Old 06-02-2006, 06:15 PM   #1
lcjarrett
lcjarrett's Avatar
Send a message via AIM to lcjarrett
Default How to install your own aftermarket horn on EK!!!
Here we go...Sorry if this isn't a good write up but i am trying to help all the EK owners that want to use there horn with an aftermarket steering wheel...
Tools:
Screwdriver
Wire Cutter
Electrical Tape
Piece of metal (6 1/2 inches long)
2 Pieces Speaker Wire (6 inches)
Double Sided Connector
Prong Connector
1st : Located the horn button under the steering column it looks like this...
I cut mine before I made this post but anyways you can see that there are three wires that come out of the horn button(teal wire with black line, teal wire with red line and a blue wire with a silver line). The horn wire is the blue wire so double sided connector, connect it to a piece of speaker wire and to will look like this...
Now that you connected the horn wire to the speaker wire you have to get that metal piece that you needed and here is the tricky part...You have bolt up this metal piece to the steering column and make sure that the metal piece is touching the brass part of the hub which is in the back of the hub. Which should look like this...Front View
Top View...
Rear View...
When you bolt on that metal piece it's time to get that horn wire with the connector and bolt that up to the screw that you used to bolt up the metal piece. Which should look like this...
After you bolt that screw on now it's the easy part...That wire that comes with the hub is going to connect to the prong that is on the botttom of the quick release. Now with the other piece of wire and the prong connector this will be the ground wire that will connect to the other prong on the bottom of the Quick Release. The ground can be bolted the steering wheel nut...Which should look like this...
Now from the Quick Release you have wires in there also. Make sure that you wire the Quick Release RIGHT. The ground to the ground and the power wire which is the horn wire the the horn wire...Then from the Quick Release wire it up to the aftermarket horn....Then kazaam...honk honk!!!!!! HAHA
I hope this post helps out all you EK owners...
lcjarrett Vouch Thread
http://www.hondamarketplace.co...03264
DIY: Install Front Tow Hook
http://honda-tech.com/zerothread/1742522
DIY: Install Horn in a EK
http://honda-tech.com/zerothread?id=1648030
R.I.P Marine Corps Lance Cpl. Blake A. Magaoay
One of The Few, The Proud, A Marine!
96 Civic piece of Art Stolen....You will be missed
lcjarrett is offline Report Post   Reply With Quote
Old 06-02-2006, 07:26 PM   #2
ekVtecPower
ekVtecPower's Avatar
Send a message via AIM to ekVtecPower
Default Re: How to install your own aftermarket horn on EK!!! (lcjarrett)
good write up..
[b]JDM is how I Roll ...
***EK SQUAD***
***PAYPAL VERIFIED***
ekVtecPower is offline Report Post   Reply With Quote
Old 06-02-2006, 07:59 PM   #3
VRD^sam
VRD^sam's Avatar
Default Re: How to install your own aftermarket horn on EK!!! (ekVtecPower)
use marco next time you take pictures
VRD^sam is offline Report Post   Reply With Quote
Old 06-02-2006, 08:04 PM   #4
lcjarrett
lcjarrett's Avatar
Default Re: How to install your own aftermarket horn on EK!!! (..::ferio::..)
what the F*** is Marco?
Old 06-02-2006, 08:22 PM   #5
jp8900
jp8900's Avatar
Send a message via AIM to jp8900
He meant mAcro.... its a camera setting where u can take super up close pics in clear quality........(haha laymans terms)
jp8900 is offline Report Post   Reply With Quote
Old 06-02-2006, 09:17 PM   #6
SuperSi
Send a message via AIM to SuperSi
Default Re: How to install your own aftermarket horn on EK!!! (jp8900)
Marco hahahahha Thanks for the write up.
SuperSi is offline Report Post   Reply With Quote
Old 09-22-2006, 05:50 AM   #7
viskii420
viskii420's Avatar
Send a message via AIM to viskii420
nice write up
Ebay|Build|Ramku|Vouches
"If A is success in life, then A equals X plus Y plus Z.
Work is X, Y is play and Z is keeping your mouth shut.
" -A.Einstein.
viskii420 is offline Report Post   Reply With Quote
Old 09-29-2006, 04:44 PM   #8
turbob18si
turbob18si's Avatar
the only question I have is after you remove your cable reel how do you get the signalst to turn off automatically ek specific
If you want your car to be cheap and fast it wont be reliable...
If you want your car to be reliable and cheap it wont be fast...
If you want your car to be fast and reliable it wont be cheap
turbob18si is offline Report Post   Reply With Quote
Old 09-29-2006, 04:52 PM   #9
BlueIntegraBoy
1998 Acura Integra
BlueIntegraBoy's Avatar
Default Re: How to install your own aftermarket horn on EK!!! (turbob18si)
I need to get my horn working again.
インテグラ タイプR 98-0425
BlueIntegraBoy is offline Report Post   Reply With Quote
Old 09-29-2006, 05:02 PM   #10
NMZ
NMZ's Avatar
Send a message via AIM to NMZ
Default Re: How to install your own aftermarket horn on EK!!! (BlueIntegraBoy)
this is confusing man
does that wire stick out like that all the time
NMZ is offline Report Post   Reply With Quote
Old 10-09-2006, 11:33 AM   #11
Jdmglenn
Jdmglenn's Avatar
Send a message via AIM to Jdmglenn
Default Re: How to install your own aftermarket horn on EK!!! (dontgivafuk)
just one wire goes to the metal strip, and the other two go to the backside of the cover. The wire doesnt really stick out cuz your ign. plastics cover it all
thow la nguoi yeek nam
Jdmglenn is offline Report Post   Reply With Quote
Bookmarks
96, aftermarket, civic, company, ek, honda, horn, install, market, quick, release, s2000, steering, wheel, wire
