Tips for taking off stuck oil filter
Old 04-04-2002, 11:36 PM
Halo's Avatar
Default Tips for taking off stuck oil filter
How do you guys remove a stuck oil filter? I did a search had no luck.. thanks in advance
Old 04-05-2002, 12:04 AM
B2FiNiTY's Avatar
Default Re: Tips for taking off stuck oil filter (Halo)
Punch a screw driver into it and unscrew.
Old 04-05-2002, 12:08 AM
keys's Avatar
Default Re: Tips for taking off stuck oil filter (B2FiNiTY)
screwdriver should be a last resort....
try first:
oil filter wrench
leather belt
Old 04-05-2002, 09:38 AM
robbin's Avatar
Default Re: Tips for taking off stuck oil filter (keys)
you can buy sort of a huge socket that fits over the filter and then unscrew it with a ratchet with an extension. The socket's like $3 or something.
Old 04-05-2002, 09:42 AM
reefer_bob's Avatar
Default Re: Tips for taking off stuck oil filter (robbin)
Screwdriver will work, but like said... LAST resort... There is an oil filter remover called the claw, which is adjustable, it has 3 prongs on it that clamp around the filter and tighten as you try to loosen the filter... I forget where I got it though... gotta think...
Reefer_Bob.
Old 04-05-2002, 11:54 AM
eastsidemags's Avatar
Default Re: Tips for taking off stuck oil filter (reefer_bob)
super walmart has that thing
Old 04-05-2002, 11:59 AM
Dirt's Avatar
Default Re: Tips for taking off stuck oil filter (eastsidemags)
Mechanix glove and good leverage works for me.
Old 04-05-2002, 12:06 PM
gsr squirrel's Avatar
Default Re: Tips for taking off stuck oil filter (MmmVTEC)
i use on of those rubber hand grips that i used to use at the gym. works good for me.
Old 04-05-2002, 02:00 PM
GSRaCeRbOI's Avatar
latex or Mechanix gloves, grip hard and turn
if that doesnt work.. you can try using a piece of sandpaper to grip the filter and then turn it.. if htat still doesnt work try using an oil filter wrench.. there are a few kinds.. one where the tips are semi circles and grip on the filter, theres the kind that attach to a 3/8" ratchet.. as you turn it to loosen the tips close and grip ... theres the normal oil filter wrenches, if all else fails.. jab a screwdriver thru it and turn...
Old 04-05-2002, 04:58 PM
amal8301's Avatar
Default Re: Tips for taking off stuck oil filter (GSRaCeRbOI)
My last oil change I used all the normal methods, then I used the screwdriver and the filter casing ripped. I ended up putting 5 holes in it before it was loose enough to turn by hand(punch, turn about 1/32 of a turn and the hole was too deformed to use, repeat).
I'll never go to a quick lube place again.
Old 04-05-2002, 05:42 PM
Jackson's Avatar
try first:
oil filter wrench
leather belt
whoa baby! not the leather belt!
Old 09-17-2002, 02:41 PM
keys's Avatar
Default Re: Tips for taking off stuck oil filter (Jackson)
lol yes the leather belt!!
As much as I hated to punch a screwdriver through my oil filter, I had to do it today. The weird thing is that I only screwed my filter on hand tight(because ever since I switched filter brands, my filter wrench doens't fit anymore) and even though I tightened the filter hand tight, for some reason my hand wasn't able to get it out. So it does happen and the screwdriver was my last resort, because I couldn't drive my car to get a oil filter wrench that fit. HTH
Old 09-17-2002, 03:53 PM
Area57's Avatar
60-80 grit sandpaper...be very carefull w/ the screwdriver
Old 09-17-2002, 04:06 PM
mugenracer's Avatar
Default Re: Tips for taking off stuck oil filter (Area57)
make sure when replacing it to put a little oil around the rubber seal on the end of the filter, this will also help in getting it off again, as it stops the rubber from sticking/melting to the hot engine
Old 09-17-2002, 04:19 PM
Tweakmeister's Avatar
ahhh the screwdriver death stab! I know it well. Last time it was a hot Mobil1 bath
I took pics of the filter...need to get them up.
You can try the cap thingys (I never get them to fit) or the strap things or the huge *** Channel Lock pliers (a personal favorite).....or you can get this, a gift from Heaven....
http://buy.snapon.com
EDIT\\\okay no doubt the above link is DOA. So, go to snap-on and get the adjustable oil filter wrench. As you tighten, it tightens against the filter. It wouldn't have worked on the last filter I had to stab (I ended up bending two screwdrivers on this beauty) but it should do the trick for other ones....
[Modified by Tweakmeister, 1:25 AM 9/18/2002]
Old 09-17-2002, 04:20 PM
EL Vap133's Avatar
Wrap a thick ruberband around the filter and try unscrewing it by hand...
Old 09-17-2002, 04:34 PM
stumpyf4's Avatar
Default Re: Tips for taking off stuck oil filter (Vap133)
A big pair of channel lock pliers will do the job.
Old 09-17-2002, 05:32 PM
PatrickGSR94's Avatar
Default Re: Tips for taking off stuck oil filter (stumpyf4)
I always use a piece of coarse sandpaper. I don't even try any other method first, I just get the sandpaper and go at it.
Old 09-17-2002, 06:37 PM
keys's Avatar
Default Re: Tips for taking off stuck oil filter (PatrickGSR94)
damn I sure wish I knew about the sandpaper method before I stabbed my filter. Has anyone ever done or heard of anyone doing any damage to the engine block using the screwdriver stab method?
Old 09-17-2002, 07:40 PM
IN VTEC's Avatar
I use the claw. Works without fail, unless i use the smaller Honda filters from the 'K-series engines or the HAMP filters.
I'm trying to find a smaller claw.
Old 09-17-2002, 07:48 PM
MattG's Avatar
I did the screw driver trick and it worked. I used to do it on an old truck we had. Not the best way but in a pinch it will get the filter off.
Old 09-17-2002, 07:55 PM
ingrate's Avatar
Default Re: Tips for taking off stuck oil filter (MattG)
this is my first time posting pics in a really long time so don't laugh
Old 09-17-2002, 08:38 PM
Rusty Shackleford's Avatar
Default Re: Tips for taking off stuck oil filter (In7egrity)
how tight are you guys putting your filters on? i put mine on hand tight, and get it off with a hand. it probably helps i use the filters with a textured grip, but filters dont need to be so tight.
Old 09-17-2002, 10:02 PM
redteg1's Avatar
Default Re: Tips for taking off stuck oil filter (cpteg)
i use fram cuz it has the grip thing. so then next oil change i just unscrew it by hand
Old 09-17-2002, 10:05 PM
smeister's Avatar
Default Re: Tips for taking off stuck oil filter (ExOdy)
This is my first resort if I cant get the oil filter off with a good grip. This only happens after the dealer puts the oil filter in though. Those hand wrenches have never worked for me because I have a hard time putting it on the rachet. A hole in the old oil filter isn't a big deal anyways. You will end up throwing it away anyways. JMO
Quick Reply: Tips for taking off stuck oil filter
