distributor and head question
Old 06-08-2006, 12:13 AM
milllllkman's Avatar
Default distributor and head question
I am trying to figure out which head is on this b18b block i have... I bought it from a friend of a friend and he said it was a b18b... I think the distributor is shot and i got a working one from a 95 ls and it wont fit.. the code on the head is pr4.. on the timing cover its in jap so i guess its a jdm head.. are the b18a 92-93 distribtors different then the b18b's? Thank you
Old 06-08-2006, 02:21 AM
project 2two9's Avatar
Default Re: distributor and head question (milllllk)
the b18a distributor should work on it
Old 06-08-2006, 04:33 AM
deckster333's Avatar
Default Re: distributor and head question (project 2two9)
Use the distributor that goes with the OBD of your ecu and ignition system
Old 06-08-2006, 09:35 AM
Yeah thats the problem.. i got a 95 ls distributor right here obd1 and it doesnt fit.. i dont want to waste more money on another one thats not going to fit.
Old 06-08-2006, 10:08 AM
Default Re: (milllllk)
How do you identify the distributor? Like tdxxx? The only writing i found was on the inside of the cap that said PT2/3 M16680
Old 06-08-2006, 11:30 AM
ACURA INTEGRA 1.8L NON-VTEC
1996 - 2000 OEM # TD-85U (OBD2)
1992-1995 OEM #: TD46U OR TD55U (OBD1)
1990-1991 OEM #: TC07A, TD23U, & TD24U (OBD0)
that should be correct
Old 06-08-2006, 11:37 AM
instructor74's Avatar
Default Re: (deckster333)
this might be stupid but did you check to see if you had the key way turned to match the cam? these are keyed to go in one way only.
Old 06-08-2006, 12:20 PM
PhatBoy5015's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by milllllk &raquo;</TD></TR><TR><TD CLASS="quote">Yeah thats the problem.. i got a 95 ls distributor right here obd1 and it doesnt fit.. i dont want to waste more money on another one thats not going to fit.</TD></TR></TABLE>
What do you mean by "doesn't fit"? What part of the distributor isn't fitting?
Double Agent
09-23-2009 08:12 PM
matmcg
02-15-2008 05:05 PM
goforbroke
11
08-30-2005 02:30 PM
Doodoo
01-21-2003 09:23 AM
g's integ
03-27-2002 01:01 PM
Quick Reply: distributor and head question
