How to build a "reliable" lsvtec/b20vtec
#2101
Re: How to build a "reliable" lsvtec/b20vtec
so what do people mean by "build it right" when you are using stock unmodified bottom end for b20vtec?
there seems to be a lot of people using stock b20 block on the forums but I hear this all the time "build it right" what is there to build when ure using stock block?
I wanted to use a stock gsr head with stock cams and set rev limiter at 8000 seems like that's where most people stop with stock block
#2102
Is there a site I can go to where I can view these pictures? You mentioned Cardomain, are they still visible on there?
#2103
8000 will most likely be fine.. on motor the gsr cams are going to not be making real power above that anyway if itr cams start to drop at 7800-8000. just get yourself a nice tight gear ratio so when u shift at 8000 you can still stay in the vtec pretty good
#2104
well actually im using 97 itr cams I was just confused about contradicting posts on many boards regarding stock block b20vtec some people swear to take it to 9000 daily others swear that anything above 7200 will explode.. was just trying to see a word from a shop that does a lot of them.
thanks blackeg
thanks blackeg
#2105
Somebody clear this up. Ive searched and searched . What is the best hg to use on ls vtec .
B18a block and b16 head.
Ive herd ls and ive herd vtec.
Gotta put my head back on tom. So i needa know asap. Thanks
#2110
DO IT ON ALL FOURS
For the record I rev my B20V to 9,000 RPM every time I drive it... no failures to date.
I used to only use the VTEC head gaskets for LSV but then one day I took the time to compare each gasket style on the block. Ever since then I always use the gasket that matches the block. All the holes line up MUCH better. Having drain back oil pooling on top of the gasket just isn't my idea of fun LOL.
#2111
#2113
#2114
The head gaskets have to be checked on the block as well as the head. The main problem with the fitment of the vtec gasket on the block is a bit of misalignment of the oil drain passages. The oil will still drain fine. Now when you look at the non vtec gasket on the vtec its found that the coolant ports do not align in a few spots. To me I think I think water flow through the head properly is a bit more important than a already generous sized oil drain mis aligned a bit. But like I said previously, it all comes down to opinion.
#2115
BAMBAM - great original write up. I'm starting my B20/B16A2 Frankenstein this weekend! I'm stoked. Did anyone use a block guard to brace the piston sleeves for added strength?
#2116
Block guards dont help unless they are machine for YOUR motor. CNCWerx does whats called a cylinder support system, ie a block guard machined to fit perfectly. Its cheaper than sleeving and I believe they guarantee their work up to ~400 (only guarantee sleeves wont crack)
#2117
Have you had your block machined? your bores checked and/or over bored yet? your crank checked for straightness and balanced and aligned if need be yet? only reason I ask is if so then its pretty late in the game to start thinking about putting on a block guard if your ready to assemble already, and installing one on your own may cause deformation to the bore at TDC....if none of that work has been performed it might not be best to at least make sure your rod and piston weights are balanced.
#2119
I will soon be building an lsvtec set up of my own (LS block /b16 head) to put in my delsol and this gave me a lot of useful info. Happen to have any I suggestions about an itb setup ?
#2120
Great thread, it's nice to see some solid time and effort put forth to help educate those in need.
If anyone is interested in a fresh (zero miles) fully built balanced and blueprinted, bulletproof Edelbrock assembled b18b/PR3 LSVTEC for cheaaaaap (they gave me a good deal so I'm paying it forward) shoot me a PM. It comes with a folder full of build sheets specs and reciepts.
#2121
#2122
#2124
So I'm building a lsv with a gsr head I was wondering is arp head stud bolts mandatory I only plan on daily drive this set up n not rev more than 7k but most revs will be around 3k also on ecu how long can I go on a p72 ecu with out tuning on this driving conditions
