Go Back   Honda-Tech > Honda and Acura Technical Forums > All Motor/ Naturally Aspirated
Old 04-18-2006, 04:19 PM   #1
Spence
Spence's Avatar
Send a message via AIM to Spence
Default crank position sensor keeps going bad?
Hey guys so this is the second distributor that i have had the crank position sensor go bad on what could cause this in my motor? I believe its a bad product but i cant prove it i dont feel that a cps is going keep going bad in my motor.
Thanks
Spence Click the image to open in full size.
My Vouch Threadhttp://www.honda-tech.com/zerothread?id=949852
"88 Fo Door"
"95 EG Hatch" Sold http://is.rely.net/1-92-65076-l-NREc...mLFY3DaZnA.gif
"90 Wagovan" Sold http://images.honda-tech.com/set1/smile/emsad.gif
"Reppin PORTLAND OREGON"
Spence is offline   Reply With Quote
Old 04-18-2006, 07:41 PM   #2
Spence
Spence's Avatar
Default Re: crank position sensor keeps going bad? (Spence)
bump for help
"88 Fo Door"
Old 04-19-2006, 04:40 PM   #3
Spence
Spence's Avatar
up
"88 Fo Door"
Old 04-20-2006, 03:55 AM   #4
Chillinit
Chillinit's Avatar
Is your motor OBD1 or OBD2? If its OBD2, I think the crank position sensor is near the crank sprocket.
Donít believe the HYPE! - Educate yourself
Builder - Gord Bush Performance @ http://www.gordbushperformance.com/
Chillinit is offline   Reply With Quote
Old 04-20-2006, 06:54 AM   #5
cxcivic
cxcivic's Avatar
Default Re: crank position sensor keeps going bad? (Chillinit)
if you still lived in Tampa, i could help ya Click the image to open in full size.
A/M STREET K24CRX 11.30@122... FIS EG 10.49@136
NS RACING Tampa (813)842 5517
http://www.youtube.com/watch?v=nbsSp...e_gdata_player
cxcivic is offline   Reply With Quote
Old 04-20-2006, 07:30 AM   #6
Ruben19
Ruben19's Avatar
Send a message via ICQ to Ruben19 Send a message via AIM to Ruben19
if the motor is obd2 the crank sensor is located behind the crank pulley.
obd1 you dont need this sensor.
Inside the distributor you have the cam sensor
Middle finger to All Thieves here in WA and over the world, they deserve to die now
Em1 crew Peyton Manning #18 Best QB in the NFL. I <3 HATERS
Ruben19 is offline   Reply With Quote
Old 04-20-2006, 08:11 AM   #7
cxcivic
cxcivic's Avatar
Default Re: (Ruben19)
there is only one ckp(code4)...in the dizzy. The other one near the crank is a ckf...crank fluctuation sensor.
Old 04-20-2006, 01:50 PM   #8
Spence
Spence's Avatar
Neal i dont live in tampa anymore
The motor is obd1 and it through this code only once the other day for the first time since the new dissy this car is not a daily driver now its pretty much a maybe once a week drove car. But everytime it throws this code it goes into limp mode which is very annoying. Neal do you think it maybe wiring? You remember my white hatch that had that torn up wires under the dash. maybe you have a dash harness laying around for a eg
hope this helps
"88 Fo Door"
Old 04-24-2006, 04:11 PM   #9
Spence
Spence's Avatar
bump for some help from mr. cxhatch Neal Sutton
"88 Fo Door"
Old 04-24-2006, 09:35 PM   #10
cxcivic
cxcivic's Avatar
check the blu/green& blu/yel wires at B15 and B16(B is middle plug...these wires are on the end) at the ecu....also same color wires at the dizzy plug. hope this helps some Click the image to open in full size.
Old 04-24-2006, 09:37 PM   #11
cxcivic
cxcivic's Avatar
....and i do have the complete body harness if you need it.
bad, censor, cps, cranck, crank, crankshaft, distributors, failing, honda, keeps, ns, position, sensor, shaft, sign, symptoms
