not holding fuel pressure
Old 04-25-2006, 02:59 PM
efyou's Avatar
Default not holding fuel pressure
i dunno y, but as soon as i put my new fuel injectors in...my car wont hold fuel pressure anymore after i turn the car off, with my old ones the gauge would never go down. so when i start it...i have to crank it a lot longer/ crank it twice and then it starts.
Old 04-25-2006, 04:10 PM
jpnucrx's Avatar
Default Re: not holding fuel pressure (efyou)
Bump because mine does the same thing?!?!
Old 04-25-2006, 04:42 PM
Tippyman's Avatar
Check your banjo bolt. Or it could be leaking somewhere. Park your car over a large peice of cardboard and check for leaks in the morning...
Old 04-25-2006, 05:14 PM
jpnucrx's Avatar
Default Re: (Tippyman)
Mine leaks from where the lil circle bolt goes on to the fuel rail....could that cause it to not fire up as easy?
Old 04-25-2006, 06:56 PM
jpnucrx's Avatar
Default Re: (jpnucrx)
ttt
Old 04-27-2006, 05:00 PM
efyou's Avatar
wtf? a banjo bolt? is that on the left side of the fuel rail?
Old 04-27-2006, 05:02 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jpnucrx &raquo;</TD></TR><TR><TD CLASS="quote">Mine leaks from where the lil circle bolt goes on to the fuel rail....could that cause it to not fire up as easy?
That little circle thingy is the banjo bolt.
Where the fuel line meets the rail is like this ring thing that slides oer the fuel lines, that is a banjo fitting, check to see if it is leaking.
ef-hatchcrap
03-16-2009 02:29 PM
sixtodc2
03-15-2006 04:56 PM
dohced
02-25-2004 07:43 PM
m0t0rhead
01-20-2004 08:17 AM
range
12-19-2003 03:02 PM
Quick Reply: not holding fuel pressure
