***How-To Clean*** Your IACV a.k.a. Idle Air Control Valve
Old 10-08-2006, 03:18 PM
  #51
GHETTOBEAST's Avatar
Default Re: ***How-To Clean*** Your IACV a.k.a. Idle Air Control Valve (wildoutwhitegsr)
subscribed, bump for a nice write up
Old 10-08-2006, 04:56 PM
  #52
rickturboteg's Avatar
Default Re: ***How-To Clean*** Your IACV a.k.a. Idle Air Control Valve (GHETTOBEAST)
i got a 1.5 single cam with 1.6 vtec head (mini-me-swap) does my car have this valve underneath the throttle body?
Old 10-09-2006, 06:16 PM
  #53
rollercosta123's Avatar
Default Re: ***How-To Clean*** Your IACV a.k.a. Idle Air Control Valve (rickturboteg)
i did it and it did not work on my 97 accord ex
Old 10-09-2006, 08:46 PM
  #54
wildoutwhitegsr's Avatar
Default Re: ***How-To Clean*** Your IACV a.k.a. Idle Air Control Valve (rollercosta123)
this will only help if your idle problem is coolant related.
Also try a tune up ignition related
-spark plugs
-spark plug wires
-02 Sensor, big one on older cars
Then move onto fuel related
-fuel filter
-fuel injectors
Then vacuum
-check for intake manifold leaks
-exhaust manifold leaks
-exhaust leaks
-clean your pcv valve or replace
As a last straw, do a sea foam cleaning. Search for that one.
Old 10-11-2006, 02:55 PM
  #55
i have done my car twice and every time i have done it it made it worst. i looked at it and while the car was running i loosend the 2 bolts and moved it around a bit and it got better. i think im gonna get a new rubber seel. i know hat the reason why theres a roming idle on cars is because when air is coming in the manifold it puts air pressure on the iacv and with a bad rubber seel it has some air leaking out and makes the idle roam from 1000 to 1500 and back and forth. a new seal is good for older cars that have a roaming idle
Old 10-13-2006, 03:18 PM
  #56
i have a 97 accord ex 4 cyl and i just recently had problems with my idle control valve and car used to rev up to high and i cleaned it out and put a brand new seel to it. now the car revs down to 500 and even 200 rpm. I personaly dont think its the iacv. i am thinking it could be a fuel filter cause i never changed it (i had the car for a year) i took my battery to get it tested and they told mine was bad i bought a new one. its doing the same problem so if anyone has any input please tell me. also they tested the alternator and said it was good
Old 10-13-2006, 03:50 PM
  #57
lostsonta's Avatar
Well, regardless when the IACV is removed it should be tested to see if it actually works.
When the two terminals on the IACV are measured with an Ohm-meter, it must vary between 8-15 Ohms. If not, the IACV must be replaced.
Old 11-19-2006, 07:49 PM
  #58
ari.'s Avatar
Default cheesefries
Old 11-21-2006, 06:57 AM
  #59
nahledge's Avatar
Default Re: cheesefries (skinnyshugg [V2])
Nice write up. This should help me out with the problem that i am having right now. I started my car the other day and the RPM was fluctuationg from 500 to 100 and engine almost turning off completely. I would rev it and RPM would still drop. I turned it off and back on and it went away. However, the following day it did it again and wont go away. If its not this it could be my TPS or FITV.
Old 11-21-2006, 06:58 AM
  #60
nahledge's Avatar
Default Re: cheesefries (nahledge)
You dont have to reset your ecu after this right?
Old 11-21-2006, 10:40 AM
  #61
S2KILLA's Avatar
Location: Yeah IM from Jersey, big wup, wanna fight about, it, USA
subscribed...
Old 11-28-2006, 02:38 PM
  #62
scartail's Avatar
Is the IACV a dealer only item?
I've cleaned mine out, but I still have problems with my high cold idle and sluggish acceleration when the engine is relatively cold.
Old 01-16-2007, 09:27 AM
  #63
b20acura's Avatar
so am i suppose to spray wd-40 into it?
  #64
b20acura's Avatar
Old 01-16-2007, 12:50 PM
  #65
Default Re: ***How-To Clean*** Your IACV a.k.a. Idle Air Control Valve (b20acura)
^^^ No
Old 01-21-2007, 11:03 PM
  #66
EFmashplz's Avatar
so i cleaned this and my FITV.
my car was idling from 1000 to 2000 rpms warm and 1500 to 2500 cold. back and forth. a constant roam the whole time i drove.
i cleaned these 2 valves.
1500 steady like a rock cold.
800 steady like a rock warm.
THANK GOD FOR THESE WRITE UPS
Old 02-09-2007, 12:02 AM
  #67
4Door Life's Avatar
Default Re: (EFmashplz)
dumb question i know, were is the FITV located..? i cleaned the IACV and its still surging at idel, 1500-2000rpm's... when driveing it seems to be fine unless im just creepin along... Thank's, Brian
Old 03-13-2007, 08:15 PM
  #68
edo_13's Avatar
Default Re: (4Door Life)
Question,
I have a 1994 honda accord
lately the rpm little arm has been just going up and down from 1-0 .... just up and down and at times just turns off the car...
could it be that i need to also clean it?
Old 05-07-2007, 10:50 AM
  #69
Budget Racer's Avatar
Can someone post a pic of IACV location on a D16y7? Please!!
Old 05-07-2007, 12:42 PM
  #70
Default Re: ***How-To Clean*** Your IACV a.k.a. Idle Air Control Valve (Budget Racer)
bump
bump bump
bump bump bump
Old 05-07-2007, 08:40 PM
  #71
b16a4's Avatar
i have a civic, i cleaned my iacv and my car still hunts, idles from 1000-1500rpm
help me out guys
Old 05-08-2007, 12:19 AM
  #72
Default Re: ***How-To Clean*** Your IACV a.k.a. Idle Air Control Valve (b16a4)
bump for pics of D16y7 throttle body
Old 05-23-2007, 04:41 PM
  #73
dougshatch's Avatar
I took IACV and i notice there was a screen and its complete black what should i do? i have 1991 Honda civic DPFI, and i have a pretty rough idle from 1000rpm to 2500, and the idle really rough and i tried drive it and i cant go over 3500rpm at all does that IACV could be the effective?
Old 06-18-2007, 05:20 PM
  #74
EnjoyTheRideDC2's Avatar
Default Re: ***How-To Clean*** Your IACV a.k.a. Idle Air Control Valve (dougshatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dougshatch &raquo;</TD></TR><TR><TD CLASS="quote">I took IACV and i notice there was a screen and its complete black what should i do? i have 1991 Honda civic DPFI, and i have a pretty rough idle from 1000rpm to 2500, and the idle really rough and i tried drive it and i cant go over 3500rpm at all does that IACV could be the effective?</TD></TR></TABLE>
Clean the screen on the IACV.
I think the problem with your motor though lies in the ignition or timing area. Check to be sure your timing is right, check the plugs and wires, cap, rotor.
Old 06-23-2007, 12:55 PM
  #75
DuDeJo's Avatar
Nice write up, but uh i cant even take out the screws they're rly rusty and the 12mm socket just rounds up the screw and it slides around ... lol
Dunno what to do now
Quick Reply: ***How-To Clean*** Your IACV a.k.a. Idle Air Control Valve
