How long do Honda engines usually last?
Old 04-04-2006, 06:24 AM
  #26
existanzcivicb20's Avatar
Default Re: (kaoss_11)
wen you buy a car check suspension, under the chassis for leaks, bushings, motor mounts, brakes (the hole system), the body, inside the car make sure everything works and estimate ur damage and see if its a good buy for you
I have a 97 cx hatch with 210k swapped out the motor sold the single cam and its still running in my Buddy's car I dont no how many miles it has now but its like 280k - 300k
Old 04-04-2006, 11:12 AM
  #27
junbb1's Avatar
Default Re: (existanzcivicb20)
There was a small magazine insert in Car and Driver about 2 years ago, where a subscriber sent in a picture of his 1996 accord. the pic. was of him and his car and a pic. of the odometer. It was taken just prior to rolling 1,000,000 miles it was 999,999,... The owner was a map maker.
In the article it talked about his routine services always done at a honda dealer.
changed oil once a week always using full synthetic.
Changed trans fluid once a month. (MT)
Preformed all major services and at appropriate milage. (t-belt , plugs etc...)
He was on his second Alternator.
Second radiator
Original muffler--never had time to rust.
second or third clutch
original transmission components
you get the idea, but the car was still running with absolutly no problems.
My opinion Honda should by it back from the customer and give him a brand new one. It would be great for R&D.
Old 04-04-2006, 11:22 AM
  #28
GDD Lonely Krew
the_unknown's Avatar
on a honda, the last thing you should be worrying about is the motor, especially when the car will be swapped later on. as stated before just make sure the body, frame and suspension are straight. the rest will come easily and with minimal cost. what will kill you in the long run is body work. body work is body work whether it be on a honda or a bmw. therefore the labor will always cost the same. motor work on the other hand, is a completely different story.
Old 04-04-2006, 01:04 PM
  #29
EsQueue's Avatar
Default Re: (the_unknown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the_unknown &raquo;</TD></TR><TR><TD CLASS="quote">on a honda, the last thing you should be worrying about is the motor, especially when the car will be swapped later on. as stated before just make sure the body, frame and suspension are straight. the rest will come easily and with minimal cost. what will kill you in the long run is body work. body work is body work whether it be on a honda or a bmw. therefore the labor will always cost the same. motor work on the other hand, is a completely different story.</TD></TR></TABLE>
Fully agreed.
Old 04-04-2006, 04:08 PM
  #30
edseg6es's Avatar
my 90 integra ls 4dr 5spd 238,000 boyyyyyyyyy
Old 04-04-2006, 05:25 PM
  #31
DC4KiD's Avatar
Default Re: How long do Honda engines usually last? (DC4KiD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC4KiD &raquo;</TD></TR><TR><TD CLASS="quote">My '93 Accord (all stock) has over 220,000 miles, and counting up very fast every week </TD></TR></TABLE>
I just changed the oil in this car a few days ago @ 221,304 miles, and the car does not burn oil at all. Everything all stock, maintained well by me
Old 04-04-2006, 05:44 PM
  #32
MEAT PATTY
goforbroke's Avatar
Default Re: How long do Honda engines usually last? (THEUSED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEUSED &raquo;</TD></TR><TR><TD CLASS="quote">My CX went 316k before it blew a head gasket and the rings were nearly gone, though I drove the hell out of it everyday trying to blow it up</TD></TR></TABLE>
My cx has 200K on it but it burns a quart of oil every 100 miles, kinda sucks but its the beata.
Old 04-04-2006, 07:25 PM
  #33
StorminMatt's Avatar
Agreed. It is MUCH better to buy a car with a good body and bad drivetrain than to buy the opposite. Also keep in mind that the motor is the most reliable thing in ANY Honda. You will destroy a transmission before you EVER destroy a motor.
Old 04-06-2006, 06:28 PM
  #34
datssoled's Avatar
sorry im new at this
"check suspension, under the chassis for leaks, bushings, motor mounts, brakes (the hole system), '" how do you check those?
how am i suppose to estimate the damages i can do to the car?
Old 04-06-2006, 06:41 PM
  #35
DC2 Mang's Avatar
ive seen soo many go past 200k without problems
my friends 91 accord 307k down due to a fuel pump but runs like a champ, drove it from the bay to santa barbra with no problems
my other freind had 295k on hi 91 integra and was squeezing on it for 100k and it still drives
Old 04-06-2006, 09:06 PM
  #36
honda-freak's Avatar
Default Re: How long do Honda engines usually last? (datssoled)
Honda engines last a life time all you have to do is give them a little lovin' if you dont like how many miles are on the engine then rebuild it upgrade some stuff to make it be how you want then you got urself a real toy to drive
Old 04-07-2006, 10:44 PM
  #37
datssoled's Avatar
so if im about to spend $5-6 k, would you try to find a car at $4-5 k and spend the rest on taking care of the car, i. e. replacing parts and cleaning it up?
Old 04-07-2006, 11:36 PM
  #38
OMG WTF's Avatar
My girlfriends uncle has a 97 Odyssey. 390,000 miles and still going.
Old 02-22-2020, 03:26 PM
  #39
Charles White's Avatar
Originally Posted by datssoled
Hey
Im new here and Im not sure if Im suppose to post on this forum, but how long do Honda engines usually last?
I have heard it can go stories where it can go until 325,000 miles or 250,000 miles. But with the normal wear and tear, w/o racing on it, how long do they last?
Im trying to find a car, mainly civics,accords, integras, and preludes, right now and most of them has around 125k miles and up.
Old 02-22-2020, 03:32 PM
  #40
I have a 2007 Honda Civic Coupe LX, with, 294,000 km. 181.5 k miles. Runs like new. Added a computer enhancer, eco fuel module. Works hot damn. Runs better and better fuel mileage and almost the horse power of the SI. Yep. Great car! Only problems is I am old and tall and that car is So close to the ground. Nice when in, a bitch in or out .
Old 02-27-2020, 08:50 PM
  #41
EmmatheEclipse's Avatar
I have found out in my experience it isn't how many miles does a honda engine last it is how miles does the transmission last lol my 95 integra b18b1 has 144k miles on it and it is still kicking but the transmission lost all power in d4 (yes it is an auto) and most power in d3 so the engine lasts for a long time but the trans you will be replacing every so many miles since the reason I am looking for a manual trans cause they last as long as the engine does and sometime longer
Old 02-28-2020, 09:56 AM
  #42
All motor Mike's Avatar
Every Honda I’ve ever purchased had 195k+, even bought one with 337k on it, all ran awesome and only ever blew one f22a1 engine with 389k due to oil starvation from massive sludge build up. Maintenance it and it’ll last a very long time even with a beating. 125k is hardly even broken in lol it’s nothing at all for miles on a Honda.
Old 02-28-2020, 12:49 PM
  #43
Premium Member
Aradin's Avatar
I service multiple examples that have 400-500k+ miles. Maintenance is key.
Old 02-29-2020, 10:40 AM
  #44
K7-1Ktrevor's Avatar
I tuned a gsr with 381k on it original miles original motor. That gsr ran super strong and didn’t smoke from what I could tell. When it comes to Honda’s miles are just a number judge the car on the condition and current issues.
Old 03-08-2020, 01:35 PM
  #45
Scottwax's Avatar
Sold my 1990 Accord with 280,285 miles on it, still running when I saw it 6 years later, had well over 300k miles then. Current Accord just passed 264,000 miles, still runs great. Change the oil every 7500 miles with synthetic, down maybe 1/4 quart at 7500 miles.
Old 03-16-2020, 10:13 AM
  #46
Dohcit's Avatar
Hard to say for how long it should last.
i have an 82 2nd gen civic which his engine has never been opened and is still running.
its been well maintained through the years, but never overhauled.
Old 03-23-2020, 09:12 AM
  #47
baruch1's Avatar
1986 accord still going with over 350k miles.
Old 03-23-2020, 07:05 PM
  #48
CyborgGT's Avatar
hickuphonda
05-13-2013 11:28 AM
muddmonky
07-08-2012 08:05 PM
Beyondthespeed19
06-15-2010 09:20 AM
Exodus Cycling
Honda Civic (2006 - 2015)
03-10-2008 05:39 PM
Quick Reply: How long do Honda engines usually last?
