Old 04-03-2006, 11:39 AM   #1
RICE POLICE SIP
1997 Honda Del Sol
RICE POLICE SIP's Avatar
iTrader Rating: (1)
Default SOHC timing belt teeth????
Does anyone have a run down of all the SOHC timing belts and how many teeth they have? Or where I can find the info? Anywhere from EF's to the 7th gen civics... TIA
Accidents in the back seat cause kids;Kids in the back seats cause accidents
Bought from: ICeDoUt; big-cat Sold to: pane93civhb
RICE POLICE's Garage
RICE POLICE SIP is offline   Reply With Quote
Old 04-03-2006, 01:20 PM   #2
RICE POLICE SIP
1997 Honda Del Sol
iTrader Rating: (1)
Default Re: SOHC timing belt teeth???? (Split Image Prez)
I put a 92-95 civic head (d15b7) on a 96-97 del sol block (D16y7) and now the y7 timing belt is to short... anyone know of any longer belts?
Old 04-04-2006, 08:59 AM   #3
RICE POLICE SIP
1997 Honda Del Sol
iTrader Rating: (1)
well after a little research and counting of teeth on timing belts I find that on the 91 CRX si 1.6L belt you have a 106 tooth belt and a 107 tooth belt... The D16Y7 belt has 104 teeth... I'm still doing a little more research but I ended up buying the 107 tooth belt...
Old 04-04-2006, 02:56 PM   #4
RICE POLICE SIP
1997 Honda Del Sol
iTrader Rating: (1)
anyone know any of the other belt tooth counts?
Old 04-04-2006, 02:58 PM   #5
SVOboy
SVOboy's Avatar
Send a message via AIM to SVOboy
Bump for fun, this'd be good info to put in a FAQ.
www.crxMPG.com <-- MPG the CRX way, http://images.honda-tech.com/set1/smile/emwink.gif
http://www.ecomodder.com <-- Trick out your car for fuel economy!
SVOboy is offline   Reply With Quote
Old 04-04-2006, 03:24 PM   #6
92hatchling
92hatchling's Avatar
Default Re: (SVOboy)
it the b7 belt your looking for you almost always use the belt for the head you use
92hatchling is offline   Reply With Quote
Old 04-04-2006, 03:51 PM   #7
RICE POLICE SIP
1997 Honda Del Sol
iTrader Rating: (1)
Default Re: (92hatchling)
That's what I was thinking too, but then I was thinking if it's a 1.5L block why would the belt be longer.. I stopped by Auto Zone and the CRX si belt have the same part number as the D15b7 belt.. But one is a 1.5L and the other is a 1.6L also..... When they pull up the 91 CRX 1.6L in the computer it asks you 106 or 107 tooth... Why would they be different?
Old 04-04-2006, 04:03 PM   #8
mc
mc's Avatar
Default Re: (Split Image Prez)
the d15z1 belt is 103 teeth
edit:
actually I found some more after searching a little
The VX timing belt has 103 teeth, where as the Z6 timing belt has 104 teeth, and the B7 belt 106 teeth.
Modified by mc at 9:12 PM 4/4/2006
mike
92 EG8 Phantom Gray Sedan
D15B powered... FINALLY turbo'd http://images.honda-tech.com/set1/smile/emthup.gif
mc is offline   Reply With Quote
Old 04-05-2006, 08:27 AM   #9
RICE POLICE SIP
1997 Honda Del Sol
iTrader Rating: (1)
Default Re: (mc)
edit:
WOW 103 lol Thanks for the info! I put the 106 tooth belt on and it seems to be just fine... knock on wood... LOL
Old 06-10-2007, 09:01 PM   #10
Metal Head
Metal Head's Avatar
Default Re: (RICE POLICE SIP)
does vtec and non vtec affect the belts length? I have a d15B vtec, im looking for a belt for it, I assume the d16z6 belt would work cuz its VTEC, so I have to use a 1.5L belt, does it HAVE to be vtec? or can I buy a 1.5L non-vtec belt??
Metal Head is offline   Reply With Quote
106, b7, belt, civic, d15b7, d16y7, difference, honda, numbers, part, teeth, timing, tooth, y7, z6
