Old 07-03-2006, 02:58 PM   #1
slowpokecivic
slowpokecivic's Avatar
Default OBD2 port not working?
went to the state ref today and failed...
but the weird thing is that they told me that they couldnt communicate with the ecu...where can i go to check this out and how do i fix this...?
Originally Posted by simpleCRXkid
im now thinkin bout fixing my crx...had no time in da past but got plenty of it now...i have no vtec...wut wire to cut so i can get vtec???HELP..i need boost!
i laughed so hard diet vanilla pepsi came flying out of my nose...lol
slowpokecivic is offline   Reply With Quote
Old 07-03-2006, 03:02 PM   #2
slowpokecivic
Default Re: OBD2 port not working? (SLoWpOkECiViC)
so the state ref assumed the ecu was jdm...
Old 07-03-2006, 03:54 PM   #3
B16CivicEX
B16CivicEX's Avatar
i have a JDM use , obd 2 to obd1 harness, and same thing here the CEL is on and the reader said can not comm with vehical. bump
B16CivicEX is offline   Reply With Quote
Old 07-03-2006, 07:02 PM   #4
slowpokecivic
Default Re: (AirForceB16)
the thing is i have an usdm ecu...obd2a car with obd2a ecu...
i think ima go to autozone and see if they can read it...
Modified by SLoWpOkECiViC at 12:58 AM 7/4/2006
Old 07-03-2006, 07:47 PM   #5
oOoBanana
oOoBanana's Avatar
the reason why its not reading it because its an obd1 ecu and it needs to read an obd2 ecu...
[B]DB Squad #48[/B] [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img]
"I don't hate you, I just dislike you a lot"
oOoBanana is offline   Reply With Quote
Old 07-03-2006, 07:51 PM   #6
EX-T
1999 Honda Civic
EX-T's Avatar
@dgrantg inebriatedGDubb GDubb615
Default Re: (SLoWpOkECiViC)
Originally Posted by SLoWpOkECiViC
the thing is i have an usdm ecu...obd21a car with obda2a ecu...
What the hell is an obd21a and obda2a ecu??????????
Do you have a CEL on?
Balls out
99 FBP EM1 built and boost'd D16Y8
06 IP G35 Coupe I/TP/E, Tein S Tech Springs
EX-T is offline   Reply With Quote
Old 07-03-2006, 11:58 PM   #7
slowpokecivic
Default Re: (EX-T)
oops...typed that wrong...edited
Old 07-05-2006, 09:08 AM   #8
slowpokecivic
and yes i do have a CEL...but the jumper harness works so i already checked my codes...but the diagnositc plug on the other hand does not work or so what the state referee told me. im going to kragen today after work to check it out....
Old 07-06-2006, 07:05 PM   #9
slowpokecivic
ended up going to autozone and they were able to check the codes...
does that mean the machine at the state ref was not working? or do their machines do a whole different thing?
Old 07-07-2006, 12:15 PM   #10
slowpokecivic
no one can help?
Old 07-07-2006, 12:31 PM   #11
Luserkid
Luserkid's Avatar
Send a message via AIM to Luserkid
If an autozone scanner works on your car then the ref just didnt want to deal with you. If thats the case, rent the scanner and take it to the ref and ask them why there hightech scanner doesnt work when a piece of **** autozone one does. If thats the only reason why they failed you you could take them to court and if you win, you never have to worry about a state ref again (for that car).
Luserkid is online now   Reply With Quote
Old 07-10-2006, 09:18 AM   #12
slowpokecivic
Default Re: (Luserkid)
do you guys think that their scanner couldnt communicate with the ecu because the ecu just got resetted?
2004, 96, 99, civic, communicating, harness, honda, hybrid, ii, inop, obd, obd2, odb2, port, work, working
