Go Back   Honda-Tech > Honda and Acura Technical Forums > Tech/Misc
Old 06-28-2006, 07:03 AM   #1
Mangotreemechanic
Mangotreemechanic's Avatar
Default Do Honda transmissions absolutely, positively need Honda brand fluid?
Is Honda's auto trans fluid MANDATORY? Or is there another great/superior substitute? Are there proprietary additives that the Honda trans MUST have? Has anyone experienced problems with using non-Honda auto trans fluid? Has anyone used the Mobil 1 auto trans fluid? Thanks for all input. Click the image to open in full size.
Honda Coupe's forever! http://images.honda-tech.com/set1/smile/emthup.gifhttp://images.honda-tech.com/set1/smile/emsmile.gif
'96 Civic EX coupe, black
'90 Accord EX coupe, silver
Mangotreemechanic is offline   Reply With Quote
Old 06-28-2006, 08:49 AM   #2
Hyaboosta
Hyaboosta's Avatar
Default Re: Do Honda transmissions absolutely, positively need Honda brand fluid? (Mangotreemechanic)
some people swear by honda tranny fluid but I use mobile one 5w30
ASE Cert. Honda dealer tech avalible for side work in Ft. lauderdale. Parts at cost http://images.honda-tech.com/set1/smile/emthup.gif
Hyaboosta is offline   Reply With Quote
Old 06-28-2006, 09:20 AM   #3
slow poke
slow poke's Avatar
Default Re: Do Honda transmissions absolutely, positively need Honda brand fluid? (Hyaboosta)
For the love of GOD dont put that in your auto trans! Iv heard any auto trans fluid works.
slow poke is offline   Reply With Quote
Old 06-28-2006, 01:24 PM   #4
Hyaboosta
Hyaboosta's Avatar
Default Re: Do Honda transmissions absolutely, positively need Honda brand fluid? (slow poke)
Good god who even has an auto on here?!?!
Old 06-28-2006, 01:40 PM   #5
SOUNDEFFECTS
SOUNDEFFECTS's Avatar
Send a message via AIM to SOUNDEFFECTS
10w30 cheap castrol oil
Old School Boost Junkie
SOUNDEFFECTS is offline   Reply With Quote
Old 06-28-2006, 04:13 PM   #6
non-VTEC
1995 Acura Integra
non-VTEC's Avatar
Default Re: Do Honda transmissions absolutely, positively need Honda brand fluid? (SOUNDEFFECTS)
i don't know why you guys don't read before you post your replies.......he said AUTO TRANNY
as far as i know the "older" honda auto trannys you can use regular dexron ATF fluid........i read somewhere that the "newer" auto tranny MUST use the specific Honda ATF fluid or you may damage the trans.......
I'm not 100% sure if that is true but who cares....you only need a few quarts of ATF just buy it from the dealer and be done with it.
95 Integra Turbo - SOLD
2014 Toyota Corolla S
non-VTEC is offline   Reply With Quote
Old 06-28-2006, 08:05 PM   #7
Mangotreemechanic
Default Re: Do Honda transmissions absolutely, positively need Honda brand fluid? (non-VTEC)
Thanks for the replies! Click the image to open in full size.
I was not about to throw motor oil into my AUTO TRANNY. Click the image to open in full size.
I agree it is not much money for a few quarts, but it is always good to know if a substitute might do even better. Click the image to open in full size.
After all, isn't that why some people mod their cars?
Old 06-28-2006, 08:24 PM   #8
Combustion Contraption
Combustion Contraption's Avatar
Send a message via AIM to Combustion Contraption
Yes, but your not going to gain a few horses by switching to a different auto trans fluid. Someone will bitch and argue about this but i dont care.
EARL LASKEY, YOU WILL BE MISSED
CCCylinderheads.com
Combustion Contraption is offline   Reply With Quote
Old 06-28-2006, 09:53 PM   #9
FalkenSiR
FalkenSiR's Avatar
shpongled357 SeekerOfOneness
Send a message via Skype™ to FalkenSiR
I am aware that Ford and Honda require their own fluids. Now just because you put a different tranny fluid in your auto honda, it doesn't mean you are modifying it, and it won't make your car faster, just a FYI. Click the image to open in full size.
If you think you know, but you don't do, you don't know.
- A random wise guy.
FalkenSiR is offline   Reply With Quote
Old 06-29-2006, 06:36 AM   #10
Mangotreemechanic
Default Re: Do Honda transmissions absolutely, positively need Honda brand fluid? (fast95eg8)
No argument and no bitching. Click the image to open in full size.
I know its not hp, but it's the mentality and desire to find a better replacement or substitute. Thanks.
Anyone running the automatic transmission fluid made by Mobil?
BMW also specifies its own trans fluid.
Old 06-29-2006, 07:57 AM   #11
slow poke
slow poke's Avatar
If you not worried about price then the Honda ATF is the best option.
Old 07-08-2006, 05:22 PM   #12
outersquare
outersquare's Avatar
actually it doesn't say you must use honda atf for newer auto trannies either. As pulled from my 03 i4 auto accord manual, pg 280;
"Always use Honda ATF-Z1 (Automatic Transmission Fluid). If it is not available, you may use a DEXRON III automatic transmission fluid as a temporary replacement. However, continued use can affect shift quality. Have the transmission flushed and refilled with Honda ATF-Z1 as soon as convenient."
In the same manual, the last page, service information summary lists as follow;
"automatic transmission fluid: Honda ATF-Z1 (Automatic Transmission Fluid) preferred, or a DEXRON III ATF as a temporary replacement."
For 01+ civics the manual carries the same statement.
I've read a claim here that using a dexron iii fluid increases shift firmness, thus durability/torque holding. Of course I don't have experimental evidence to support this yet.
http://www.honda-tech.com/zerothread?id=1195661
This weekend I tried a drain and fill of M1 ATF on the accord, changes 3 quarts out of 7 total, and it does seem to make shifts firmer. If anyone has driven an old school honda, like 3rd or 4th gen accord, it now has a similar shift feel instead of the impercetible one.
I have an IR thermometer and there is no difference in transmission temperature.
2003 LX - 2007 SE - 2010 LX-S
outersquare is offline   Reply With Quote
Old 07-09-2006, 05:31 PM   #13
EvilPinkEye
EvilPinkEye's Avatar
Send a message via AIM to EvilPinkEye
I do you ***!!! lol
soon to be gone in a few weeks Click the image to open in full size.
EvilPinkEye is offline   Reply With Quote
Old 07-09-2006, 08:26 PM   #14
Ls_V_TurboSi
Default Re: Do Honda transmissions absolutely, positively need Honda brand fluid? (EvilPinkEye)
I stick 10-30 in all my cars
works good for me..
Ls_V_TurboSi is offline   Reply With Quote
Old 07-19-2006, 03:49 PM   #15
Mangotreemechanic
Default Re: Do Honda transmissions absolutely, positively need Honda brand fluid? (outersquare)
Originally Posted by outersquare
... This weekend I tried a drain and fill of M1 ATF on the accord, changes 3 quarts out of 7 total, and it does seem to make shifts firmer. If anyone has driven an old school honda, like 3rd or 4th gen accord, it now has a similar shift feel instead of the impercetible one.
Thanks. That is a good test. When you say "M1", do you mean Mobil 1? Click the image to open in full size.Click the image to open in full size.
Old 07-19-2006, 04:07 PM   #16
outersquare
yes, mobil 1 atf.
also regarding this topic, comptech recommends redline synthetic ATF for nearly all their supercharged automatic cars. They say it is worth a 25 deg reduction in transmission temps. Redline syn ATF is a dexron III fluid also.
Old 07-19-2006, 08:46 PM   #17
aafryf
aafryf's Avatar
amsoil. works well in a honda auto
aafryf is offline   Reply With Quote
atf, atfz1, atv, dexron, fluid, honda, iii, kind, manual, mobil, mobile, synthetic, tranny, trans, transmission, z1
