torque specs for things that hold the cams down
Old 04-24-2006, 11:40 AM
StraightCivic's Avatar
Default torque specs for things that hold the cams down
does anyone have torque specs for the things that hold the cams down
Old 04-24-2006, 01:46 PM
RHDintegXsi's Avatar
Default Re: torque specs for things that hold the cams down (StraightCivic)
..edited because i accidently gave the wrong info
Modified by SINFULintegXsi at 2:16 AM 4/25/2006
Old 04-24-2006, 01:53 PM
Dartanian's Avatar
20 ft/lbs for the 12mm
7.8 ft/lbs for the 10mm
Don't overtighten because the bolts WILL snap. It has happened to me 4 times so far.
Old 04-24-2006, 02:13 PM
Robstunner4's Avatar
Default Re: (Das Schmoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Das Schmoo &raquo;</TD></TR><TR><TD CLASS="quote">20 ft/lbs for the 12mm
Don't overtighten because the bolts WILL snap. It has happened to me 4 times so far.</TD></TR></TABLE>
better that the bolts snap than the thread getting ripped up(b/c of a ungodly high grade bolt...
( i work at fastenal so no it didnt happen to me lol)
Old 04-24-2006, 03:02 PM
non-VTEC's Avatar
how can you guys give this guy torque specs if you dont even know what engine he is working on.......
Old 04-26-2006, 08:09 PM
Default Re: (Robstunner4)
do u know torque specs for the ones that hold the seals?
Old 04-26-2006, 11:37 PM
95 integra's Avatar
Default Re: torque specs for things that hold the cams down (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">how can you guys give this guy torque specs if you dont even know what engine he is working on.......
Good point....
Old 04-27-2006, 07:07 AM
Default Re: torque specs for things that hold the cams down (95 integra)
the engine is a b18a1 it has all 10 mm bolts which is what my buddy told me, im not taking it apart till i know the specs. What if i just used a torque wrench to find out? would it work that way? like start out small and work my way up little by little until they move a tiny bit then go down one and that should be the torque right?
Old 04-27-2006, 08:18 AM
eight equals equals equals D
Tim2179's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StraightCivic &raquo;</TD></TR><TR><TD CLASS="quote">the engine is a b18a1 it has all 10 mm bolts which is what my buddy told me, im not taking it apart till i know the specs. What if i just used a torque wrench to find out? would it work that way? like start out small and work my way up little by little until they move a tiny bit then go down one and that should be the torque right?</TD></TR></TABLE>
Don't do that.
20 ft/lbs for the 12mm & 7.8 ft/lbs for the 10mm sounds about right though. It's not much, and they wont seem "super" tight, but you don't want to over do it.
Old 04-27-2006, 02:01 PM
95 integra's Avatar
Default Re: torque specs for things that hold the cams down (Tim2179)
BTW, correct torque specs for the LS is 7.8 ft/lbs on the cam caps. The GSR (which uses 12mm bolts) is somewhere in the 18-22 range (i forget exactly....which is why I own a freakin helms manual).
Old 04-27-2006, 11:09 PM
Tim2179's Avatar
According to the '92 service manual for the B18A, the camshaft holder bolts are 7 ft/lbs (10 Nm) the cam gear bolts are 27 ft/lbs.
hspoon
11-24-2007 03:57 PM
GsRwHiTe
03-10-2004 09:51 PM
Islander
04-22-2003 02:20 PM
DOHCtorTHRUST
11-08-2002 07:43 AM
Quick Reply: torque specs for things that hold the cams down
