**Official H2B Discussion thread **
Old 02-21-2007, 06:57 AM
  #2501
skunked's Avatar
Default Re: (4LugR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4LugR &raquo;</TD></TR><TR><TD CLASS="quote">sup all, need some help here!! i got a h 2 b swap, got all the b-series hasport mounts and i have a h22a w/ a b16tranny, in a 94 civic 4dr ex, having trouble w/ the motors mounting up right. i bolted up the driver mount first and the tranny was too low to mount up. when the motor was put at a level spot, there was about a 4in gap!!! it looks like it needs a fatass spacer or longer studs.
one more thing, the intermediate shaft is not on right, its not lining up w/ the kit and its not going in right,its a 96 gsr shaft, i was wondering if i have the right one or do i need one from a 90-93 DA?
help me out i wanna get my baby running asap
thanks.. </TD></TR></TABLE>
All manual B series midshafts are the same. Sounds like your car has an auto chassis/tranny mount too.
Old 02-21-2007, 07:03 AM
  #2502
high_revs's Avatar
your car was prob manual and you might be using the wrong rear bracket as well
Old 02-21-2007, 07:50 AM
  #2503
4LugR's Avatar
Default Re: (h2b_eg8)
it was actually an automatic transmission at first.. about 6 months ago, we did a auto to manual swap
Old 02-21-2007, 08:05 AM
  #2504
I'm really 2slow
2fast4u831's Avatar
Default Re: (4LugR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4LugR &raquo;</TD></TR><TR><TD CLASS="quote">it was actually an automatic transmission at first.. about 6 months ago, we did a auto to manual swap</TD></TR></TABLE>which tranny mount were you using? It should be 1" and 1/2 off if you are using the manual tranny mount. my car used to be auto too
Old 02-21-2007, 08:08 AM
  #2505
high_revs's Avatar
yeah you have to use the tranny auto to manual mount
Old 02-21-2007, 08:10 AM
  #2506
I'm really 2slow
2fast4u831's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h2b_eg8 &raquo;</TD></TR><TR><TD CLASS="quote">yeah you have to use the tranny auto to manual mount</TD></TR></TABLE>the one you stole from me
Old 02-21-2007, 08:31 AM
  #2507
skunked's Avatar
Default Re: (2FAST4U831)
or he needs to weld a new manual mount to the chassis ($40 from Honda).
pic of my manual chassis mount:
pic of the OE mounts
Old 02-21-2007, 08:37 AM
  #2508
h22apwrdcivic's Avatar
Default Re: (skunked)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">or he needs to weld a new manual mount to the chassis ($40 from Honda).
you can get these mounts from honda? seriously? beats going to the junkyard
Old 02-21-2007, 08:38 AM
  #2509
I'm really 2slow
2fast4u831's Avatar
Yup I'll be getting that mount from honda to redo mine.
Old 02-21-2007, 09:27 AM
  #2510
high_revs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2FAST4U831 &raquo;</TD></TR><TR><TD CLASS="quote">the one you stole from me </TD></TR></TABLE>
i bought it fair and square
Old 02-21-2007, 09:29 AM
  #2511
high_revs's Avatar
i hadda re-do the mount in my bubble, it sucked cuz i had to drill out the old tach welds....welding the new mount was easy tho
Old 02-21-2007, 09:47 AM
  #2512
I'm really 2slow
2fast4u831's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h2b_eg8 &raquo;</TD></TR><TR><TD CLASS="quote">i hadda re-do the mount in my bubble, it sucked cuz i had to drill out the old tach welds....welding the new mount was easy tho</TD></TR></TABLE>haha!! I also had to do that, TWICE!! takes a good amount of time.
Old 02-21-2007, 09:48 AM
  #2513
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2FAST4U831 &raquo;</TD></TR><TR><TD CLASS="quote">haha!! I also had to do that, TWICE!! takes a good amount of time. </TD></TR></TABLE>
yeah it takes some time, they're atleast 10 spot welds on those bastards.
Old 02-21-2007, 09:50 AM
  #2514
high_revs's Avatar
yeah man, gotta do wat you gotta do
Old 02-21-2007, 10:08 AM
  #2515
havin a hard time locating them. looking in body section and nothing. but the rubber mounts. any ideas on the p/n?
Old 02-21-2007, 10:12 AM
  #2516
nevermind i found it
p/n is 60831-SR3-300ZZ BRACKET, TRANSMISSION MOUNTING $26.74 $9.28
thats at http://www.slhondaparts.com
  #2517
Turbogixxer's Avatar
Default Re: (h22apwrdcivic)
60831-sr3-300zz
Old 02-21-2007, 10:13 AM
  #2518
high_revs's Avatar
Default Re: (Turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">60831-sr3-300zz</TD></TR></TABLE>
Old 02-21-2007, 12:45 PM
  #2519
AdamB18C1EK's Avatar
Default Re: (AdamB18C1EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AdamB18C1EK &raquo;</TD></TR><TR><TD CLASS="quote">i did my h2b swap over this past weekend and i went to start it up for the first time tonight after finishing up the wiring and it idles pretty lumpy and sounds like its running sorta rich. i took it for a test drive and vtec pops in and out. also, my tach no longer works. i have no CELs. i plan to change the distributor tomorrow just to see if that might be my troubles. any opinions guys ? </TD></TR></TABLE>
so no ideas fellas ?
Old 02-21-2007, 12:56 PM
  #2520
sounds like wiring issues. that or faulty ecu
Old 02-21-2007, 02:02 PM
  #2521
NHswaps13203's Avatar
Location: Swapin Motors,Tuckin Bays and Making Harness, CT, USfukenA
sounds like your maps not hooked up, and are you running a integra harness or civic?
Old 02-21-2007, 02:07 PM
  #2522
skunked's Avatar
Default Re: (H22EHSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22EHSI &raquo;</TD></TR><TR><TD CLASS="quote">sounds like your maps not hooked up, and are you running a integra harness or civic?</TD></TR></TABLE>
No Cel's......
what ECU are you running?
Old 02-21-2007, 02:13 PM
  #2523
high_revs's Avatar
could be a lot of stuff, start with the basics, try a friends ecu or something, check map, tps senors, dizzy
Old 02-21-2007, 02:24 PM
  #2524
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AdamB18C1EK &raquo;</TD></TR><TR><TD CLASS="quote">so no ideas fellas ?</TD></TR></TABLE>
now that i thought about it when i first did my swap the map wiring wasnt included in the harness.
and mine idle like that
Old 02-21-2007, 02:27 PM
  #2525
high_revs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22apwrdcivic &raquo;</TD></TR><TR><TD CLASS="quote">
now that i thought about it when i first did my swap the map wiring wasnt included in the harness. </TD></TR></TABLE>
so you got a new harness?
Quick Reply: **Official H2B Discussion thread **
