII's Avatar
Default Re: how to hook up autometer air fuel ratio gauge? (mantic6t9)
ecu or the sensor itself both work fine.
jesseunvoas
06-15-2006 08:04 PM
93IntegraRacer
02-10-2004 07:23 PM
Tad
23
11-13-2003 11:24 AM
dnt94civic
05-22-2002 04:54 AM
Quick Reply: how to hook up autometer air fuel ratio gauge?
