> Honda Civic (2001- 2005)
Old 05-14-2006, 06:11 PM   #1
xproductionz
xproductionz's Avatar
Send a message via AIM to xproductionz
Default DIY - DX/LX head swap to EX VTEC
dang.. took us about 4 hours but we finally got it done... dont trust what everyone else says u need.. u dont need the ECU from an EX to convert over.. heres what u will need if you want to avoid getting an ECU from an EX and reflashing ur key:
EX vtec head with solenoid
ex head gasket
and a vafc2
basically if you never have done a head swap before i highly suggest u take it to a shop to do it. we ran into i hiccup after completion cause i had some air bubbles in the coolant but we took care of that in about 10 minutes.. make sure u disconnect the battery before doing the the vafc install
and heres a picture of the cover taken off
the dx head looks like when its off
heres a picture of the ex head.. notice the hanging blue wire.. thats the vtec wire and solenoid...
heres the vafc2 controller.. this is the only way to bypass getting an ECU from an EX and getting your key reflashed
now heres the trick to wiring your ecu.. solder everything and no crimping.. i got a gas powered one so i dont have to worry about running extension cords
now while wiring the vafc2...
first tape off or cap the blue VTM wire cause u will not be using that... also tape off or cap the purple VTEC wire cause u will not be using that either (the DX/LX does not come with a VTEC solenoid signal from the ECU).... also tape the orange wire cause there is no VTC cam signal.. and for other people that are also running the VAFC2 on there EX's we do have a TDC wire on our cars... it would be on pin 26 on the first harness to the left... then follow the installation instructions according to the vafc2 manual using diagram H7-a and dont worry about the other DIY mentioned in another topic thats says to buy a diode.. dont need it... now all u gotta do is finish up ur head install.. as soon as thats done.. remember that blue wire hanging from the EX head.. well cut off the clip
and hard wire it (see the light green wire) from the engine bay into the car next to the ECU... then solder that wire to the pink wire from the vafc... almost there
clean up all ur wires and finish up anything under the hood... fill back ur oil.... add more antifreeze..and now ur car looks pretty much the same when u first started..
haha with the exception of the vtec solenoid and wire.. PLEASE NOTE that if u have had a DX intake then the place where it mounts has to be moved cause that bracket where it used to mount is now replaced with the vtec solenoid..
do the start up proceedures according to what the manual says for the vafc before starting the car... now as for me when i was done.. it took a few minutes before the car actually started... once it finally ran it idled pretty bad and fluctuated... then after a good 2 or 3 minutes the car ran perfectly fine.. my friend says the ecu is just adjusting to the new things we put on there... drove it around for an hour and set my vafc to kick the vtec from
Lo-->Hi at 4700
Hi-->Lo at 4000
just basic settings to get me started but its not even tuned yet and can feel the car pulling alot more when the vtec kicks in
hope this helps
-Mike
WHO DOESNT GO ON MYSPACE
myspace.com/allmotak20
ITS BACK!!.. and better than ever...
Cars. Models. Shows.
Arcade Games and more
www.xproductionz.com
Check out my write-ups
FAQ: Should i Swap or Turbo?
DIY: K20 Swap into a 2001+ Civic
DIY: DX/LX head swap to EX VTEC
xproductionz is offline Report Post   Reply With Quote
Old 05-14-2006, 07:09 PM   #2
brjhnson
71.164.153.48
Send a message via AIM to brjhnson
Default Re: DIY - DX/LX head swap to EX VTEC (xproductionz)
Wow i was asking around about doing this because I really want to. How much did you pay for every thing and how much do you think it would cost to get it done at a shop. also were did you buy everything from
brjhnson is offline Report Post   Reply With Quote
Old 05-14-2006, 07:13 PM   #3
theciv
theciv's Avatar
Send a message via AIM to theciv
Default Re: DIY - DX/LX head swap to EX VTEC (brjhnson)
you can get the head and shit at a junkyard from an es1 or an em2 i believe.
then jus by the vafc controller
U.S.M.C.
theciv is offline Report Post   Reply With Quote
Old 05-14-2006, 08:52 PM   #4
xproductionz
well.. you have to use the em2... i got the head from a junkyard for $200 and had the head milled before i put it on to rasie compression.. gasket i think was like 30-40... its been a while forgot how much it was.. and the vafc2 was $200.. labor was done myself since we did it at the shop so i cant really tell you how much a shop charges.. call around cause shops differ in price from place to place and state to state
Old 05-14-2006, 09:06 PM   #5
theciv
theciv's Avatar
Default Re: (xproductionz)
you could do it yourself though right?
can't be that hard?
pretty much bolts?
U.S.M.C.
Old 05-14-2006, 09:08 PM   #6
xproductionz
well... key things to worry about is..
making sure that everything stays TOP DEAD CENTER while doing it..
and making sure you loosen and tighten the bolts in the right sequence... other than that your good...
another if your going to do this you might as well change the timing belt while your at it
Old 05-14-2006, 09:13 PM   #7
theciv
theciv's Avatar
haha foo sho.
thanks alot. i will do this if i end up getting it
looks like a hell of a fun job and good gains considering i have no vtec
U.S.M.C.
Old 05-15-2006, 08:31 AM   #8
brjhnson
71.164.153.48
Default Re: (theciv)
If I go get it from a junkyard what should I look for exactly if I do find the head. For example what pieces
Old 05-15-2006, 08:39 AM   #9
brjhnson
71.164.153.48
Default Re: (brjhnson)
Also I was wandering should I use a D16 VTECH head or a d17 VETCH head
Old 05-15-2006, 05:56 PM   #10
MajinB
MajinB's Avatar
Send a message via AIM to MajinB
OMG D17!
MajinB is offline Report Post   Reply With Quote
Old 05-15-2006, 06:11 PM   #11
brjhnson
71.164.153.48
Default Re: (MajinB)
calm down i have heard of people using a d16 I was just asking.
Old 05-15-2006, 07:48 PM   #12
xproductionz
well.. if anyone wants my head that i used for that swap im selling it...
Old 03-29-2007, 03:03 PM   #13
jivi
jivi's Avatar
Send a message via ICQ to jivi Send a message via AIM to jivi
Hi newbie here, I have an 2001 LXI gulf specs with D15Y3 engine. Do you think a D17 with Vtec will work as a head swap?
No D15 vtec here in Dubai only a D17 which is a VTI engine has a VTEC.
Will these work also from auto tranny engine then swap to Manual tranny??
Sorry for my ignorance..
TIA
JHMES85361S400683
Made in Japan
S5A1 YAO-NH578
Manf Date: 2000
First batch 7thgen ferio http://images.honda-tech.com/set1/smile/emthup.gif
jivi is offline Report Post   Reply With Quote
Old 03-29-2007, 03:48 PM   #14
b0yg0tskills
b0yg0tskills's Avatar
Send a message via AIM to b0yg0tskills
Default Re: DIY - DX/LX head swap to EX VTEC (theciv)
what the heck is a es1? and can you feel a big gain in the head swap you did?
b0yg0tskills is offline Report Post   Reply With Quote
Old 03-29-2007, 04:31 PM   #15
Vantage
Vantage's Avatar
es1 = 4 door.
1990 Crx: Sold, 2001 Civic LX Sold, 2002 Tacoma Sold : 2006 Civic Si Current!
Vantage is offline Report Post   Reply With Quote
Old 03-29-2007, 05:13 PM   #16
Curiouz_G
Curiouz_G's Avatar
is this in the FAQ? If its not, then it should be...
TODD PUT THIS IN THE FAQ!~~~!!
The pleasure of a dream is that it is a fantasy. If it happens then it was never a dream to begin with.
Originally Posted by yobbr5
My buddy has a superchargered s2k, and that its rear wheel drive and it loses about 40% of its power from the drivetrain, axle, and other things.
Curiouz_G is offline Report Post   Reply With Quote
Old 03-30-2007, 11:42 AM   #17
DJaeMac
DJaeMac's Avatar
Send a message via AIM to DJaeMac
i was wondering how'd you fix the air bubbles in your coolant?...because mine is also doin the same thing....but i also think its boiling....i still don't know if its my headgasket or my waterpump thats causing that because my car overheats like crazy
208.1 HP/194.9 TQ @ 5lbs of boost 2007
13.5 @ 104 mph @ 6lbs 2007
325 HP/316 TQ @ 12lbs of boost 2009
DJaeMac is offline Report Post   Reply With Quote
Old 03-30-2007, 05:23 PM   #18
b0yg0tskills
the 4 door from the 01-05 ex?
Old 03-30-2007, 05:32 PM   #19
b0yg0tskills
to do this swap...do i have to get the ex headers, and intake manifold?
Old 03-31-2007, 04:40 AM   #20
toyomatt84
Sanji
toyomatt84's Avatar
Send a message via AIM to toyomatt84
Default Re: (b0yg0tskills)
No. Why would you? The mounting points are identical.
*free hugs*
IA '10: Midwest Caravan (Click to join us!)
toyomatt84 is offline Report Post   Reply With Quote
Old 04-25-2007, 09:39 PM   #21
blackcivic20
blackcivic20's Avatar
do you know of a good place to bye a gasket set from for a resinable price? thats all i need to get
blackcivic20 is offline Report Post   Reply With Quote
Old 04-25-2007, 09:51 PM   #22
Honda Rules
Honda Rules's Avatar
Send a message via AIM to Honda Rules
nice very nice
EMII
Honda Rules is offline Report Post   Reply With Quote
Old 04-26-2007, 04:36 AM   #23
Boilermaker1
Default Re: (blackcivic20)
hondaautomotiveparts.com
the head kit is around $120 for all of them
2002 Civic - POS/Toy
237 HP / 187 TQ @12 PSI
2008 Audi A3 2.0T - Daily Beater
Boilermaker1 is offline Report Post   Reply With Quote
Old 04-26-2007, 07:45 AM   #24
blackcivic20
Default Re: (Boilermaker1)
thanks alot i needed that and now i am almost done.
Old 04-26-2007, 10:14 PM   #25
blackcivic20
does anyone know what the black round thing is that is on the left side of the engine, wires would usually come down with the ones wraped in the blue and do you need it because i dont see it in this pic.
thanx.
Bookmarks
01, 2002, automatic, civic, d17, dx, engine, head, honda, lx, motor, swap, vafc2, vtec, wire
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
