Tips for taking off stuck oil filter
#26
Re: Tips for taking off stuck oil filter (redteg1)
When I couldn't get my oil filter off the first time when I was changing my oil and the cheap *** oil wrench would not grip, I said **** it and got the honda oil cap. Works like a charm.
Just got a digi cam so I'm going crazy with it.
#28
Re: Tips for taking off stuck oil filter (Halo)
Screwdriver is a risky move. if you tear the outer part of the filter, there is no way it will come off. I will never use that method again.
#29
everyone who has suggested using a sandpaper knows their ****.
sandpaper is the way to get that thing off. a 200 grit sandpaper always
works for me. jus make sure you are far enough under the car so you
can get some leverage. i usually go as far as my belly button area near
the control arm. GET YOUR *** WAY IN THERE. you'll get that **** out.
SANDPAPER!!!
SANDPAPER!!!
#30
Re: Tips for taking off stuck oil filter (Dr. RAB01GSR)
Nice camera
#31
Re: Tips for taking off stuck oil filter (keys)
damn I sure wish I knew about the sandpaper method before I stabbed my filter. Has anyone ever done or heard of anyone doing any damage to the engine block using the screwdriver stab method?
BTW nice camera, what kind is it?
#32
So I'm guessing no one has ever damaged their block or heard of anyone damaging their block using the screwdriver stab method?
#36
Re: Tips for taking off stuck oil filter (SiMugen)
Leather belt works, but I've snapped a few before on cars that are factory tightened. Filter wrenches work great if you can fit it on the filter.
Sandpaper or a nice mechanic's glove also will make a tough filter a ton easier to pop off.
#37
Re: Tips for taking off stuck oil filter (ExOdy)
Punch a screw driver into it and unscrew.
