Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Prelude
Old 05-10-2006, 05:34 PM   #1
PWRDbyHseries
PWRDbyHseries's Avatar
Default How to install Piston rings?
Well i am refreshing my engine and i dont know how to "clock" the rings and was just looking fo rsome help with that...
93 Prelude Si(14.7@93mph)
JDM H22a, Apexi N1 catback, gutted cat, ebay intake,
Fidanza 8.8lbs flywheel, ExedyStg1 clutch, ES mount inserts,
Eibach Sportlines on stock(blown) struts
http://i34.photobucket.com/alb...8.jpg
PWRDbyHseries is offline   Reply With Quote
Old 05-10-2006, 05:47 PM   #2
BDRphaSe2
BDRphaSe2's Avatar
Send a message via AIM to BDRphaSe2
Default Re: How to install Piston rings? (PWRDbyHseries)
were they but up your supposed to have em at like, 12o clock, then second one at 3 oclock, then 6 then 9 get it?
What ever happened to function OVER form ???
since 87
BDRphaSe2 is offline   Reply With Quote
Old 05-10-2006, 09:00 PM   #3
JTCdudeman
Master H Technician
JTCdudeman's Avatar
Send a message via AIM to JTCdudeman
Default Re: How to install Piston rings? (BDRphaSe2)
.Heh... not what Honda or any other ring/piston manufacturer suggests, but ok...
Your helms manual should be able to help you in this matter...
The should be approximately 15 degrees off from each other... They shouldnt be directly at above the wrist pins or perpendicular to them... This will help minimize scarring and maximize effectiveness... Please reference the helms manual before trying anything like this as it seems like a disaster waiting to happen...
If you're into cars you must understand the golden rule: You have 3 words: Fast, Cheap, Reliable...
The problem is, you can only choose 2 of them.
89 Prelude Si 642whp 502tq @ 29psi H22a
1/4 mile: 10 sec club
1993 Si
H22a
JTCdudeman is offline   Reply With Quote
1993, accord, clock, clocking, h22, h22a, honda, hondatech, how, instal, install, installing, piston, ring, rings
