Go Back   Honda-Tech > Honda and Acura Technical Forums > Forced Induction
Old 05-26-2006, 07:54 PM   #1
abmerop18
abmerop18's Avatar
Send a message via AIM to abmerop18
Default how to calibrate e-manage to gm 3bar map sensor?
i am about to install a gm 3 bar map sensor on my 7thgen and need to know how to calibrate my e-manage so that it has the correct boost reading since i am switching from a 1 to a 3 bar map sensor. any help would be appreciated. thanks.
7thgen boostin 12 psi http://images.honda-tech.com/set1/smile/emthup.gif
Originally Posted by Specialedition05
Well my car is a EM2 the "2" makes it a 04-05 the EM is 01-03
abmerop18 is offline   Reply With Quote
Old 05-27-2006, 07:36 AM   #2
abmerop18
abmerop18's Avatar
Default Re: how to calibrate e-manage to gm 3bar map sensor? (abmerop18)
anyone?
Old 05-27-2006, 08:45 AM   #3
TheShodan
TheShodan's Avatar
iTrader Rating: (5)
Send a message via AIM to TheShodan Send a message via Yahoo to TheShodan
Originally Posted by abmerop18
anyone?
You don't use the GM 3bar map sensor for the Greddy e-manage. You would use the Greddy Pressure sensor (which is 3 bar) to hook up to the unit. The original manufacturer is DENSO, and they use the same pressure map sensor as the APexi' Power FC. If you MUST use the GM 3 bar sensor, plan to change managment altogther for best results, but the pressure sensor from Greddy isn't that expensive, and can be easily ordered.
“Don't let the opinions of the average man sway you. Dream, and he thinks you're crazy. Succeed, and he thinks you're lucky. Acquire wealth, and he thinks you're greedy. Pay no attention. He simply doesn't understand.” -Robert G. Allen
TheShodan is offline   Reply With Quote
Old 05-27-2006, 11:28 AM   #4
abmerop18
abmerop18's Avatar
Default Re: how to calibrate e-manage to gm 3bar map sensor? (TheShodan)
i have the pressure sensor alredy, i was under the assumption that it was used to control the voltage clamp and that it wasnt a map sensor in itself?
Old 05-27-2006, 12:50 PM   #5
mike93boost
Send a message via AIM to mike93boost
you need the greddy pressure sensor. yes it is a 3 bar map sensor.
mike93boost is offline   Reply With Quote
Old 05-27-2006, 02:51 PM   #6
TheShodan
TheShodan's Avatar
iTrader Rating: (5)
No it IS the map sensor. It works in conjunction with your STOCK OEM map sensor. Youd don't disconnect the one to use the other. this really helps with a smooth transition.
Old 05-27-2006, 04:07 PM   #7
abmerop18
abmerop18's Avatar
well i am throwing a code for high voltage to the map sensor. what should i do to solve this then?
Old 05-28-2006, 07:45 PM   #8
Weq
Weq's Avatar
adjust the boost cut limiter to a lower voltage. for odb2 civics it should be a max of 2.95v, 2.9v to be safe.
DOnt ask around here for this kind of stuff, look onthe yahoo emanage group. There is a heep of information on how to use a GM 3bar instead of the greddy pressure sensor. Its very easy and these guys are just haters who have no idea what they are talking about!
Weq is offline   Reply With Quote
bar, boost, calibrate, calibrating, clamp, cut, emanage, gm, greddy, hook, map, pressure, reading, sensor, voltage
