How to build a "reliable" lsvtec/b20vtec
Old 03-03-2008, 01:26 PM
  #1251
moderator emeritus
98vtec's Avatar
Default Re: How to build a "reliable" lsvtec/b20vtec (Dual Cam Racing)
the tech forum is not a place to post drama. settle DRAMA over IM. Anymore bickering about headgaskets or bickering in general will be deleted from this point on.
Old 03-03-2008, 01:28 PM
  #1252
A.E Motoring's Avatar
Default Re: How to build a "reliable" lsvtec/b20vtec (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">the tech forum is not a place to post drama. settle DRAMA over IM. Anymore bickering about headgaskets or bickering in general will be deleted from this point on.</TD></TR></TABLE>
Old 03-03-2008, 02:54 PM
  #1253
bambam's Avatar
GE and I spoke over PM's and cleared up any issues we had. Let's get this thread back on track to lsvtec related questions.
Old 03-03-2008, 02:58 PM
  #1254
Golden Eagle's Avatar
Default Re: (bambam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bambam &raquo;</TD></TR><TR><TD CLASS="quote">GE and I spoke over PM's and cleared up any issues we had. Let's get this thread back on track to lsvtec related questions.</TD></TR></TABLE>
Old 03-03-2008, 03:04 PM
  #1255
bambam's Avatar
Default Re: (Golden Eagle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Golden Eagle &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
BTW, to GE's product line and craftsmanship. Good stuff there.
Old 03-03-2008, 03:08 PM
  #1256
moderator emeritus
98vtec's Avatar
thread cleaned. Thank you guys for your cooperation.
Old 03-04-2008, 10:40 AM
  #1257
R.A.T.'s Avatar
Default Re: (98vtec)
Cool, you guys figured things out! So... which head gasket do I use?
LoL
Just kidding
Old 03-04-2008, 10:44 AM
  #1258
h22crxpwr's Avatar
Default Re: (R.A.T.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R.A.T. &raquo;</TD></TR><TR><TD CLASS="quote">Cool, you guys figured things out! So... which head gasket do I use?
LoL
Just kidding </TD></TR></TABLE>
An H22 headgasket.
Old 03-04-2008, 10:45 AM
  #1259
Default Re: (h22crxpwr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22crxpwr &raquo;</TD></TR><TR><TD CLASS="quote">
An H22 headgasket.</TD></TR></TABLE>
Old 03-04-2008, 11:45 AM
  #1260
Dead CIVIC's Avatar
Default Re: How to build a "reliable" lsvtec/b20vtec (bambam)
can you guys help me out with my question.
https://honda-tech.com/zerothread?id=2239897
Old 03-04-2008, 01:48 PM
  #1261
bambam's Avatar
Default Re: How to build a "reliable" lsvtec/b20vtec (Dead CIVIC)
Replied to your thread.
Old 03-04-2008, 08:05 PM
  #1262
mafioso619's Avatar
this post is very helpful!!! i currently have a b20vtec and looking to go all motor and make it reliable so just what i was looking for.
Old 03-06-2008, 10:27 AM
  #1263
b18_racer805's Avatar
good info keep it up
Old 03-06-2008, 08:06 PM
  #1264
cito's Avatar
Default Re: How to build a "reliable" lsvtec/b20vtec (SiR Inspired ED7)
Hey whats up i have a b20vtec on a ef9 what can i do to it to get mid 12
Old 03-06-2008, 08:32 PM
  #1265
slotec's Avatar
Default Re: How to build a "reliable" lsvtec/b20vtec (cito)
turbo and cross your fingers and hope for traction
Old 03-06-2008, 08:43 PM
  #1266
mouab18c1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cito &raquo;</TD></TR><TR><TD CLASS="quote">Hey whats up i have a b20vtec on a ef9 what can i do to it to get mid 12 </TD></TR></TABLE>
alot of things man....you want to stay all motor? or go turbo? choose wisely
Old 03-07-2008, 07:31 AM
  #1267
bambam's Avatar
Better cams, higher compression, Tri-Y header, and open up the air flow flow starting at the filter all the way to the tail pipe. General, but good.
Old 03-07-2008, 03:12 PM
  #1268
Mike_S's Avatar
you broke your motor in on the road alot of guys say to do it on the dyno... just curious to see what other peoples opinions are
Old 03-07-2008, 06:19 PM
  #1269
bambam's Avatar
Default Re: (Mike_S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike_S &raquo;</TD></TR><TR><TD CLASS="quote">you broke your motor in on the road alot of guys say to do it on the dyno... just curious to see what other peoples opinions are</TD></TR></TABLE>
It was not a problem, because I drive around with a Wideband permanently installed. 13.2:1 AFR's across the board.
Old 03-07-2008, 07:44 PM
  #1270
Kevin's Avatar
I see that ARP has a different part number for b18c1 head studs and b20b with b16 head...what is the difference between these two? I could call ARP on monday but i figured i'd post it in here first.
Old 03-08-2008, 06:53 AM
  #1271
Mike_S's Avatar
It was not a problem, because I drive around with a Wideband permanently installed. 13.2:1 AFR's across the board.</TD></TR></TABLE>okay just wondering I was going to build mine and break it in then tune it.. Was going to break in with race gas
Old 03-08-2008, 08:07 AM
  #1272
08_Civic's Avatar
very nice write up man. Repped.
Old 03-08-2008, 08:57 AM
  #1273
bambam's Avatar
Default Re: (Kevin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kevin &raquo;</TD></TR><TR><TD CLASS="quote">I see that ARP has a different part number for b18c1 head studs and b20b with b16 head...what is the difference between these two? I could call ARP on monday but i figured i'd post it in here first. </TD></TR></TABLE>
Spoke to someone that spoke to ARP...according to ARP, the both kits use all the same part numbers, meaning they're exactly the same. ARP chose to create a new kit for b20vtec's to eliminate confusion with their customers. I know personally that both kits will work...never took the time to measure them or look into it further, but it makes sense to me.
Old 03-08-2008, 09:42 AM
  #1274
Kevin's Avatar
Just for reference, the part number for the b20vtec head stud kit is ARP 208-4306.
Old 03-09-2008, 09:38 PM
  #1275
MOE@Hyper16Valve's Avatar
Default Re: (Kevin)
BUMP for BAMBAM...
GOOD write up and good 411 ...
Quick Reply: How to build a "reliable" lsvtec/b20vtec
