Car overheating, radiator fan only works when car is off??
Old 03-25-2011, 07:16 AM
  #26
Vurt's Avatar
Default Re: Car overheating, radiator fan only works when car is off??
Hi i am having the same problem with my 95 civic lx. My radiator fan does not work, i have a new waterpump,thermostat and i checked all my fuses. Would taking the ac fan and swapping it with the radiator fan fix it? Also, How much is a new relay? My car like boils the antifreeze after i stop for awhile so that white container cap pops right off from that. What should I do? Thank you
Old 03-25-2011, 08:50 AM
  #27
mherrcat's Avatar
Funny that in the first 25 posts on this thread no one mentioned doing the easiest thing first: crack the bleed bolt and bleed the air from the system at the thermostat housing. If the fan switch on the thermostat housing works and the fans aren't coming on something is not allowing coolant (or enough coolant) to flow over the switch sensor. I just went through this with my 94 EX and changing the thermostat and bleeding the air fixed it.
Post #26 sounds like the thermos switch on the top radiator hose is not working, if this is happening after the engine is shut off.
This link helped me test all the connections and relays, etc:
http://techauto.awardspace.com/overheating.html
Old 07-02-2017, 09:24 AM
  #28
Monz951's Avatar
Default Re: Car overheating, radiator fan only works when car is off?? (pyrojeff)
Originally Posted by JimBlake
I think in '94 there were 2 fan switches & a fan timer module. The fan switch on the thermostat housing is responsible for running the fan while the engine is on. Unplug that & jumper the wires with a paperclip or something. Key on, that should make the fans run.
If it does, you've just demonstrated that all the fuses & relays are working OK. So you need a new fan switch.
, I jumped my wires with a paper clip but they do not kick on,,, any ideas?
Old 10-21-2019, 09:50 AM
  #29
Trapordie70's Avatar
what did you do to get working!!??
305S0L
11
11-08-2019 08:04 PM
DJaeMac
Honda Civic (2001 - 2005)
04-28-2007 04:05 PM
Maxpower350
07-16-2006 06:56 PM
adnohr
05-31-2005 10:10 AM
Mattyg2
06-01-2004 02:46 PM
Quick Reply: Car overheating, radiator fan only works when car is off??
