**Official H2B Discussion thread **
Old 11-09-2012, 03:07 PM
  #18876
slowesteg's Avatar
Default Re: **Official H2B Discussion thread **
anyone looking for an KS BS eliminator kit? http://hondamarketplace.com/showthread.php?t=3099087
Old 11-11-2012, 04:02 PM
  #18877
DA is best's Avatar
update 11-14
parting out my h2b setup, everything is new and in good condition and for a h22/h2b/civic
pm is best
h22 skunk2 pro 1 cams..SOLD
h22 skunk2 cam gears...$230
h22 skunk2 intake manifold...SOLD
h22 hondata intake gasket...$?
h22 BDL fuel rail...SOLD
h2b logic tri-y... SOLD
QSD h2b EF kit...SOLD
esp ef traction bar...$330
function & form type 1 coilovers for ef hatch...$550
h22 gates timing belt (new) $?
rywire obd1 harness for h22 in eg/dc (used for 3 months in the summer)..$650
innovative motor mounts ef bseries (new) ...$150
esp upper alternator relocation brackter for ef...$100
3.5'' to 4'' intake with 4'' v-stack...SOLD
blox 76mm h22 throttle body...SOLD
hasport ef bseries shift linkage...$120
if you need individual pics pm me
Old 11-11-2012, 06:43 PM
  #18878
bluehbcivic's Avatar
^^ got PM'd
Old 11-11-2012, 10:37 PM
  #18879
slojdmcrx's Avatar
Pm me a price for the intake manifold, tb, and velocity stack as a package deal shipped to NC. Thanks
Old 11-12-2012, 01:44 PM
  #18880
DA is best's Avatar
pm's replied
Old 11-13-2012, 02:59 PM
  #18881
kulo's Avatar
Wtb h2b header
Old 11-13-2012, 08:18 PM
  #18882
n*werk's Avatar
h2b with a/c. anyone done it yet? if so pm me your setup. thank you h2bEasters
Old 11-13-2012, 09:33 PM
  #18883
turtleman321's Avatar
Yes in Ek chassis
Old 11-14-2012, 01:43 PM
  #18884
jdmcivic89's Avatar
Anyone going to Vegas ifo?
Old 11-14-2012, 04:56 PM
  #18885
SP GARAGE's Avatar
Holla
Old 11-14-2012, 10:51 PM
  #18886
jdmcivic89's Avatar
Originally Posted by FLATBUSH PROJECTS
Holla
When u leaving?
Old 11-14-2012, 11:03 PM
  #18887
SP GARAGE's Avatar
Originally Friday but now Saturday morning.... Might tune Friday...work has been hectic since our turbine generator went down on Sunday so I will see how much I can get done on the car...
Old 11-15-2012, 07:16 AM
  #18888
92frostwhtdb2's Avatar
Got some hparts if anybody is interested.. http://hondamarketplace.com/showthread.php?t=3102952
Old 11-15-2012, 04:39 PM
  #18889
ef9_lover's Avatar
i got krut's ssr h2b header today!! wut fck wut! jus need wait for my new brake lines to get here so i can drive the hatch. i deleted my abs! finally!
Old 11-15-2012, 04:57 PM
  #18890
Krut's Avatar
Nice Curious to see what power you make with it
Old 11-15-2012, 06:05 PM
  #18891
Originally Posted by jaw0885
Currently running Evo mounts and plate with QSD space and slave adapter. Get rid of the Evo flywheel, wasted a year of racing with it
Whats the problem with the evo flywheel??? i ran 2 complete evo kit without problems?
Old 11-16-2012, 11:53 AM
  #18892
kulo's Avatar
Nice header
Old 11-16-2012, 04:45 PM
  #18893
H2BJON's Avatar
Those SSR headers are going to finally wake that motor up, can't wait to see the dyno #s
Old 11-16-2012, 09:28 PM
  #18894
ef9_lover's Avatar
going to dyno wednesday hopefully!!
Old 11-17-2012, 05:43 PM
  #18895
YeeJ6's Avatar
ef9 lover, good choice on the header!
Old 11-18-2012, 05:52 PM
  #18896
blueballsh22's Avatar
car did not like shifting at anything above 7500....bought a qsd spacer, bolts, and slave adapter and switched to a twin disc, same tranny shifted like butter
Old 11-19-2012, 04:49 PM
  #18897
ramzan_anwar's Avatar
Originally Posted by Fern413
I just finished installing my QSD h2b kit but I'm having issues.
I bolted up the qsd intermediate bracket that goes behind the block
Now I bolt up the intermediate shaft and the thing does not spin whatsoever...
This is driving me crazy..has anyone ever ran into this issue before?
If so please help!!!! Thanks
Problem solved!!!....the intermediate shaft bracket with the welded nuts is junk! To make this work I had to grind off the welded nuts off with a cut off wheel and use longer bolts washers and new nuts and it worked...looks like the welded nuts where just slightly off which was causing the shaft to lock up once it was torqed...
I'm having this same issue!! And it making me crazy!!!
Ive got the welded nut version and every time I tighten them up the shaft locks up, all I have to do is loosen each nut half a turn and it frees it up.
So I got hold of the older version mount which you have to use a nut and bolt and that does exactly the same thing!!!
I even tightened everything up and loosened all the gearbox bolts and still it's the same!
Theirs plenty of space between the intermediate shaft and the block, I grinded more that enough and I've used several different intermediate shafts
What I'm I doing wrong!!!
Old 11-19-2012, 07:04 PM
  #18898
3rdtimecharmer's Avatar
My h2b kit from QSD just arrived at my door step. Looks great!
Shout out and big thanks to; of course Seth @ QSD for a great product and also
Flatbush_project here on Honda tech for helpin me out!
Old 11-20-2012, 01:47 AM
  #18899
Let us know how it goes, I'm having serious issues with my rear intermediate mount, every time I tighten it ou the shaft locks up, who can I speak to?
Old 11-20-2012, 05:05 AM
  #18900
ef9_lover's Avatar
are you using a da or dc b series half shaft?
Quick Reply: **Official H2B Discussion thread **
