> Forced Induction
Old 04-12-2006, 10:52 AM   #1
yellowturbo
yellowturbo's Avatar
Default Misfiring problem. Always at 3800-4000 rpm under load ? ( gt28rs SOHC )
Well like the title said.... Ive been at my tuner shop last friday to get the new setup tuned and there is always this stupid misfiring issue right when we cross 4000rpm !!
We have to pass this point without loading the engine too much but if we start in 3rd gear at 2000 rpm and go WOT the engine will just start misfiring when when cross this point. My tuner played with the timing, fuel, VTEC point etc... nothing work. Past that point the engine will pul STRONG until the redline without any issue. Its strange since its where the turbo really kicks in....
I run a MSD SCI box with a blaster SS coil... we changed the coil but it didnt help. I suspect the box now...
Do you know if I could run the SS coil without the box to do the test ? If yes how I could do the wiring ?
Or you may have another idea....
Thanks for the help !
SOHC GT28RS .82ar http://images.honda-tech.com/set1/smile/emthup.gif
17 psi of fun on the street.
yellowturbo is offline   Reply With Quote
Old 04-12-2006, 12:12 PM   #2
yellowturbo
someone ??
Old 04-12-2006, 12:17 PM   #3
TypeSLO
TypeSLO's Avatar
Send a message via AIM to TypeSLO
Default Re: (yellowturbo)
did you check the spark plugs????
will always be too slow...
TypeSLO is offline   Reply With Quote
Old 04-12-2006, 12:17 PM   #4
warrick
warrick's Avatar
I am having the same issue with a friend's car, but it won't go past 4000rpm.
adjusting fuel, timing, boost levels etc does nothing. tried multiple crome maps (p30 and p72), premade and from scratch.
tried a brand new dizzy, new wires, new plugs, smaller gap, nothing.
try a smaller gap though, it may be a good step towards resolution.
warrick is offline   Reply With Quote
Old 04-12-2006, 12:23 PM   #5
yellowturbo
well they are gapped at 0.28'' so its supposed to be good...
well its only when crossing 4000rpm under load... if im in 3rd at 4500rpm and I floor it there is no problem at all !??
Old 04-12-2006, 12:32 PM   #6
2k.civic.si
2k.civic.si's Avatar
all we can really say is check over the ignition system if your sure its not a tuning problem...since i see you have a msd sci system (same one i run) you may want to make sure the msd box itself is grounded...i know if you install the msd system with the rubber spacers according to the directions the box itself is not grounded to the chassis...although internally it may be grounded to the connection it has to the battery...but its still good to ground the box to seperately
EFI University Certified Advanced Tuner http://www.artietuned.com
Ecu chipping,Street/Dyno tuning,Crome Pro/Gold,AEM,FAST,Motec, and more.
www.westcoastnationals.org
2k.civic.si is offline   Reply With Quote
Old 04-12-2006, 12:43 PM   #7
yellowturbo
Default Re: (2k.civic.si)
yeah I will look at the ground thats a good idea cuz I just moved it last winter !
Old 04-12-2006, 01:30 PM   #8
tegasaurus
tegasaurus's Avatar
Send a message via AIM to tegasaurus
my teg would do that (all motor tho) when the ground that was on the back of my thermostat housing would kinda "hang-loose." Check all of your grounds even the ones for that ridiculous msd box you have in your engine bay
94 integra LS - wrecked, care of bmw745il 7/31/02 - 4/24/03
94 integra LS/vtec - stolen at ASU 5/2/03 - 9/11/04
90 nissan 240sx - SR20DET - SOLD 1/6/05 - 8/15/05
01 chevrolet s-10 v6 - SOLD 9/8/05 - 6/7/06
98 integra ls - turbo - fast - SOLD 2-2-07
03 infiniti g35 6mt sedan current project black on black on black fo sho
tegasaurus is offline   Reply With Quote
Old 04-12-2006, 03:44 PM   #9
tcontesh
tcontesh's Avatar
Default Re: Misfiring problem. Always at 3800-4000 rpm under load ? (yellowturbo)
this is the same exact issue that I may possibly be having. we changed the plugs, and it went away for about a week and then just started happening to me again. but my problem is that we cant get vtec to engage on this p72 with crome, and the plugs get loaded up with fuel because the injectors I have supply the higher cam up to 8000 rpms. anyways, maybe some of the plugs are fouled.
[B]97 Prelude SH [/B]
t3/t4 custom Turbo kit @ 10-psi
obd1 p72 piggybacked on cromepro
Precision 550cc's
HKS SSQ BOV
Blitz TT/boost controller
Clutch masters stage 3
[url="http://www.trickengineering.com/customers.htm"]www.trickengineering.com[/url]
tcontesh is offline   Reply With Quote
Old 04-12-2006, 04:37 PM   #10
Weq
Weq's Avatar
Since ur ignition is upto scratch, how is ur fuel pressure? tegasaurus referred the to the ground which controls the fuel pump!
Weq is offline   Reply With Quote
Old 04-12-2006, 04:51 PM   #11
SOHC_MShue
SOHC_MShue's Avatar
Send a message via AIM to SOHC_MShue
I would start with getting rid of the msd and seeing if an oem ignition setup will work. Honestly that has alway worked best for me. MSD has given problems in the past on cars I tuned. A recent one would start breaking up as soon as vtec hit no matter where it was set and even at light load. Took out the MSD and added a bunch of grounds to the engine bay and it completely got rid of it.
Neptune Dealer
www.shuetuning.net
www.powertraincontrolsolutions.com
SOHC_MShue is offline   Reply With Quote
Old 04-12-2006, 04:51 PM   #12
TurboTegB18c
TurboTegB18c's Avatar
Send a message via AIM to TurboTegB18c
Default Re: (Weq)
If your positive it's not tuning related, bypass the ignition box. The 2 wires coming from the distributor, that hooks up to the msd box, run those straight to the coil. 1 positive and 1 negative. That should bypass the box altogether. Hope that helps, Paul
Trackmasters
Dynojet tuning
http://www.etrackmasters.com
Dealer for Rocket Motorsports
http://m24x.zeroforum.com
Need References?? My vouch thread http://www.honda-tech.com/zerothread?id=382495
Best ET: 10.307@146.73mph
Best MPH: 10.398@148.56mph
TurboTegB18c is offline   Reply With Quote
Old 04-13-2006, 04:12 AM   #13
yellowturbo
Default Re: (TurboTegB18c)
Thats what I will do after looking at my grounds...
UPDATE : when im full throttle starting from 2500-3000 rpm I hit full boost at 3500rpm and I pass this misfiring region without any problem ???? When im in mid boost and mid throttle now the misfire happens That really bad since the car is perfect past this region.....
Old 04-13-2006, 07:41 AM   #14
turboeg77
turboeg77's Avatar
change the distributor and all your problems will be gone. its exactly what happened to my car before when i uploaded the wrong aems basemap. change the wires too cuz their next.
turboeg77 is offline   Reply With Quote
Old 04-13-2006, 08:09 AM   #15
yellowturbo
Default Re: (turboeg77)
damn I also runned with a wrong base map that the stupid tech at AEM instaleld in my computer for I dont know why ( I returned them my EMS for a small problem... HOPEFULLY I was doing my broke in period on my new clutch... My tuner is the one who find that it wasnt his map... )
I will change the dizzy for sure now that I read this !
Old 04-13-2006, 08:35 AM   #16
blundar
blundar's Avatar
Send a message via ICQ to blundar Send a message via AIM to blundar
I'm not convinced it's not a tuning issue.
Formerly PGMFI's cheerleader...
RD Tuning - Blundar.com under construction. Tuning in Cincinnati, OH - PM me for rates.
eCtune-Neptune-PowerFC-Crome-Uberdata-Hondata-AEM-Autronic-more
blundar is offline   Reply With Quote
Old 04-14-2006, 06:48 AM   #17
turboeg77
turboeg77's Avatar
Default Re: (blundar)
its not really the tuning that kills the dizzy. its when you havent zeroed in the timing of the EMS to the dizzy that kills it. it has something to do with the stat sync. of the EMS.
Old 04-14-2006, 01:58 PM   #18
KevronsEG
KevronsEG's Avatar
Send a message via AIM to KevronsEG
If your car was sitting all winter maybe you have some water in your tank from temp. change. Thats what happend to me. Just an idea.
Kevron
94civiccx
-The things which we fear the most in life have already happend to us.
FEAR:
F--FALSE
E--EVIDENCE
A--APPEARING
R--REAL
My vouches:
http://www.ef-honda.com/main/viewtopic.php?t=5336
http://feedback.ebay.com/ws/eB...=1883
KevronsEG is offline   Reply With Quote
Old 04-19-2006, 06:11 AM   #19
yellowturbo
update... its not the MSD SCI box... I removed the box last weekend and it still do the same stupid thing.
Damn I cant understand what could cause the car to misfire always at the same spot.
I did another test... if I floor the throttle at 2500 RPM and let the boost built it wont do anything ?????? Its just when im partial throttle.... I begin to suspect a tuning issue.....
Old 04-19-2006, 09:20 PM   #20
2k.civic.si
partial throttle it does it but not under load...its the tuning
Old 04-19-2006, 10:52 PM   #21
Weq
Weq's Avatar
my friend had a similiar problem with his microtech, the ignition driver had issues with higher revs. He did the same, MSd box and all, nothing helped until he switched EMS's.
Old 04-19-2006, 11:25 PM   #22
Drew Peacock
Drew Peacock's Avatar
Sounds like a tuning issue, I would say it IS a tuning issue. I have been there.
Drew Peacock is offline   Reply With Quote
Old 04-19-2006, 11:30 PM   #23
Synapse
Default Re: (turbozxi)
sounds dumb, but I had a similar issue at part throttle.
If you're running an HKS sequential BOV, try cranking on the spring or just run without vacuum line to the BOV and see if it fixes anything.
Synapse is offline   Reply With Quote
Old 04-20-2006, 08:57 AM   #24
Importordomestic
Importordomestic's Avatar
Send a message via AIM to Importordomestic
Default Re: (Synapse)
I had the same problem with my MSD SCI box. BUt my engine is N/A, but i replaced all my grounds and the problem went away.
1990 - S13 - daily driver
1988 - Honda Accord Hatch - project car
Currently: Bulding LS/Vtec Turbo.
WTB: GE Ls/Vtec kit
WTB: ITR Cams
WTB: SC61 Precision Turbo
Luck is a last resort, skill is everything up to the point that you get lucky and **** goes your way - Onemanlan
Importordomestic is offline   Reply With Quote
Old 04-20-2006, 09:08 AM   #25
yellowturbo
thanks for all you reply. Im pretty sure that its my igniter... I will try a new one soon.
2000, 2001, 3800, 4000, accord, crankshaft, crv, gm, honda, load, misfire, p1382, position, rpms, sensor, troubleshoot
