Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Acura Integra Type-R
Old 05-01-2006, 09:26 AM   #1
KnowForever
KnowForever's Avatar
Send a message via AIM to KnowForever
Default Code P1399 Anybody?
So I'm pulling into my driveway last night and the check engine light comes on. Car is still running fine and everything so i head to the garage and get the trusty Actron code scanner. I don't remember the first 3 codes exactly but it's close and i remember what the descriptions are.
P3020 - Cyl 2 misfire
P3030 - Cyl 3 misfire
P3003 - Random/Multiple misfire
P1399 - Manufacturer Specific
"Ok" I think, lets bust out the Helm's manual.
To my dismay of course the code is not in there.
Google search: Chrysler light switch code or something to that effect.
H-T.com Search: a bunch of stabs in the dark but nothing solid that i could find.
Didn't really have time to mess with it last night so i just cleared the codes on it and drove it to work today (only mode of transportation). I was easy on it but the codes didn't reappear and it drove fine as far as i can tell.
So first question is, anyone know what this code really is?
Second, what's wrong with my car.. bent valves, plugs, rotor button, cap wires, just an odd coincidence, valves out of adjustment, loose nut behind the wheel?
I'll be doing a compression test tomorrow as well as possibly ordering some tune up parts just to be safe. Click the image to open in full size.
ITR 01-0673 http://images.honda-tech.com/set1/smile/emthup.gif
Good Sellers/Vouches:
Danza, Willard, Ebelp, BlueR http://images.honda-tech.com/set1/smile/emthup.gif
KnowForever is offline   Reply With Quote
Old 05-01-2006, 09:31 AM   #2
len
len's Avatar
Default Re: Code P1399 Anybody? (KnowForever)
Are you positive that it's not a P1359?
Originally Posted by P1359
P1359: CrankshaftPosition/TopDeadCenter/CylinderPosition (CKP/TDC/CYP) Sensor
The scan tool indicates Diagnostic Trouble Code (DTC) P1359: A problem in the Crankshaft Position/Top Dead Center/Cylinder Position (CKP/TDC/CYP) Sensor circuit.
len is offline   Reply With Quote
Old 05-01-2006, 09:40 AM   #3
KnowForever
Default Re: Code P1399 Anybody? (len)
I'm positive that i wrote down a P1399 but i guess it's possible i copied it down wrong or sloppy. From searching H-t there were several threads with people asking about this code but with no real responses.
Old 05-01-2006, 02:23 PM   #4
Echo7847
Echo7847's Avatar
Send a message via AIM to Echo7847
None of the codes you listed are valid codes per Honda.
ASE Certified Honda Service Technician
94' Civic Ex
Echo7847 is offline   Reply With Quote
Old 05-01-2006, 03:53 PM   #5
rainforest
Send a message via AIM to rainforest
Default Re: Code P1399 Anybody? (Echo7847)
p1399 is a random misfire code.it will show up when there is more than one misfire most of the time. btw chris answer your phone.
rainforest is offline   Reply With Quote
01, actron, acura, adjustment, code, crv, dtc, honda, integra, manufacturer, p1359, p1399, p3020, scanner, specific, trouble, valve
