2000 Civic SI radio...all lights out except for center (amber display)
Old 05-26-2006, 03:22 PM
dotmichael to you
. M i c h a e l's Avatar
Default 2000 Civic SI radio...all lights out except for center (amber display)
I dont know why...but every backlight is out except for the part that tells you the time/volume/track listing.
any way to figure out whats wrong and how to fix it? i have no use for it and want to sell it and get the most out of it.
Old 05-26-2006, 08:30 PM
shyboy817's Avatar
What about the Climate Control/Cluster etc, those lights turn on?
Old 05-27-2006, 05:19 AM
dotmichael to you
Default Re: (shyboy817)
yeah everything was is fine except for what i mentioned.
Old 05-27-2006, 05:43 AM
B18C_EJ8's Avatar
Have you checked the fuse?
Old 05-27-2006, 10:45 AM
JSPECSIR's Avatar
Default Re: (B18C_EJ8)
the faceplate lights iluminate when powered on by the illumination wire. the display lights come on with the radio with acc. check your illumination wire with a meter to see if it gets 12v when you turn on your parking lights.
Old 05-27-2006, 02:04 PM
dotmichael to you
Default Re: 2000 Civic SI radio...all lights out except for center (. M i c h a e l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Have you checked the fuse?</TD></TR></TABLE>
no since the clock works and part of the lumination of the radio works
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5THGENSI &raquo;</TD></TR><TR><TD CLASS="quote">the faceplate lights iluminate when powered on by the illumination wire. the display lights come on with the radio with acc. check your illumination wire with a meter to see if it gets 12v when you turn on your parking lights.</TD></TR></TABLE>
its completely out of the car now...is there any way to test it while being out?
Old 05-28-2006, 05:56 AM
JSPECSIR's Avatar
i would go to best buy and tell them you need a 98 up honda reverse harness. thatll be the same as the one in your car . then you can find a 12v power source, ground the neg. dimmer wire and apply 12v to the orange ill. wire. if that doesnt illuminate them, then go ahead and hook the memory, and acc. wire to 12v, and the black wire to ground and try again. I have one of these radios hooked up in my garage to a computer power supply and thats the harness i used. hope this helps.
wesley_925
Lighting
10
07-05-2008 06:34 PM
94eh2
02-06-2007 09:41 AM
gsp ej1-em1
10-01-2005 10:14 AM
FBP Si 2000
12-23-2003 05:16 PM
wu tang
13
07-19-2003 03:39 PM
Quick Reply: 2000 Civic SI radio...all lights out except for center (amber display)
