98 HONDA ACCORD TUNE UP...
Old 06-09-2006, 07:19 AM
execute007's Avatar
Default 98 HONDA ACCORD TUNE UP...
1998 hond accord, 96k miles. I want to do a complete tune up on this car. Does anyone have a writeup on what i should buy and how to do the tune up?
Thanks
Old 06-09-2006, 07:24 AM
S CARTER's Avatar
Default Re: 98 HONDA ACCORD TUNE UP... (execute007)
V6 or 4 cylinder?
Old 06-09-2006, 09:25 AM
execute007's Avatar
Default Re: 98 HONDA ACCORD TUNE UP... (S CARTER)
v4..
Old 06-09-2006, 09:55 AM
mattf22b1's Avatar
ok..rotate tires change oil and oil filter change fuel filter coolant flush, clutch fluid brake fluid, transmission fluid, power steering fluid, change distributor cap and rotor, change spark plugs and wires. timing belt and all drive belts. Check timing, compression, and do a leak-down test. check brake pads and rotors, change windshield wipers if necessary. re-do all grounds valve cover vtec solenoid engine ground etc...clean motor and do a motor flush, involves putting in liquid with you old oil nd running the car for 10 minutes before changing oil, can use sea foam if you want to clean up the carbon build up.
thats all i can think of right now, and pretty much all ofr this can be found at your local autozone, if you need/want honda specific parts try http://www.tasauto.com
compscience007
08-16-2017 01:35 PM
MacH
04-11-2008 09:18 AM
dleccord
04-08-2008 08:00 PM
Ms.JDMdb8
07-09-2005 06:34 AM
RUBZERK
09-18-2003 09:01 AM
Quick Reply: 98 HONDA ACCORD TUNE UP...
