Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Acura Integra Type-R
Old 04-17-2002, 06:47 AM   #1
Black R
1988 Honda Civic
My Garage
Black R's Avatar
Send a message via AIM to Black R
Default o2 sensor extenders (plug and play) and vafc wiring harness (plug and play)
A couple of people have asked me about these lately, so here's a pic:
From left to right:
kenji vafc harness, primary o2 extender, 2ndary o2 extender, and oem primary o2 sensor.
The kenji harness you can plug and play - I spliced and soldered the wires and heat shrink wrapped all the connections to make them permanent to the vafc harness.
The o2 sensor extender harnesses are plug and play as well. I added the rubber plug for nice oem fitment where the old one used to go.
Nice, eh?
Solder + splicing + heat shrink wrapping + electrical tape is your friend. Click the image to open in full size.
[Modified by Black R, 10:49 AM 4/17/2002]
Toda itb's for sale:
http://hondamarketplace.com/showthread.php?t=3064222
Black R is offline   Reply With Quote
Old 04-17-2002, 06:49 AM   #2
Renegade
Renegade's Avatar
Default Re: o2 sensor extenders (Black R)
where do you get the plugs at, I mean the grey ones at the ends?
did you use the stock ones just spliced in more wire to make them longer?
[Modified by 98401R, 3:50 PM 4/17/2002]
SupertechPerformance.com -/- RadixMotorsports.com -/- SwiftSprings.com -/- GoPro.com -/- BlacktraxPerformance.com -/- KingOfWraps.com -/- VexMotorsports.com -/-
Performance Electronics pe-ltd.com -/- specialprojectsms.com -/- specclutch.com/
Renegade is offline   Reply With Quote
Old 04-17-2002, 07:10 AM   #3
Austin
Austin's Avatar
Default Re: o2 sensor extenders (98401R)
Stock plugs, just extended them with a little extra wire.
Austin
2001 Type-R
1994 Civic B18B H2 #23
HyTech Exhaust DynoSpot Racing HASport Motor MountsWest Coast Honda Challenge
Austin is offline   Reply With Quote
Old 04-17-2002, 07:16 AM   #4
Black R
1988 Honda Civic
My Garage
Black R's Avatar
I should add that junkyard is your friend.
IM kenji on this board for the ECU plug and play option. He is Click the image to open in full size. and I've bought from him many times as well as referred people to him.
I made these "plug and play" items so I wouldn't have to splice into my factory wiring harness... I like the clean installs like that, and no worries about trying to go back to stock if necessary - just unplug and plug the stock o2 sensor back in if I want... I needed extra length with the godspeed testpipe, and with the hytech header, and these work perfect. Plug and play, and if I ever go back to stock, I can unplug the extenders, plug everything up, and nobody will ever be the wiser. This is great for those looking to keep their warranty. Click the image to open in full size. I was even selling them for $50 for two a while back. Not worth it for me to make them cause it takes so much time, but if you can't do it yourself, these are nice.
I may make some plug and play injector harnesses next, so I can go from oem honda to say rc 440 or 450 dsm injectors - just by plugging them in... We'll see...
Old 04-17-2002, 07:20 AM   #5
AssPenny
AssPenny's Avatar
As soon as I get my lazy *** to a junk yard that has some dc2's (none with in like 50 miles of me), dan-sucks.com will start selling the extenders and we will also be selling o2 fakers so you don't get a cel when running a test pipe. We will be installing the prototype on Marc's (RealTypeR) car next weekend to see how it works. I'll keep you all posted.
Craig -Whos got a **** load on his plate, extenders, o2 faker, mc braces, front hood release blockers, ....
Craig - I spell like a 3 year old.
01 ITR
03 M3
Host it the we-todd way http://images.honda-tech.com/set1/smile/emthup.gif
AssPenny is offline   Reply With Quote
Old 04-17-2002, 07:23 AM   #6
RATEDR
RATEDR's Avatar
nice work....you ever going to actually use these items or just let them stay in your JDM apartment for photo shoots Click the image to open in full size.
+ 1
If you want a great price on a new Honda in Atlanta email me!
RATEDR is offline   Reply With Quote
Old 04-17-2002, 08:49 AM   #7
Kengs
Kengs's Avatar
Default Re: o2 sensor extenders (RATEDR)
Ken has been a busy little beaver Click the image to open in full size.
Kengs is offline   Reply With Quote
Old 04-17-2002, 09:13 AM   #8
Rob :190:
Rob :190:'s Avatar
Send a message via AIM to Rob :190:
Default Re: o2 sensor extenders (kengs)
excuse my ignorance, but somebody explain the purpose of extended o2 sensor wires. better fitment with non-stock cat/header combos?
Rob Maybach, ex-ITR owner
we-todd-did-nc::P1 Automotive Owns
Rob :190: is offline   Reply With Quote
Old 04-17-2002, 09:17 AM   #9
Willard
Willard's Avatar
Default Re: o2 sensor extenders (Brian Spilner 1035)
check out Ken's header post and look at the different lengths..Click the image to open in full size.
Willard is offline   Reply With Quote
Old 04-17-2002, 09:18 AM   #10
Rob :190:
Rob :190:'s Avatar
Default Re: o2 sensor extenders (Willard)
just did, one of those things where i knew the answer, just needed some reassurance Click the image to open in full size.
02, dodge, ends, extender, extenders, harness, honda, o2, o2s, plug, purpose, sensor, wire, wiring
