***Official H22 All-Motor Dynamometer Thread***
Old 04-26-2006, 08:03 PM
VtecKiDD's Avatar
Default ***Official H22 All-Motor Dynamometer Thread***
looking to see what your setup is an what your whp an TQ look like.
Preferably 220whp+
Old 04-26-2006, 08:15 PM
SMSP's Avatar
Default Re: Post your H22 All Motor Dynos (VtecKiDD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecKiDD &raquo;</TD></TR><TR><TD CLASS="quote">looking to see what your setup is an what your whp an TQ look like.
Preferably 220whp+</TD></TR></TABLE>
Corey Jacobs H1 Engine
232.1 whp and 169.6 lb-ft
Type S pistons (+.25mm)
NASA H2 legal head work, i.e. not much head work
Jun IIIs
Skunk2 cam gears
Accord Type R IM
light weight FW
ITR TB
ITR snorkel
S200
SMSP 4-2-1 Header #2 in the size chain from the current 4 offerings
(The red line was his old H2 engine)
Old 04-26-2006, 08:21 PM
VtecKiDD's Avatar
Default Re: Post your H22 All Motor Dynos (SMSP)
Old 04-26-2006, 10:44 PM
FSAE
92TypeR's Avatar
Really want to get this car back on the rollers with a good header and 2.5" exhaust.
Old 04-27-2006, 12:05 AM
4genaccordfreak's Avatar
^^ WOW that is some serious torque numbers for only 227whp!!
although looks to be about right considering the 2mm bore increase and 13:1 c/r
Wicked numbers tho!
Old 04-27-2006, 03:56 AM
junbb1's Avatar
Default Re: (4genaccordfreak)
https://honda-tech.com/zerothread?id=1555815
These numbers like Corey's are SAE and not STD or actual.
Old 04-27-2006, 05:29 AM
F22PwrdS2k's Avatar
Engine & Transmission
JDM H22A, Crower Stage 3 Cams (316 Duration), Ferrea Valvetrain, Mahle 11.5/1 Pistons, Crower Max Light Rods, Micropolished and Balanced Honda Crank, STR Throttle Body, AEM Fuel Rail, B&M Fuel Pressure Regulator, RC 440cc Injectors, Fidanza Cam Gears, Motorvations Cam Seal, Hytech Tri-Y Custom Header (2.5in Collector), K-Teller Exhaust Piping with Magnaflow Resonator, and ES Oval Muffler (All 2.5in), Cusco Oil Catch Can, Fluidyne Radiator with FAL Fan, Unorthodox Race Crank Pulley, Fidanza Flywheel, ACT Xtreme Pressure Plate with 6-Puck Unsprung Race Disc, Hondata S200 (Jim Helbing of Motorvations Tuned)
Old 04-27-2006, 07:31 AM
VtecKiDD's Avatar
wow, im loving the TQ numbers.
anyone with ITBs? trying to see anyone cracking 240whp
Old 04-27-2006, 08:39 AM
Chase's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecKiDD &raquo;</TD></TR><TR><TD CLASS="quote">wow, im loving the TQ numbers.
anyone with ITBs? trying to see anyone cracking 240whp</TD></TR></TABLE>
I drove Taylors car, its fast as shittttteee!!!!
and Taylors car will go past 240hp with ITB's (when he gets them )
Old 04-27-2006, 09:42 AM
xDicktonesx's Avatar
Default Re: Post your H22 All Motor Dynos (EF8kid)
with the H2B out now, can you imagine a 240hp 170tq H22 with an ITR tranny and 10lb flywheel? K KILLER.
Old 04-27-2006, 10:21 AM
Shooting Star
vtecspeed1320's Avatar
10lb how about 8lb ftw!!! When I get done with my build, I will hope to be pushing the 250 whp with addition to the h2b.
Old 04-27-2006, 10:26 AM
VtecKiDD's Avatar
Default Re: (vtecspeed1320)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecspeed1320 &raquo;</TD></TR><TR><TD CLASS="quote">10lb how about 8lb ftw!!! When I get done with my build, I will hope to be pushing the 250 whp with addition to the h2b.</TD></TR></TABLE>
whats your setup if you dont mind me asking
Old 04-27-2006, 10:30 AM
Shooting Star
h22
h23 crank
RM h22 rods
mahle pistons c/r will end up being 11.78:1
crower stg 3's
pnp head
not sure of valvetrain yet
h2b
b16 w/lsd
not sure of what intake...either itb's or that nice mani that rlz engineering made!!!! If they sell.
nos...after the 250whp
Old 04-27-2006, 12:15 PM
SMSP's Avatar
You don't need ITBs to break 240whp on a H22. Corey would be there if he had a full porting job.
Old 04-27-2006, 12:26 PM
VtecKiDD's Avatar
thats what im seeing, i have an EF, so it depends on what ill need as far as intake manifold clearance will be.
Old 04-27-2006, 12:49 PM
cpforyou's Avatar
H22A All-Motor 233 HP 175 FT-LBS Dyanpack Dyno on OEM Bottom End
Euro R Engine
R&D CNC Ported Head
Skunk2 Stage II Camshafts
Valvetrain & Adj. Cam Gears
Injen Cold Air Intake
HyTech Header
Custom 2.5" Piping with Magnaflow Muffler
Old 05-03-2006, 11:58 PM
Fresh start for 09'
ATS*EK24's Avatar
Default Re: Post your H22 All Motor Dynos (cpforyou)
This is gunna be a good thread
Old 05-04-2006, 03:13 AM
SkankyEJ7's Avatar
Default Re: Post your H22 All Motor Dynos (H22PwrdHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22PwrdHatch &raquo;</TD></TR><TR><TD CLASS="quote">
first time i have ever held on for dear life in a honda was in this car
it pulls like a dodge
Old 05-13-2006, 08:59 AM
Fresh start for 09'
ATS*EK24's Avatar
Default Re: Post your H22 All Motor Dynos (98ekhx)
bump
Old 05-13-2006, 01:03 PM
skunked's Avatar
Default Re: Post your H22 All Motor Dynos (ATS*FRED)
Stock USDM H22 longblock (10:2:1) with crower cams, six sigma header, 68mm Holley. Tuned with a fields.
[IMG][/IMG]
Old 05-13-2006, 01:29 PM
moderator emeritus
98vtec's Avatar
Default Re: Post your H22 All Motor Dynos (skunked)
damnit, i need to dyno my car. I guess you guys are gonna have to wait til i get the ITB's on.
Old 05-13-2006, 01:52 PM
Fresh start for 09'
ATS*EK24's Avatar
Default Re: Post your H22 All Motor Dynos (98vtec)
good numbers "skunked"
Old 05-13-2006, 06:27 PM
The_Head's Avatar
Sorry I don't have a graphic I can post but here's the numbers from my old H23VTEC setup
140-155 wtq from 2700-7700
215 whp @ 7700 rpms
JG Engine Dynamics Sheetmetal Intake manifold
64 MM throttle body
RC 440 injectors
P28 with Hondata S100
STR fuel rail
H23A Block, Balanced bottom end
Shotpeened rods, ARP rod bolts
Type-S pistons (~12.0:1)
Crower Springs & Retainers
Stock H22A cams
Skunk 2 adjustable cam gears
Hondata intake gasket
Crush Bent 2.5" Exhaust with resonator
Old 05-13-2006, 06:38 PM
sikciv666's Avatar
Default Re: Post your H22 All Motor Dynos (The_Head)
bump for sum more!!
Old 05-13-2006, 07:22 PM
Bserious's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_Head &raquo;</TD></TR><TR><TD CLASS="quote">Sorry I don't have a graphic I can post but here's the numbers from my old H23VTEC setup
215 whp @ 7700 rpms
64 MM throttle body
RC 440 injectors
STR fuel rail
Stock H22A cams
Crush Bent 2.5" Exhaust with resonator </TD></TR></TABLE>
That was all it made? That setup is good for at least 230. What type of bumpsticks were you running?
Quick Reply: ***Official H22 All-Motor Dynamometer Thread***
