best vtec oil?
Old 04-09-2006, 10:17 PM
  #26
airmax's Avatar
i heard for synthetic the longer you run it the better (4-6k miles)
what about just regular oil? any takes on that?
and the how many quarts are you guys putting into your h22s.
i usually put just a gallon =4 quarts but when ever i measure the dip stick it's barely passing the first dot. you think i need to add another half quart?
Old 04-09-2006, 10:29 PM
  #27
hu
hu's Avatar
Besides not being made by Fram what are the other advantages of the S 2000 filter on the Prelude?
Old 04-09-2006, 10:33 PM
  #28
bad-monkey's Avatar
Default Re: (hu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hu &raquo;</TD></TR><TR><TD CLASS="quote">Besides not being made by Fram what are the other advantages of the S 2000 filter on the Prelude?</TD></TR></TABLE>
larger filter, more filtering media.
i believe this comes at the cost of a little bit of oil pressure though.
Old 04-09-2006, 10:38 PM
  #29
hu
hu's Avatar
I want to give it a try. What year should I buy the S 2000 filter for? My Lude is a 96. I currently use a K&N filter.
Old 04-09-2006, 11:24 PM
  #30
SpeedFreak77's Avatar
Default Re: (pprreelluuddee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pprreelluuddee &raquo;</TD></TR><TR><TD CLASS="quote">and the how many quarts are you guys putting into your h22s.
i usually put just a gallon =4 quarts but when ever i measure the dip stick it's barely passing the first dot. you think i need to add another half quart?</TD></TR></TABLE>
Yeah you need to add some, the H22 takes nearly 5 quarts. Check your manual, I don't have mine in front of me but it's like 4.8 quarts per oil change.
Old 04-09-2006, 11:43 PM
  #31
TimeRacer's Avatar
Default Re: (SpeedFreak77)
Good lord people, 2k and 4k? Any half decent synthetic will last AT LEAST 7500 miles; PERIOD. If you want to waste money please throw it my way. I change my oil @ 10-12k, and have gotten it tested only to find that there's still 5k of life still in there. This is just with cheapest full synthetic on the market, Mobil 1.
Old 04-10-2006, 11:31 AM
  #32
NAmodified's Avatar
Default Re: (monalisa overdrive)
get torco, that oil is a trip the way it works.
Old 04-10-2006, 11:32 AM
  #33
M2B4's Avatar
Default Re: (NAmodified)
h22 hold 5.1 q of oil from empty thats from honda
Old 04-10-2006, 12:00 PM
  #34
Default Re: (M2B4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M2B4 &raquo;</TD></TR><TR><TD CLASS="quote">h22 hold 5.1 q of oil from empty thats from honda</TD></TR></TABLE>
Isn't that with a complete overhaul? Anyways pprreelluuddee isn't putting enough oil in his engine.
Old 04-10-2006, 02:18 PM
  #35
honda3431's Avatar
Default Re: (hu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hu &raquo;</TD></TR><TR><TD CLASS="quote">I want to give it a try. What year should I buy the S 2000 filter for? My Lude is a 96. I currently use a K&N filter.</TD></TR></TABLE>
For the s2k filter, just go to a honda dealership parts desk and ask for a "s2000 oil filter and washer." They are made by toyo roki.
Old 04-10-2006, 10:45 PM
  #36
aslude's Avatar
Default Re: (honda3431)
For the people here that use Mobile 1 synthetic oil, you say you change the oil every 4k~5k miles but didn't say every how many months. Do you change it every 4~5 months?
Old 04-10-2006, 10:55 PM
  #37
petern101's Avatar
Default Re: (aslude)
something like that, depends on how much you drive
sometimes i cahnge at 6k and sometimes a little more because i forget
using 10w-30 from mobil 1. for track i used redline.
Old 04-11-2006, 11:15 AM
  #38
absoludely's Avatar
mobil 1 is a great daily synthetic but not made for the track so even if u do use it there, it's highly recommended u change it once ur done.
Old 04-11-2006, 12:45 PM
  #39
maks's Avatar
Default Re:
Everyone here says how great synthetic oil is... but I think you're forgetting that the engine has 130,000 miles. If you've been using non-synthetic (regular) oil all this time, why not stick with it?
If your engine burns regular oil, it is almost guaranteed that it will burn even more with synthetic, as it is much thinner, and flows easier. Also, synthetic oil affects the seals... so beware with a high mileage engine... just a heads up, synthetic isn't going to solve any problems if that's what you're looking for.
And in my opinion, 2-3k for synthetic change is way too often, but hey, if that's what makes you happy, then go nuts.
Old 04-11-2006, 01:09 PM
  #40
mgags7's Avatar
OP: if it has had dino oil before, keep using it
if you want to know what synthetic to run, use mobil1 10w-30 and change it every 8000 miles, and use a better filter than the FRAM crap....
Old 04-11-2006, 06:38 PM
  #41
TimeRacer's Avatar
Default Re: (absoludely)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by absoludely &raquo;</TD></TR><TR><TD CLASS="quote">mobil 1 is a great daily synthetic but not made for the track so even if u do use it there, it's highly recommended u change it once ur done.</TD></TR></TABLE>
LOL that's the biggest pile of rubbish I've ever seen.
Old 04-11-2006, 06:44 PM
  #42
petern101's Avatar
Default Re: (TimeRacer)
lol i kept my redline in the car long after i came back from the course
7 sessions at 20 minutes each all WOT, i'm sure if i would have done a blackstone analysis it would have been fine
Old 04-12-2006, 04:07 AM
  #43
syntax.'s Avatar
Honda recomends 5w-30 oil. whats the benefit or reasoning behind running 10w-30? Local weather highs and lows?
Also, Honda makes a filter for our engines. It is the right size so you dont lose oil pressure and i'm hoping its made better than a fram. Any comments on that?
Old 04-12-2006, 04:47 AM
  #44
95PreludeSi's Avatar
Default Re: (syntax420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by syntax420 &raquo;</TD></TR><TR><TD CLASS="quote">Honda recomends 5w-30 oil. whats the benefit or reasoning behind running 10w-30? Local weather highs and lows?
Honda recommends...
H22a1 - 10w-30
H23a1 - 5w-30
Old 04-12-2006, 05:25 AM
  #45
VisPreludeVtec's Avatar
Default Re: (95PreludeSi)
I have an h22 with almost 90k....I use synthetic blend in mine...works fine
Old 04-12-2006, 08:46 AM
  #46
M2B4's Avatar
Default Re: (VisPreludeVtec)
i was told to run 5w-30 not 10 by the rep at royal purple when i ordered my oil
Old 04-12-2006, 09:03 AM
  #47
syntax.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95PreludeSi &raquo;</TD></TR><TR><TD CLASS="quote">
Honda recommends...
H22a1 - 10w-30
H23a1 - 5w-30</TD></TR></TABLE>
I just called my local Honda monger and they recommended 5w-30 for my h22a4. I only have the helms for a 4th gen. Does anyone have a 5th gen helms to confirm this?
Old 04-12-2006, 09:08 AM
  #48
bad-monkey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by syntax420 &raquo;</TD></TR><TR><TD CLASS="quote">I just called my local Honda monger and they recommended 5w-30 for my h22a4. I only have the helms for a 4th gen. Does anyone have a 5th gen helms to confirm this?</TD></TR></TABLE>
manual states that if your temperatures are above freezing you can run either 5-30 or 10-30.
Old 04-12-2006, 10:02 AM
  #49
Mr.Luder's Avatar
Default Re: best vtec oil? (lewdlude)
if ur using royal purple and ur changing ur oil that often i think ur wasting ur money. its just retarded. royal purple is expensive as hell if u didnt notice and it is one of the best kind of oil out right now.
Old 04-12-2006, 02:34 PM
  #50
absoludely's Avatar
it's fine if you actually had some valuable information to contradict what i said with, but saying what you did with no backup? worthless.
Quick Reply: best vtec oil?
