Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Prelude
Old 04-09-2006, 03:37 AM   #1
darkstar1440
darkstar1440's Avatar
Send a message via AIM to darkstar1440
Default best vtec oil?
Does anyone know what the best oil woiuld be to run on my 130000 mile h22a1 is royal purple and good ??please help what's good?
darkstar1440 is offline   Reply With Quote
Old 04-09-2006, 05:07 AM   #2
PRELUDE-GT35R
PRELUDE-GT35R's Avatar
Default Re: best vtec oil? (darkstar1440)
As long as you change every 2000 mlies. Its all good for your motor Click the image to open in full size.
PRELUDE-GT35R is offline   Reply With Quote
Old 04-09-2006, 08:21 AM   #3
mkazm83
mkazm83's Avatar
Send a message via AIM to mkazm83
RP, Mobil 1, Amsoil, are all good oils.
mkazm83 is offline   Reply With Quote
Old 04-09-2006, 08:46 AM   #4
93h22a1vtec
93h22a1vtec's Avatar
Send a message via AIM to 93h22a1vtec
Default Re: best vtec oil? (mkazm83)
mobil 1 ftw
I drive a brittany blue green sex machine
93 bb1 with h22a and a few bolt ons
"I'm so jdm I drive on the other side of the road"
<U>F/S</U>MANY MANY h22 parts, i have a spare blown motor pm me if you need something: JDM pistons, 3 usdm pistons, JDM rods, 3 usdm rods, crank, JDM cams, usdm cams, rebuildable head with p&p (needs comb. cham. re weld), and, alot of random ****
AIM:bbLUDE93
[B][I]BB SQUAD #74[/I][/B]
93h22a1vtec is offline   Reply With Quote
Old 04-09-2006, 10:25 AM   #5
Buffalo
Buffalo's Avatar
Default Re: best vtec oil? (93h22a1vtec)
Originally Posted by 93h22a1vtec
mobil 1 ftw
x2
In order to be old and wise you must first be young and stupid
...so hit vtec more often yo http://images.honda-tech.com/set1/smile/emwink.gif
Buffalo is offline   Reply With Quote
Old 04-09-2006, 10:29 AM   #6
M2B4
M2B4's Avatar
Default Re: best vtec oil? (Buffalo)
royal purple FTW
M2B4 is offline   Reply With Quote
Old 04-09-2006, 10:31 AM   #7
honda3431
honda3431's Avatar
Send a message via AIM to honda3431
mobil 1 synthetic. and change it every 3-4k. and use the Honda S2000 oil filter. make sure you change the washer.
-Will
'92 Prelude Si (RIP), '92 Prelude Si (Sold), '94 Accord EX Coupe (Sold), '93 Prelude Vtec (Parting), '05 GPW S2000
honda3431 is offline   Reply With Quote
Old 04-09-2006, 10:33 AM   #8
M2B4
M2B4's Avatar
Default Re: best vtec oil? (honda3431)
what makes the honda s2000 filter so much better?
Old 04-09-2006, 11:56 AM   #9
DIRTYsouthBB6
DIRTYsouthBB6's Avatar
Default Re: best vtec oil? (M2B4)
It's JDM boooiiiiiii!!!!!!!!! Click the image to open in full size.
DIRTYsouthBB6 is offline   Reply With Quote
Old 04-09-2006, 11:59 AM   #10
Yield
Yield's Avatar
There is no reason to change your oil anywhere near 2-3000 miles. You're wasting your money. Synthetics last much longer - in the 5-10,000 mile range. Do an oil analysis if you don't believe it. Just get a good synthetic like mobil 1 or the german castrol.
Yield is offline   Reply With Quote
Old 04-09-2006, 01:37 PM   #11
honda3431
honda3431's Avatar
It's not made by Fram and its OEM
-Will
Old 04-09-2006, 01:38 PM   #12
honda3431
honda3431's Avatar
Default Re: best vtec oil? (DIRTYsouthBB6)
You're a *** and have no idea what you're talking about
-Will
Old 04-09-2006, 02:17 PM   #13
redtop22
redtop22's Avatar
Click the image to open in full size. + Click the image to open in full size.
redtop22 is offline   Reply With Quote
Old 04-09-2006, 02:24 PM   #14
BlueLude 94
BlueLude 94's Avatar
Default Re: (redtop22)
Greedy just released an oil that is strictly ment for VTEC engines.
JDM fogs for sale. PM mew for info.
BlueLude 94 is offline   Reply With Quote
Old 04-09-2006, 02:42 PM   #15
93h22a1vtec
Default Re: (BlueLude 94)
any more info on that?
AIM:bbLUDE93
Old 04-09-2006, 03:20 PM   #16
mkazm83
mkazm83's Avatar
HAHAHA.
Old 04-09-2006, 03:31 PM   #17
98vtec
Gone Fishin'
1998 Honda Prelude
98vtec's Avatar
efi.logistics.by.blake.barr bbmoto
Default Re: (mkazm83)
Royal Purple here Click the image to open in full size.
Mercedes-Benz Systems Technician
Pescador Perception Sport 12.0 w/ 30# Minn Kota
1998 H2B Turbo Prelude - project
98vtec is offline   Reply With Quote
Old 04-09-2006, 04:07 PM   #18
lewdlude
1996 Honda Civic
lewdlude's Avatar
Royal Purple here. Call me obsessive but i change my oil every 2500-3500miles with partial quart top offs. h22's are notorious for oil consumption. Valve seals, and cam seals will help. But even from the factory they burn oil. I say check your oil regularly, make sure you're lubricated, top off as needed, and at least change at the recommended interval 3750miles unless you run synthetic then as yield said 5-10kmi. Measuring how much oil is left in your engine between intervals will give you a better idea of how much oil your motor burns or leaks (that's beyond the scope of this discussion). I have seen approx 1qt per 1000mi, of consumption, with conventional oil and half that for royal purple at least on my vehicle. So i think top offs are especially important.
Send some samples to blackstone for analysis. Let a professional determine how long you have before changing your oil.
lewdlude is offline   Reply With Quote
Old 04-09-2006, 04:09 PM   #19
98vtec
Gone Fishin'
1998 Honda Prelude
98vtec's Avatar
Default Re: best vtec oil? (lewdlude)
i change mine every ~4500
2500 is way to earlier.....thats just getting into the oils peak.
Old 04-09-2006, 05:30 PM   #20
honda3431
honda3431's Avatar
Default Re: best vtec oil? (98vtec)
after i pass 3k, i start thinking about changing it. sometimes i keep it in there until over 4k. but i use synthetic. contrare to what some may say, synthetic does break down if you run your engine hard. i was burning a quart every two weeks before i changed my oil last. and that was after about 4,500 miles.
-Will
Old 04-09-2006, 05:33 PM   #21
AnthonyG2003
Guest
Posts: n/a
i heard about that as well....
Old 04-09-2006, 06:14 PM   #22
M2B4
M2B4's Avatar
Default Re: best vtec oil? (AnthonyG2003)
ive learned to let everyone else test new stuff then try it Click the image to open in full size.
Old 04-09-2006, 06:17 PM   #23
bad-monkey
bad-monkey's Avatar
Send a message via AIM to bad-monkey
i change oil every 8000 miles.
mobil 1 10w30.
i refuse to change oil every 3000 miles.
og poster: what kind of oil have you been using for the past 130000 miles? synthetic in a high mileage motor can lead to some headaches.
bad-monkey is offline   Reply With Quote
Old 04-09-2006, 06:30 PM   #24
M2B4
M2B4's Avatar
Default Re: (bad-monkey)
im gunna be running royal purple 5w-30 plan to change every 5k
Old 04-09-2006, 06:53 PM   #25
monalisa overdrive
monalisa overdrive's Avatar
I've been running Amsoil Series 2000 0W-30 for about 10k, runs well
monalisa overdrive is offline   Reply With Quote
98, change, consumption, h22, high, honda, mileage, oil, oilf, prelude, recomended, recommended, s2000, synthetic, vtec, weight
