Go Back   Honda-Tech > Honda and Acura Technical Forums > Tech/Misc
Old 04-26-2006, 07:32 PM   #1
rmcdaniels
rmcdaniels's Avatar
Default HowTo: DIY Exhaust Coating
I've been messing around with DIY exhaust coatings, and have about got it down. It's pretty cheap, quick, and easy to do your own stuff if you want to. Here's how it works:
I've been using Caswell Black Satin ceramic-reinforced thermal barrier coating:
http://www.caswellplating.com/aids/techline/
This stuff works really well, I used it on a Lovefab SST manifold (big ramhorn turbo manifold) and after a few dyno pulls I could put my hand less than .5" away from it and hold it there comfortably, it radiated very little heat (uncoated it's way too hot to get your hand anywhere near it and burns the paint on the hood over the manifold after a while).
I bought the 12 oz. can for $55, but I've done two headers and a turbo manifold/downpipe with it and I've still got well over half the can left. I can probably do 5-6 more manifolds/headers with it.
The biggest thing about using this stuff is the surface prep. I did the turbo manifold without getting it sandblasted, just wire-brushed it and hosed it down with brake-clean. It went on and did it's job, but it scratched very easily before it cured and some of it flaked off after it cured. On a well-prepped surface it is very tough, even before it cures. I scraped my new header against my radiator when I was installing it and it didn't even scratch the uncured surface. After you heat it up and it cures, it's really tough. I've got some pics from the last thing I did, my old RMF header that I wanted to fix up before I sold it.
Here's the header, just bare mild steel at this point. These things are beautiful and they make power; Randy Monroe does great work:
Here it is after sand blasting:
I don't have a sand blaster, so I got somebody else to do it. You want to get it aluminum oxide blasted, or anything that leaves it with a nice rough finish. No glass beading, nothing that would polish it. Clean it off good with some brake-clean and make sure it is completely dry.
You just need a very thin coat, about .001"-.0015". According to the people at Caswell, the best way to get it on there right is with an air brush. Here's the one that I bought for $10 at Northern Tool & Equipment, I'm sure they have something similar at Harbor Freight. I have a small compressor with a 2.5 gallon tank that I paid $90 for new many years ago so I could do leakdown testing, and it works fine for the air brush:
I spray it just enough to cover the metal. If you get too thick a coat on it, then it will not adhere to the metal. It dries in a few minutes, but needs to be heated to at least 700 degrees to cure. It will scratch off if you scrape it too hard before it cures, so be careful installing uncured parts. I didn't want to put this in the oven, mostly because I'd be concerned about fumes and I cook in that oven, so I just cure it on the car. After it cures, the coating is very tough. Here are some pics of the coated, uncured header:
This one is getting sold, so no cured pics of it, but here's a pic of my new header to show what it looks like cured:
It cures to a flat black finish.almost chalky looking when it first cures, but it's not powdery to the touch, and the chalky look goes away after a while.
Once again I can't stress how much this cuts down on radiated heat, especially from turbo manifolds, but also from headers. Is it as good as paying hundreds of dollars to professional ceramic coating places? Probably not, but it's dirt cheap, can be accomplished in your back yard in an hour, and gets the job done.
Every ship is a minesweeper, once.
rmcdaniels is offline   Reply With Quote
Old 04-26-2006, 10:03 PM   #2
redzcstandardhatch
something different
redzcstandardhatch's Avatar
Send a message via AIM to redzcstandardhatch
excellent little write up! i'm definitely doing this.
-adam j. moderately tall dutch track bum. enjoys long walks in the paddock. seeking a trackday where he doesnt hit something.
redzcstandardhatch is offline   Reply With Quote
Old 04-26-2006, 11:12 PM   #3
Muckman
Moderator
Muckman's Avatar
iTrader Rating: (2)
ccmuckman
Send a message via ICQ to Muckman Send a message via AIM to Muckman
Default Re: HowTo: DIY Exhaust Coating (rmcdaniels)
Have you tried HPC ceramic coatings? I wonder how they stack up again Jet-hot and Swaintech. Great write up by the way! Click the image to open in full size.
Integra GSR 13.5:1 GT30R 597hp build
Evo9 MR SE
Muckman is offline   Reply With Quote
Old 04-27-2006, 12:20 AM   #4
raceACCORDingly
raceACCORDingly's Avatar
I need a compressor and a bigger garage.
raceACCORDingly is offline   Reply With Quote
Old 04-27-2006, 08:29 AM   #5
JK_Motorsports
JK_Motorsports's Avatar
Any idea on the Thermal Abilitis of the ColorGuard?
Does it insulate as well as the black?
Be nice for blocks, heads, DPs in the Titanium or Aluminum Color!
<FONT COLOR="red">[B]JKMotorsports Traction Bars from LSD Motorsports:[/B]</FONT> [B][url="https://www163.safesecureweb.com/lsdmotor/suspension.aspx"]Great Traction Bars at a Great Price![/url][/B]
93 Hatch, DOHC ZC, Eagle Rods, SRP Pistons, Delta Cams, JG Cam Gears, ARP Studs, JKMotorsports Sidewinder, T3/T04B all real Garrett, Tial KnockOff, Direct Port Nitrous, CromePro, LC-1, Ostrich, Helical LSD, Clutch Specialties Stg4
90 RHD Hatch in Build
JK_Motorsports is offline   Reply With Quote
Old 04-27-2006, 11:51 AM   #6
Dunc
Dunc's Avatar
Default Re: HowTo: DIY Exhaust Coating (neo_)
What would happen if you sprayed it on thicker than .001"-.0015"?? Like if you used a regular paint gun as opposed to the air brush.
Also, would the 4oz. can be enough for a just a Lovefab Shorty (log-style) manifold and a downpipe?
'08 R6
'97 LS-GSR/VTEC Turbo
'98 Jeep Cherokee 4WD
Dunc is offline   Reply With Quote
Old 04-27-2006, 12:03 PM   #7
DJ Gurgla GSR
DJ Gurgla GSR's Avatar
Default Re: HowTo: DIY Exhaust Coating (AF-P Dunc)
it will probably chip or flake easily if you apply it too thick
Mr. Sparkle Detailing Inc. - Owner / Operator
Authorized Installer of Opti-Coat
www.MrSparkleDetailing.com
DJ Gurgla GSR is offline   Reply With Quote
Old 04-27-2006, 05:03 PM   #8
rmcdaniels
rmcdaniels's Avatar
Default Re: HowTo: DIY Exhaust Coating (DJ Gurgla GSR)
The people at Caswell said it wouldn't bond to the metal properly if it is too thick.
Old 04-27-2006, 06:02 PM   #9
Dunc
Dunc's Avatar
Gotcha, so .001" is a layer just barely covering the metal then? Like should I just spray it on as thick as like a normal spray can would? Oh, just remembered about my other post...you think the 4oz. can would be sufficient for a log manifold and downpipe (maybe the dumptube if I feel like it)?
'08 R6
Old 04-27-2006, 07:19 PM   #10
JDMTurboEG6
JDMTurboEG6's Avatar
damn nice stuff ive got to try this!
Vouches: Garth, Quang-sta, Aztekef9, scrambledeg, magooeg6, cdapimp691, Integra_Nguyen, dmakarov, shaun311, Sp00n'd Supra, RasmusRic, TaylorEj1
HONDA Certified Technician
JDMTurboEG6 is offline   Reply With Quote
Old 04-27-2006, 10:34 PM   #11
Takumi Fujiwara
Takumi Fujiwara's Avatar
Default Re: HowTo: DIY Exhaust Coating (JDMTurboEG6)
What compressor did you buy for $90?
Takumi Fujiwara is offline   Reply With Quote
Old 04-27-2006, 11:17 PM   #12
rmcdaniels
rmcdaniels's Avatar
The air brush puts out a real thin layer, like a spray can if you move it real fast. 4 oz. should be more than enough for a log and a downpipe.
Some super-cheap junky compressor that was on sale at Pep Boys. It's actually worked pretty well though, but I mostly use it for leak down testing.
Old 04-28-2006, 08:06 AM   #13
Dunc
Dunc's Avatar
Cool thanks for you ideas & help!! Click the image to open in full size. I'm just waiting for the new turbo to get in (the current one is smokin' like a champ haha)....so when it does I'll take some before and after readings with a laser temperature guage.
'08 R6
Old 04-28-2006, 08:09 AM   #14
rmcdaniels
rmcdaniels's Avatar
That would be great, please post them up. It feels a lot cooler when I hold my hand near it, but I haven't had my hand calibrated in years.
Old 04-28-2006, 08:35 AM   #15
Dunc
Dunc's Avatar
haha hands usually need a recalibration once a year or so. As soon as Garrett gets on the ball (I'm hearing Wednesday of next week) and makes some 60-1's I'll post up the temps.
'08 R6
Old 05-02-2006, 01:16 AM   #16
redsikiller
redsikiller's Avatar
Send a message via AIM to redsikiller
That would make your EGT's waaay higher, wouldn't it?
-Mike
redsikiller is offline   Reply With Quote
Old 05-05-2006, 09:57 PM   #17
Dunc
Dunc's Avatar
Default Re: HowTo: DIY Exhaust Coating (redsikiller)
Just ordered a 4oz. can Click the image to open in full size. The new turbo is slated to get here on May 11th. I've done some preliminary temp. measurements.
After a one hour trip on the highway with EGT's averaging 1350*, I let it sit idling for a couple minutes. When the EGT's dropped to 950* I opened the hood and measured:
Manifold: 650*
Turbo: 800*+ It spiked the laser gauge, so it was well over 800*
I'll do the exact same test in a couple weeks when the new turbo is on there and ready to rock Click the image to open in full size.
'08 R6
Old 05-24-2006, 08:18 PM   #18
Dunc
Dunc's Avatar
Ok so I just put the new turbo and stuff on this weekend. That coating is definitely worth the $25 for the 4oz. can. It went a LOOOOONG way. I heat coated my manifold and entire downpipe/dumptube with maybe like 1/4 to 1/3 of the can. Click the image to open in full size.
But yea, I can hold my finger literally a 1/16" or 1/8" from the manifold comfortably for well over a minute. I could go longer, but I got tired of just holding my finger there....so try and do that with an uncoated manifold!!
Data:
Uncoated:
- Manifold: 650*F
Coated:
- Manifold: 490-500*F
Conclusion:
This stuff is worth every penny for the 4oz. can! I bought the 4.99 air brush kit from Harbor Frieght and just threw it away when I was done. The surface temperature was reduced by 100*F but the radiant heat is amazingly lower. Click the image to open in full size. Click the image to open in full size. Click the image to open in full size.
rmcdaniels: GOOD FIND MAN Click the image to open in full size.
'08 R6
Old 05-24-2006, 09:34 PM   #19
jdm'dc2sc61
jdm'dc2sc61's Avatar
excellent, i was worried i wouldn't be able to do my downpipe, but i guess i can. ima do my turbine as well. Click the image to open in full size. Click the image to open in full size.
[url="http://www.spoolinperformance.com"]http://www.spoolinperformance.com[/url]
Nor Cal installs/Fabrication
EG/DC IC piping - 304L tig welded log manifolds( B-D-F-H Series)
revhard/inlinepro/drag/blox) downpipes etc.
[email]Spoolindevelopment@gmail.com[/email]
[url="http://www.redzoneperformance.com"]http://www.redzoneperformence.com[/url]
for all your motor needs! [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img]
jdm'dc2sc61 is offline   Reply With Quote
Old 05-24-2006, 09:39 PM   #20
b18sihatch
b18sihatch's Avatar
very impressive Click the image to open in full size.
Vouches: b18c5rx [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img] , 99_dc2 [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img] , Andres-eh2 [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img] , CockChaos [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img] Nisif [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img] aquarious [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img] Utahbmx [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img] AttentionWhore [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img]
Addicted To Full Race [img]http://images.honda-tech.com/set1/smile/emthup.gif[/img]
b18sihatch is offline   Reply With Quote
Old 05-25-2006, 08:00 AM   #21
CivicMike
CivicMike's Avatar
Send a message via AIM to CivicMike
hmmm, I can understand someones theories on the EGT's being higher.....any data on this yet?? Also wouldn't more heat going through the manifold/turbo create a quicker spool?
CivicMike is offline   Reply With Quote
Old 05-25-2006, 08:37 AM   #22
Dunc
Dunc's Avatar
Default Re: (CivicMike)
You might have more heat for a quicker spool, but it's probably minimal enough that there won't be a big difference.
Also about the EGT: I have not noticed any real change with where my EGT's should be when I'm driving as normal, so I don't think there is a substantial argument for higher EGT's
'08 R6
Old 05-25-2006, 08:54 AM   #23
Excel
Excel's Avatar
Default Re: (AF-P Dunc)
EGT is affected by ignition timing and afr. If you put the probe right near the exit of the port (where it should be) than you would'nt see a difference. If you were to put the probe in your downpipe near the turbine than i could see there being a difference in temps from non-coated to coated.
I am going to try this aswell
Excel
Excel is offline   Reply With Quote
Old 05-25-2006, 09:59 AM   #24
egrice
egrice's Avatar
Send a message via AIM to egrice
good job with the coating
egrice is offline   Reply With Quote
Old 05-25-2006, 10:24 AM   #25
Dunc
Dunc's Avatar
Default Re: (Excel)
Excel
Now that argument I would buy into. My probe is in the manifold runner so perhaps that is why I have seen no difference.
'08 R6
ceramic, coating, coatings, colorgard, difference, diy, exhaust, header, jose, kit, make, manifold, parts, port, san, techline, thermal, turbo
